Is this normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tntacoma, Dec 27, 2009.
  1. Dec 27, 2009 at 10:59 AM
    tntacoma
    tntacoma [OP] Well-Known Member
    tn
    I have had a whirring sound that winds up and down with acceleration. I originally had thought it was my tires that were wore out. So go get some new tires, and its still there. I crawled up underneath to look around and this is what I found. Is this a sign of the u-joint failing? 2007 DC w/44000 miles. Tell me what you guys think. See the spray ring? That is what I am questioning if it is normal.
    [​IMG][​IMG]
  2. Dec 27, 2009 at 11:00 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    just see red x's
  3. Dec 27, 2009 at 11:00 AM
    Brunes
    Brunes abides.
    Rotorhead
    Photos no workie....
  4. Dec 27, 2009 at 11:09 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Well, have you greased them since the noise has started? it could be from over greasing them. If you grab the driveshaft and try to twist it, how much play does it have?
  5. Dec 27, 2009 at 11:15 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    looks normal, any free play in the shaft?
  6. Dec 27, 2009 at 11:18 AM
    tntacoma
    tn
    No I have not greased it. No real play, that's why I am not sure if this is my problem. The sound is almost the "grrrrr" sound that you would have from mud terrains. you can feel it as a slight vibration in the gas pedal at speed, and not so much in neutral coasting, but it is still there? Driving me crazy!
  7. Dec 27, 2009 at 11:20 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    any fluid leaking from the rear tranny seal? can you move the shaft up and down any?
  8. Dec 27, 2009 at 11:30 AM
    tntacoma
    tn
    No fluid leaking and no movement, I think my problem may be else where, still looking.
  9. Dec 27, 2009 at 11:33 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    cant be your engine can it? mine kinda whines especially if its cold and the radio isnt on
  10. Dec 27, 2009 at 11:36 AM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Alright, I hate to ask the stupid question. Where exactly is the problem in that picture? I see no issues.
  11. Dec 27, 2009 at 11:40 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    i dont believe it is one, but hes refering to the grease splatter on the body
  12. Dec 27, 2009 at 11:41 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    I read somewhere on here that some people with the same year trucks as us are experiencing this problem but that it is attributed to plastic vibrating against the bed. So the faster you go the more you hear it and as you slow down the sound/vibration goes away. Not sure why you would feel it in your gas pedal though. You mentioned that your tires are worn out..maybe a balance issue not sure.
    just read this check it out
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/66616-toyota-cant-fix-my-truck.html
  13. Dec 27, 2009 at 11:55 AM
    jr114
    Jon
    SoCal
    Truck
  14. Dec 28, 2009 at 12:59 AM
    tntacoma
    tn
    Thanks for all the input, I could not find the plastic vibrating that you were referring to. I replaced the tires when I first noticed this vibration. I thought that might have been the problem. Still there with the new tires. I went to the movies last night seen avatar,( great movie) and on the way there and way home, no radio and was trying to listen. the wife thinks I am crazy. The plastic or maybe plastic bed vibrating against the frame kinda made sense, but I can not find any place that it would be doing it. so I am still on my quest to fix, and find it and show my wife that I am not crazy.
  15. Dec 28, 2009 at 1:01 AM
    tntacoma
    tn
    no stupid question, I was referring to the grease splatter around the u-joint thinking something may have worked lose and causing my vibration. I think all is normal with my u-joint. No, play or anything that I can find with it.
  16. Dec 28, 2009 at 1:04 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i def think its the joint. that is way too much grease and it looks fairly fresh. they are really cheap and easy to replace and its a good place to start. what i noticed was you said its smooth when coasting but when on the gas it vibes? deff a sign of a bad ujoint...my .02
  17. Dec 28, 2009 at 1:09 AM
    Yoytoda
    Roland
    completely stock
    a way to check is to grease it more and see if the vibe goes away. Alot of times the trucks are so refined that you cant feel play by hand but you can feel vibes when the driveshaft is spinning a couple thousand rpms because the truck is normally so smooth. In my 79 chevy the drive shaft would have to be hanging off the truck before you feel any vibe lol
  18. Dec 28, 2009 at 1:09 AM
    tntacoma
    tn
    Thanks, I was gonna start there just to make sure. No real other solutions so far that I can really see. I figure its not gonna hurt to change it and like you said, not real expensive.
