Is this install method correct
Discussion in 'Suspension' started by iTz IAN, Jan 8, 2013.
  1. Jan 8, 2013 at 8:50 PM
    iTz IAN
    iTz IAN [OP] Well-Known Member
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
  2. Jan 8, 2013 at 9:01 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It works, but heed the warning at the beginning of the video.
    It is VERY risky... the energy in the spring can kill you.
    One of the problems people encounter is that the LCA won't drop enough, and the bushing bolts are frozen.
    But an alignment will be needed anyways, so the frozen bolts need to be freed.
    Soak all of the bolts in penetrating oil, then repeat every day for a week and hopefully it will be painless.
  3. Jan 8, 2013 at 9:01 PM
    SkeeterBilt
    SkeeterBilt Zombie
    Skeeter
    Sierra Vista, AZ
    07 Prerunner DC LB TRD Zombie Response Team
    Black Satoshi Grill, Blacked Out Head Lights & Fog lights, Tint, Vent Visors, Shaved Emblems, Oil Catch Can, Ipod Hookup to Stock Head Unit, Sony Speakers, TRD Seat Covers, Xtra D-Rings and Other Small Things.... Lift and more to come
    hmmmm... this might get interesting
  4. Jan 8, 2013 at 9:03 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I'm a technican, and you will never ever catch me doing that. ever. i like my face.
  5. Jan 8, 2013 at 9:07 PM
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    Spooky:notsure:
    Could go bad. If you dont have the tools, pay someone who does. Those springs are tough.:violent:
  6. Jan 8, 2013 at 9:11 PM
    iTz IAN
    Ian
    Santa Barbara,CA
    4x4 TRD FTW
    what is good price for just installing the springs
    also some shops said that the rental spring compressor will work others say only a wall mounted one will????
  7. Jan 8, 2013 at 9:15 PM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    The rental ones will work well for taking it apart it took me and a buddy to get the eibach springs compressed enough to get it back together.
  8. Jan 8, 2013 at 9:21 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    that sketchy wow
  9. Jan 8, 2013 at 9:26 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  10. Jan 8, 2013 at 9:36 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Post up in the San Diego BS thread. I'm sure some of the local guys will be able to help you out. I know Jason (speed freek) works out of his home garage, not sure if he's got a spring compressor, but he might be able to help you out.
  11. Jan 8, 2013 at 9:39 PM
    SkeeterBilt
    SkeeterBilt Zombie
    Skeeter
    Sierra Vista, AZ
    have one of those "cheap" spring compressors like they show.. they work well if you take your time and be carefull. now ive never installed a lift spring with it, only drop springs.
  12. Jan 8, 2013 at 9:44 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    I've done a version of this method numerous times on different tacomas and a couple tundras. Easy, smooth, and felt much more safe than using those cheap spring compressors.
    Safest way to do it is take your coils and have a shop do it. Whichever method you do, be careful and attempt at your own risk.
  13. Jan 8, 2013 at 9:50 PM
    Walker
    Walker Well-Known Member
    Walker
    Weippe, Idaho
    10 Trd OffRoad
    3" procomp, Light Racing UCA's
    I have done it this way and with the "cheap" spring compressors and i would much rather do it this way. This way is much faster and i feel safer than i do with the "cheap" compressor. The shock shaft would keep it from flying out and i cant even see that happening, it worked very smooth for me. With anything like this take your time.
