Is this Sway bar shot?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ztwatson, Jan 19, 2022.
  1. Jan 20, 2022 at 11:22 AM
    ztwatson
    ztwatson [OP] Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Thanks for pointing that out. I will look into those as well.
  2. Jan 21, 2022 at 4:53 AM
    skeezix
    skeezix Ol' Geezer
    Western Slope of Colorado
    1998 Limited
    >>Can you point out the part of the steering rack you mentioned? Not sure where you are looking<<
    If you're talking about the leak, in the first photo there is a dried-up oil spot on the rack just above (and in the photo, touching) the sway bar.
    I would remove the sway bar and give it a thorough scraping/cleaning. Then decide if it's still good.
  3. Jan 21, 2022 at 6:59 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    From the looks of the mounting brackets & bolts, it may take a grinder to do so. Those nuts and/or bolts don't appear to be easily removable.
