is this harbor freight spring compressor suicide?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aficianado, Mar 8, 2010.
  1. Jul 4, 2011 at 3:53 PM
    #41
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
  2. Jun 12, 2018 at 8:38 AM
    #42
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I just re-valved my shocks and what a pain using the old school spring compressor and marked up the lower threads on the shock...
    If I have to make another adjustment I getting something like this...
  3. Jun 12, 2018 at 8:51 AM
    #43
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Many tools at harbor freight are indeed junk, however to say that they all will break after one use is rubbish. I've used their sockets, screwdrivers, ratchets and ratcheting box wrenches and various other things 3-5 days a week heavy use for the last 5 years at work and I've only suffered one loss (ratcheting box end came apart). You have to look closely at what your buying there is all.
    But back on topic, in the end I think its easier to pay a shop 20-50 bucks to compress your shocks for you and replace what you need to replace. I've used my local pep boys for this for some time and they've even done it for free before.
    4RunninInATacoWorld likes this.
  4. Jun 12, 2018 at 9:14 AM
    #44
    AaronNY
    AaronNY Well-Known Member
    Syracuse NY
    2011 MGM 4x4
    Bilstien 5100s Hella 500s and 700s
    I have the Napa/everlast spring compressors. I think they were 60$, but if you have an AAA membership you will get 10% off. I've used them probably 3 times now for my audi, 4runner and tacoma.
  5. Jun 12, 2018 at 9:24 AM
    #45
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    You know, you can also just use your truck as the spring compressor - do all your other steps for pulling the shock assembly out, except instead of removing the three strut mount nuts, put a jack under the LCA, put a little pressure on it, remove just the shock nut (and leave the strut mount bolted in), then slowly lower the jack to un-compress/unassemble it. Then do the opposite to reassemble. Quick, easy, and safer than using a sketchy spring compressor (unless you have access to a legit hydraulic one). Have done this numerous times.
    **Edit mwc273 beat me to it while I writing up my post
    mwc273 likes this.
  6. Jun 12, 2018 at 9:27 AM
    #46
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Related topic - I need to replace the struts on my stock 2010. Since they aren't horribly expensive, why shouldn't I buy the complete assembly already put together. Just unbolt and bolt the new ones in. Less hassle but more money (but not that much if you have to buy a spring compressor). Tell me why that's not a bad idea, please.
  7. Jun 12, 2018 at 9:35 AM
    #47
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
  8. Jun 12, 2018 at 9:41 AM
    #48
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
  9. Jun 12, 2018 at 1:27 PM
    #49
    shr133
    Muskego, WI
    2010 V6 Sport
    Only works for stock type shocks like OME, Bilsteins ect...
    MolonLabeTaco[QUOTED] likes this.
  10. Jun 12, 2018 at 2:10 PM
    #50
    DougSD
    DougSD Well-Known Member
    Doug
    San Diego, CA
    2015 TRD Tacoma
    Icon front 2.5 Coilovers, Fox 2.0 rear shocks, Hankook A/T tires
    I used their other style they had (black ones) worked perfect from the 5100 install.. was worried but they held up just fine
  11. Jun 12, 2018 at 2:14 PM
    #51
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Consider having the coils installed on the shock by your vendor.
  12. Jul 24, 2018 at 6:19 PM
    #52
    Pyritemica15
    Pyritemica15 Well-Known Member
    Norm
    2015 Pyrite Mica Tacoma double cab
    i had a local garage install my OME 885 on my 5100's for $50,took them 1/2 hour,i wouldn't waste my money on a cheap tool.
  13. Jul 25, 2018 at 7:55 AM
    #53
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    I installed my 5100s without a spring compressor. I just lined up all the parts how I wanted them, put the lower bolt in with the nut just finger tight, and ever so slowly used my floor jack to push the LCA up and the whole assembly went right into place. I threaded the top nut on the shock and tightened everything down, let pressure off the jack and retorqued all the parts, threw my wheels back on and got it aligned. The rears gave me more of a fight than the front, they were so rusted I ended up cutting the end of the shock arm off, straight through the nut and everything. Had everything on for a few thousand miles so far and no problems whatsoever.
  14. Jul 25, 2018 at 12:40 PM
    #54
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I use harbor freight on occasion, but I wouldnt touch that compressor with a 10ft stick. Some things you just dont cheap out on... My 2 cents...
  15. Jul 25, 2018 at 1:57 PM
    #55
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    I buy stuff from HF too, but I have a rule: don't buy anything that, if it fails, can kill you.
    MolonLabeTaco likes this.
