Is this the LSD that I need?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nemesis17592, Jan 9, 2019.
  1. Jan 9, 2019 at 5:45 AM
    nemesis17592
    nemesis17592 [OP] Well-Known Member
    Nate
    Comstock Park, MI
    2010 Tacoma DC LB SR5 4x4
  2. Jan 9, 2019 at 5:51 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    2015 sporty dcsb 4wd
    Lifted, armored, lumenz w/ switches, positraked, long legged, big tars, debadged with a hood skewp
    Yes thats the correct part#, I have the same one installed on mine. If you wanna save some money you can order it on ebay during a sale an save about 100$. But it works absolutely great on our trucks.
  3. Jan 9, 2019 at 6:04 AM
    nemesis17592
    Nate
    Comstock Park, MI
    Thank you! Did you install yours?
    MattCowsmasher likes this.
  4. Jan 9, 2019 at 6:07 AM
    MattCowsmasher
    Temple, Tx
    Had a local member who's way more knowledgable than myself but watched it. Took him about 3 hours total.
  5. Jan 9, 2019 at 11:01 AM
    71RAT
    71RAT Member
    2010 Tacoma Access Cab TRD Offf Road Silver
    2" lift
    I've installed many Eaton Truetrac's in differant vehicles. They seem to be a quality unit, smooth operation. All the customers have been happy. If you are hardcore offroader you my want to consider a locker, air, electric, or mechanical.
    SR-71A likes this.
  6. Jan 9, 2019 at 11:24 AM
    nemesis17592
    Nate
    Comstock Park, MI
    I am not a serious offroader. Just wanted something more than Auto LSD with an open diff. When you installed them, were you working at a shop or just out of your garage? Any idea what a typical labor quote would be for that?
  7. Jan 9, 2019 at 11:46 AM
    BassAckwards
    Robert
    TX
    '09 I4 5spd & '13 V6 6spd
    Another vote for the trutrac. Have one in my truck as well. You wont regret it
  8. Jan 9, 2019 at 11:53 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    For those that have them what exactly are they good for in our trucks that auto LSD can't do? I have a Torsen unit in my 91 Camaro and that's nice for not leaving one leggers anytime I give it more than 25% throttle off the line but I can't imagine the need in a truck that couldn't burn rubber if its life depended on it.
  9. Jan 9, 2019 at 12:04 PM
    nemesis17592
    Nate
    Comstock Park, MI
    Well The Auto LSD is fine for mild slow off-roading and it sort of works the way a normal LSD works. But the fact that brakes are used for Auto LSD, makes the system very inconsistent and hard to judge. The auto LSD also requires the SCS system to be on. Sometimes It works the way you want, sometimes it will beep and the brakes will pulse, and sometimes it doesn’t seem to do anything at all. In Michigan, most of our trails and off road areas are very sandy. When you are trying to get up and go in the sand or loose dirt, it’s nice to have a dependable mechanical LSD that wont kick on your Stability control if the truck begins to slide a little sideways. The truck isn’t for burnouts, however, the occasional donut in the rain is not possible with Auto LSD…
  10. Jan 9, 2019 at 12:14 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 300+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    That is a shame.
    nemesis17592 [OP] likes this.
  11. Jan 9, 2019 at 12:20 PM
    nemesis17592
    Nate
    Comstock Park, MI
    Agreed. My old Ranger FX4 could do smokey donuts on dry pavement, no problem. It had an LSD.
    MattCowsmasher and Larzzzz like this.
  12. Jan 9, 2019 at 12:21 PM
    pabstsmeared
    pabstsmeared Simulated Weight
    Tappahannock, Va
    '13 Super White DCSB TX Baja
    Mud Tars & Shit
    Oh, different LSD. Nevermind.....
  13. Jan 9, 2019 at 12:23 PM
    Larzzzz
    Larry
    MA
    Off to see Timothy Leary...?
    Edit: now I have The Moody blues stuck in my head. LOL
  14. Jan 9, 2019 at 1:05 PM
    Master Z
    Master Z Well-Known Member
    2010 Tacoma 4.0L AC SR5 Prerunner BSP
    Peachy Peach Little Tree Air Freshener
    So let me get this right.
    If you do install an LSD on a truck with an open diff and Auto LSD, the Auto LSD function is now obsolete right?
    You cant use Auto LSD in conjunction with a mechanical LSD, correct? So that button would now just be Traction control on/off(hold 3 sec).
  15. Jan 9, 2019 at 1:43 PM
    nemesis17592
    Nate
    Comstock Park, MI
    Correct. Just the 3sec hold for real LSD and SCS off.
  16. Jan 9, 2019 at 6:03 PM
    Halligan
    Halligan Old School
    Cam
    BC Canada
    2015 DCSB Gearjammer
    OME 887s, OME Dakar Heavys, 265/70/17's, Truetrac, 6sp manual
    Truetrac is an awesome upgrade. No downside.
    Don't be scared of the install, it's not too hard. No need to mess with pinion stuff, just swap the ring gear to the Truetrac, press on some new bearings and reinstall carrier caps and shims. Mine needed nothing, backlash stayed the same and I was happy with the preload. Use a dial gauge to check backlash after install and use quality carrier bearings. Remember to loctite the ring gear bolts. Torque everything to spec. I used an oem gasket for the 3rd and some "Right stuff" gasket maker. I love that stuff, it is the best I've seen. No special LSD additive needed.
    I installed mine in my garage. No worries.
  17. Jan 10, 2019 at 4:27 AM
    71RAT
    71RAT Member
    2" lift
    I'm the rebuilder at a moderate size transmission shop, also do all the ring and pinion setups. Don't do billing or deal with customers, be happy to check tor you. Don't know how much labor rates very.
