Is this the right differential fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silence9, Jul 7, 2014.
  1. Jul 7, 2014 at 3:21 PM
    Silence9
    Silence9 [OP] Solve et Coagula
    Alberta, Canada
    Hey guys and gals. Long time no activity for me. I'm at the automotive store and I'm wondering if this is the correct fluid for my rear differential. It's called extreme pressure year oil 80w-90. It's my first time changing it and I don't want to put the wrong stuff in. Thanks!!
  2. Jul 7, 2014 at 5:55 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
  3. Jul 7, 2014 at 5:58 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Do you have the LSD rear?
    If you have the LSD rear diff (limited slip differental) look for LSD sticker on your rear
    You need to add friction modifier.
    I use motorcraft 80w-90 oil along with one small 4oz. bottle of motorcraft friction modifier
  4. Jul 7, 2014 at 7:21 PM
    Silence9
    Alberta, Canada
    No Sport model / LSD for me, so I don't need the modifier, correct? Thanks.
  5. Jul 7, 2014 at 7:22 PM
    Silence9
    Alberta, Canada
    There was sludge on the magnet with some filings in it. Glad I changed it!
  6. Jul 7, 2014 at 7:33 PM
    blazze2005
    South Jersey
    No your good! How many miles were on the fluid?
  7. Jul 7, 2014 at 7:45 PM
    Silence9
    Alberta, Canada
    29,000. I think it's a bit below what they call for, but she's breaking in so I figured it can't hurt.
  8. Jul 7, 2014 at 8:06 PM
    Silence9
    Alberta, Canada
    Does it make a difference if I drive a few miles then add more? I filled it until it came pouring out the fill hole. It should be good right?
    Edit: is the stock oil 75w? Call me crazy but it seems a touch slower after the change with 80w.
  9. Jul 7, 2014 at 8:08 PM
    blazze2005
    South Jersey
    I did mine at 30,000 also...wasn't to bad, but like you I'm gonna keep it at 30,000 intervals
    My 05 only has 53,000 on it.
    Don't let your power steering fluid go too long. I did mine over the week end at 53,000
    Wish I did it at about 40,000
    The power steering rezzy started to collect debri on its insides
    Used valvoline dex/merc atf fluid
    All went well with the full flush, Nice and smooth...no problems with air
  10. Jul 7, 2014 at 8:19 PM
    Silence9
    Alberta, Canada
    Thanks for the tip about the PS, I'll keep my eye on it! No sense putting extra strain on the pump right?
  11. Jul 7, 2014 at 8:30 PM
    Jeffaz1
    Jeffaz1 Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    The way I understand it, you don't need the additive if you have a 2009 and newer because the LSD is electronic.
  12. Jul 7, 2014 at 8:36 PM
    blazze2005
    South Jersey
    Power steering fluid is the most ignored fluid in vehicles
    Better to get it out before it starts to break down
    Every 40,000 is fine
    Here is the video I used to flush mine http://youtu.be/Jg9Yjt__KHw
    Its exactly the same for the tacoma,accept you don't have to move the coolant jug
    Purchase 7ft. Of clear 3/8" inner diameter hose along with a brass 3/8" hose adapter
    Also see that short piece of tubing he puts on the rezzy. Put a bolt in the end of it so no fluid escapes.
    Purchase 2 quarts of dex/merc atf fluid
  13. Jul 8, 2014 at 6:05 PM
    Silence9
    Alberta, Canada
    Thanks again!
  14. Jul 9, 2014 at 3:09 PM
    jackbower6864
    jackbower6864 Member
  15. Jul 9, 2014 at 7:43 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    i have a prerunner with the real LSD i use castrol 80w-90 made for LSD differencials with addative in it. so far so good, but if other members have bad experience using it PLEASE let me know!
