is this dealer bs or is it true
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DBTaco, Jan 3, 2013.
  1. Jan 3, 2013 at 4:48 AM
    DBTaco
    DBTaco [OP] Well-Known Member
    NC
    '08 4x4 TRD off road
    I bought my truck about 3 weeks ago and it only came with one key so yday after work I went to the local Toyota dealer and gave him my vin number and he looked in the computer and said he couldn't find a replacement remote for my truck. He said your truck must didn't come with one. I was like really? So I left and came home and called another dealer about 20 miles away and he said he showed one but didn't know if I have the module or whatever already installed and I would need for a technician to look at it. He also said some Tacoma's didn't come with one. Does anyone know if this is BS or is it poor dealerships? I had keyless entry on my 05 silverado HD ls trim. Why wouldn't a 08 Tacoma sr5 Trd off road be stock with keyless entry?
  2. Jan 3, 2013 at 4:52 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Columbia, SC
    2015 DCSB 4x4 trd offroad
    Ome 885, dakars, lr uca, bed bars sos sliders
    did you buy it new or used?
  3. Jan 3, 2013 at 4:53 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2017 trd off-road dcsb
    my 05 trd offroad had the remote, should be part of the sr5 convenient package.
  4. Jan 3, 2013 at 4:54 AM
    DBTaco
    NC
    Used from a Chevrolet dealership. They only had one key to give me.
  5. Jan 3, 2013 at 4:56 AM
    diesel30
    diesel30 Well-Known Member
    columbus ohio
    2011 dbl cab long bed trd sport 4x4 mag gray
    carbon fiber blacked out grill ddm tuning hid kit 35w/55w bi-xenon kit ddm tuning hid fog light kit 35w m/t classic lock blacks fierce attitudes 285/70/17 5100's installed on front 2.5" rear TSB done masterlock tailgate lock 35% front window tint scangaugeII duplicolor red caliper paint
    it came with one. you should be able to go to any toyota dealer and order one if not in stock, would be surprised if they don't have them in stock since it's the same remote all the way up to 2012's if not the 13's too. then they just have to program it. they were probably just trying to cover their butts in case you had a base truck that didn't come with one from the factory.
  6. Jan 3, 2013 at 5:06 AM
    DBTaco
    NC
    Wouldn't the vin number tell them exactly which model Tacoma I have? Does anyone know where the factory module is? I've got some kind of aftermarket remote start or keyless entry BC of a remote antenna double sided taped to my windshield. Just would prefer a factory remote
  7. Jan 3, 2013 at 5:13 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like some aftermarket crap. I would not want some shit stuck to my window...
  8. Jan 3, 2013 at 5:15 AM
    diesel30
    columbus ohio
    you would think the vin would decode it. all trd's come with them. sounds like you got a parts guy that isn't that smart or is just lazy and didn't look it up at all or he's both. i'd probably try to find a different dealer.
  9. Jan 3, 2013 at 5:29 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Your truck came with keyless entry from the factory. Get a fob off Ebay and there is a process to program it to your truck. Your Owner's Manual should tell you how to reprogram a keyless entry fob or search this site for instructions.
    I would be a little concerned with whatever aftermarket alarm or keyless entry system was installed. On past vehicles my parents have owned, when an aftermarket alarm or remote start was installed, you could no longer use the factory remotes, you needed to use the ones that came with the kit.
  10. Jan 3, 2013 at 5:35 AM
    Dark_Taco
    Dark_Taco ΜΟΛΩΝ ΛΑΒΕ
    08' TRD Rugged Trail Edition
    This is what I would try......fuck messing with the dealer.
    ebay Key FOB
    1. Start with the key out of the ignition, drivers door is open all others closed and
    drivers door is unlocked.
    2. Perform these steps within 5 seconds.
    A. Insert the key into the ignition(Do NOT Turn) Pull key out.
    B. Insert the key into the ignition(Do NOT Turn) Pull key out.
    3. Perform these steps within 40 seconds.
    A. Close then open the drivers door.
    B. Close then open the drivers door.
    C. Insert the key into the ignition(Do NOT Turn) Pull key out.
    4. Perform these steps within 40 seconds.
    C. Insert the key into ignition and leave it in ignition.
    D. Close the drivers door.
    E. Turn the ignition to ON (Do NOT Start) then back to OFF.
    F. Remove the key from the ignition.
    5. Within 3 seconds, the power door locks should lock then unlock automatically
    indicating successful entry into programming mode.
    Return to step 1 if the locks do not cycle at this point.
    6. Perform these steps within 40 seconds.
    A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
    B. Immediately after letting go of the lock and unlock buttons,
    Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
    locks should lock and then unlock once indicating successful programming. If
    the door locks cycle twice, repeat steps A and B in step 6 as the remote was
    not accepted.
    C. Repeat steps A and B in step 6 for each new remote.
    7. Open drivers door.
  11. Jan 3, 2013 at 5:38 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    The VIN will decode and tell the parts person exactly what you have from the factory. It will not however show anything that was a "dealer" option.
  12. Jan 3, 2013 at 5:40 AM
    DBTaco
    NC
    How or who would probably need to take the aftermarket crap out? I'm sure they had to disconnect some wires and attach to another wire from the kit.
  13. Jan 3, 2013 at 5:48 AM
    Pugga
    Massachusetts
    F-150 Mod
    To be honest, I have no idea because it really depends on what it is. The fobs are cheap enough, I'd get an OEM fob, go through the process of programming it to your truck and see if it works. If what you have is in fact a remote start system, it will be tied into your ignition, your door locks and who knows what else. To remove it not knowing how it was wired could cause more problems than it's worth.
  14. Jan 3, 2013 at 5:56 AM
    bigperm34
    bigperm34 New Member
    missouri
    02 s runner
    I have an 02 tacoma with the sr5 package and I was told the same thing when I went to the dealership. It didn't make sense to me why it wouldn't with auto locks already.
  15. Jan 3, 2013 at 6:25 AM
    oldstick
    oldstick Middle Age Member
    GA
    "Take the aftermarket crap out..." ????
    You are probably going to get banned for uttering those words on here.
    :D
  16. Jan 3, 2013 at 6:30 AM
    Pugga
    Massachusetts
    F-150 Mod
    Not if the aftermarket stuff is crap. Nothing wrong with keeping a nice, stock looking Tacoma :thumbsup:
  17. Jan 3, 2013 at 6:34 AM
    DBTaco
    NC
    Not all aftermarket stuff is crap. I just don't understand why the previous owner took the factory keyless out and replaced it. That's why I said this aftermarket is crap
  18. Jan 3, 2013 at 6:39 AM
    goufcustom
    goufcustom 7.62x63mm
    MD
    2006 4x4 TRD Off Road DC SR5
    Bed Topper, Diff Breather, aFe Cold Air Intake, Satoshi Grill, Moved Horns, Oil Catch Can, Tailgate Lock, Husky Mud Flaps, H4 65/70W Bulbs, Lower Grill Mesh, TRD Skid Plate, LEDs in the bed, LEDs behind the grill for accent lighting, Parking lights as turn signals, LED turn signals and reverse lights, 5100s up front, eibachs up front, SS extended brake lines all around, 1.5" AAL in the rear, Relentless Fab U-Bolt Flip Kit, ICON Progressive AAL, TRD Wheel Center Caps, HomeLink, Heated Driver Seat, Hella 500 FF Driving Lights, BAMF Diff Skid, BAMF LCA Skids, BAMF Rock Sliders w/ KickOut.
    That is why, I got mine used from a Hyundai dealership, and it came with one key, and one remote, and no keys for the hard topper. I had to get another key made (by Toyota) for $100+ and the remote I got off eBay. ANd the hard topper manufacturer let me order new keys, since I had the serial number and lock/tumbler number. Sucked, but I got a killer deal on my truck, so it wasnt too much to deal with.
  19. Jan 3, 2013 at 6:44 AM
    oldstick
    GA
    I was just joking around about some of nice vehicle mods that get advertised and pictured heavily on this site.
    :D:D
  20. Jan 3, 2013 at 6:48 AM
    DBTaco
    NC
    I didn't take it personal, I want to put certain aftermarket items on my truck as time and money allows.
