Is this rust anything to worry about?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dangorah, Sep 13, 2017.
  1. Sep 13, 2017 at 12:13 PM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    Looks fine. If you're worried about it, spray some fluid film on it. But even if it were bad, you could always replace control arms. What is a little harder to replace is the frame. I'd check the frame in the back, especially the leafspring/shackle hangers. Those areas rust more often.
  2. Sep 13, 2017 at 12:15 PM
    Dangorah
    Dangorah [OP] Well-Known Member
    Dallas, TX
    But I just got this one! lol
    paid cash too so its not as much of a burden on the wallet... Well that may not be the case anymore seeing as I am obsessing over little upgrades and such. :D
    scottalot[QUOTED] likes this.
  3. Sep 13, 2017 at 12:16 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    no matter what you do, apply some fluid film, as it will prevent rust from coming back. Will prevent it more than just paint
    treating it with opsho will remove rust, but it will come back if the metal isn't protected against rust by paint and grease
    2002Tacoma4x4 likes this.
  4. Sep 13, 2017 at 12:16 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  5. Sep 13, 2017 at 8:59 PM
    Dangorah
    Dallas, TX
    After reading a huge thread about POR 15 I really want to.go that route but it seems like a huge job. I think I'll remove surface rust then use the fluid film for now. Maybe after that has settled for a bit I'll go over it with POR 15 to make it look nice. I really want to to do the skid plates with POR15 at the minimum. Then work on the frame. I worry about getting in all the nooks and crannies as well as all the seams between connected components. That is something I have not thought about in much detail.
    For example, upper control arms and ball joints. Does this POR15 go on threads, will it cause binding issues? What about bushings/rubber parts? I assume that doesn't need it but what happens if it comes in contact with this stuff? I also don't have the resources to remove the frame and coat it so the top of the frame probably won't get completely covered.
    I'm just being meticulous, but I want to be sure I do it as well as possible!
  6. Sep 14, 2017 at 2:19 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I really think you need to check the section of frame around the spring hangers
    Then if you live anyplace where you see Winter (Snow Ice) Liquid brine is brutal!!
    Despite fresh paint every fall till spring the liquid brine rusts everything.
  7. Sep 14, 2017 at 5:59 AM
    Dangorah
    Dallas, TX
    Sorry I forgot to update y'all with the info about the rear of the truck. Everything back there is fine it might even have less surface rust. The truck is originally from Alaska, but has been in Texas most of it's life including the time it will be in my possession.
  8. Sep 14, 2017 at 6:04 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Cannot paint over Fluid Film. You would apply FF over the cured Por15 if you went that route.
    Ospho you would almost need to paint over it as it is just a rust convertor.
    I think you could brush, Ospho, Paint, then FF if you were really into it lol.
  9. Sep 14, 2017 at 7:10 AM
    tony2018
    tony2018 Well-Known Member
    In bold, is what I would do.
  10. Sep 14, 2017 at 9:08 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I was in the same boat. I only had a little surface rust that I wanted to get rid of. To properly do POR15 it would be easier to just take the bed off, wheels bla bla . I thought - how much time do I want to put into my late 90's pickup? I wire brushed and sanded off all the loose crap. I bought some Chassis saver and it's been on there for some years. It's not top of the line but I can attest that it works when applied properly. It's very messy and sticky. Humidity activates it. It will not allow the rust to form as it starves it of oxygen. I saw some video of Ted Nugents Bronco and using chassis saver. Might give it a try. It takes some time but it's worth it I think.
  11. Sep 14, 2017 at 10:02 AM
    Dangorah
    Dallas, TX
    I think I'm going with wire brush, then POR15 and will yearly maintain with Fluid Film.
    iwashmycar likes this.
  12. Sep 14, 2017 at 12:16 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Unless your Surf fishing or boating through Salt Water marsh you should be fine .
    Although doing more can never hurt .
  13. Sep 19, 2017 at 10:07 AM
    Dangorah
    Dallas, TX
    Update: I'm about halfway through with the prep process. Should have everything coated using the POR15 3 step process before next week hopefully.
  14. Sep 19, 2017 at 11:00 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    I would spray the entire frame with gasoline or something similarly volatile and flammable and then throw a match on it.
    cruxofthebisquit and lynyrd3 like this.
  15. Sep 19, 2017 at 11:06 AM
    #35
    vtwinjunkie
    vtwinjunkie Well-Known Member
    2005 TRD Sport
    Bilstein 5100's, 885 coils, Dakar Leafs, SPC LR UCA's, 275-70-17
    Thanks!
    Douche bag.
    ChemDawg, rzgkane[QUOTED] and lynyrd3 like this.
  16. Sep 19, 2017 at 6:42 PM
    #36
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    atleast this is an easily repaired part of the frame with bed off. i probably wouldn't use the tow hitch as is
  17. Sep 20, 2017 at 6:41 AM
    #37
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Start with eastwood rust converter then
    I used chassis saver, apply with sponge brush on top of frame and hard to reach areas, also eastwood internal frame paint before of painting the outside frame, buch of pictures before and after at my media album
    Xbeaus[QUOTED] and opteron like this.
  18. Sep 20, 2017 at 7:01 AM
    #38
    vtwinjunkie
    2005 TRD Sport
    Yea I am going to need to get it taken care of at some point..I definitely dont plan on any towing until I get it taken care of for sure
    Thanks dude. I will check it out
  19. Sep 20, 2017 at 7:36 AM
    #39
    lynyrd3
    Bill
    East Central Upstate NY
    I think phosphoric acid is in Coke a Cola ! :confused: :eek::D
  20. Sep 20, 2017 at 11:11 AM
    #40
    rzgkane
    Just funnin'.
    vtwinjunkie[QUOTED] likes this.
