Is this compatible?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Croth51, Jan 20, 2017.
  1. Jan 20, 2017 at 8:05 PM
    Croth51
    Croth51 [OP] Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Is thisScreenshot_2017-01-20-20-02-13.jpg compatible with a 1st gen tacoma?
  2. Jan 20, 2017 at 8:15 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    For that price why not just get one made for a tacoma??
  3. Jan 20, 2017 at 8:26 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    $1000 lt kits new? Where???
    Croth51[OP] likes this.
  4. Jan 20, 2017 at 10:10 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i don't think it will work... the tacoma and 4runner are interchangeable on a lot of stuff, but i don't think the geometry is the same between taco and tundy...
  5. Jan 21, 2017 at 6:57 AM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    Buy it and start welding it on !!!!!
    Let's find out if it works after we're in the dunes!!
  6. Jan 21, 2017 at 8:47 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That looks like a nice pile of parts. Well organized and clean, and mostly likely complete. Does the chainsaw and nest of extension cords come with it?
    And no, I'm pretty sure they are not compatible - completely different trucks with different drivetrains, etc...
    Personally, anyone who can't be bothered to even set out the parts they're selling so you can actually see them without a bunch of shit piled on top, doesn't deserve my money.
    But I guess if you want do do a shit ton of cutting and fabrication, anything is possible.
  7. Jan 21, 2017 at 8:55 AM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    I wouldn't want to do anything to it... I'm too lazy. Would be for my buddies rig. Already got my LT kit on my truck...
  8. Jan 21, 2017 at 8:57 AM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Ive heard 1st gen taco 3rd gen 4runners and 1st gen tundra are the same.... Should I find out?
  9. Jan 21, 2017 at 9:03 AM
    jbrandt
    Justin
    You could do a part number search at a parts store like rockauto.com or something, but I'm pretty sure they'd be different, and you likely need to do a bunch of fab for all the other components, too. As someone else said, for that price you could probably find an lt kit made for a taco
  10. Jan 21, 2017 at 9:04 AM
    devinzz1
    devin
    95 extended cab sr5
    actually the drivetrains are very similar. Ive always thought the suspension was too. I believe they even use same spindle and balljoints but control arms have different part numbers and looks like the bump pads are bigger. I wouldnt be suprised if they bolted up though.
  11. Jan 21, 2017 at 9:08 AM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    Let me do some research
  12. Jan 21, 2017 at 9:09 AM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    I'm looking and see the differences... Bump pads are huge... I winder if that's for weight?
  13. Jan 21, 2017 at 9:11 AM
    Croth51
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    They in fact use the same spindle...
  14. Jan 21, 2017 at 9:11 AM
    jbrandt
    Justin
    They have a similar design for sure (it's a great design!), but the size is almost certainly different. like I said, I'm sure you could make it work, but the amount of fab you might need just to get it to fit might not be worth it.
  15. Jan 21, 2017 at 9:27 AM
    devinzz1
    devin
    95 extended cab sr5
    reading through this it would seem possible to fit with use of tacoma bushings and a little modification
