Is this trailer pushing the tacoma's limits?
Discussion in 'Towing' started by boognish, Jan 17, 2014.
  1. Jan 17, 2014 at 9:52 PM
    boognish
    boognish [OP] New Member
    I'm looking at hybrid campers and have found one I am interested in. I have attached a picture of the specs below. It will be towed with a 2014 4x4 DC w/tow package. Do you think i'll be able to tow this comfortably? Thanks in advance.
  2. Jan 17, 2014 at 10:22 PM
    phiniac
    phiniac New Member
    4x4 Long Bed
    Deaver HD Springs
    You'll be fine with that camper. If the rear end sags on you, you'll probably want to get a weight distribution hitch. Keep it out of Drive and just put it in 4th gear.
  3. Jan 17, 2014 at 10:44 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    You're good.
  4. Jan 17, 2014 at 11:05 PM
    acdronin
    acdronin Well-Known Member
    Might want to consider some airbags for your truck, it will keep the rear leafs from flattening out if you plan to tow that a lot.
  5. Jan 17, 2014 at 11:17 PM
    mikebuyscars
    mikebuyscars Well-Known Member
    Holly, MI
    07 Toyota Tacoma double cab TRD
    3 inch lift
    Mine is a Jayco x18D and the posted weight is the same as yours, except by the time they finish adding accesories I am at 3700#. I pull it just fine but I do use WD hitch. Taco's are good off road trucks so they have soft rear springs. I tow in Drive as long as the engine does not lug or the trans does not hunt for gears. On flat land it locks into 5th at 65MPH. I never go past 70 though. no hurry to get there!
  6. Jan 17, 2014 at 11:24 PM
    SpecialK
    SpecialK Member
    So Cal
    '12 DCLB 4X4 Sport
    Icon UCA's, Ext Travel coil-overs, rear reservoir shocks
    You'll be fine but definitely use a weight distributing hitch with sway control. I tow a 27' ultra light trailer that weighs 4000lbs dry (it's a 2012 DCLB with the tow package). Don't think you'll need the air bags but that should be your decision.
  7. Jan 18, 2014 at 5:05 AM
    boognish
    thanks for all the quick responses, hoping I can pull a good deal on this thing.
  8. Jan 18, 2014 at 5:19 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    air bags will help tremendously... towing that trailer, I'd recommend them since the factory rear springs are weak :)
  9. Jan 18, 2014 at 5:25 AM
    dandude23
    dandude23 Active Member
    Boognish, did you used to play Americas army?
  10. Jan 18, 2014 at 5:38 AM
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    skid plates and skinny tires
    Don't forget trailer brakes. My travel trailer is about the same weight. Tows great. Had it cross country last year. I only use the load distributing hitch if I bring a lot of gear on a trip. Hope this helps.
  11. Jan 18, 2014 at 5:43 AM
    MQQSE
    MQQSE Random Member
    Rob
    Palmer, AK
    I'll throw in with Chris and Mike on the airbags. I've had mine on my truck 3 yrs now. Nice to keep things riding level for when you load both the trailer and throw additional weight in the bed.
    As someone said, your decision; they have been worthwhile in my experience. FWIW
  12. Jan 20, 2014 at 6:03 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90 2WD, '98 4WD, '12 4WD, '05 Tundra 4.7, '07 4Runner 4.7
    Comfortably? Depends. I have a 3900lb GVWR and my max is 50 mph on the steep 6%-7% grades floored in 3rd gear. I have to drop the truck into 2nd gear at times to get any acceleration around the 18-wheelers on those grades. Redline in 2nd gear is about 54 mph.
    On less steep grades it still struggles, I have to drop it into 3rd gear a lot to get any acceleration around the 18-wheelers and not hold up traffic behind me too much. I often put the 4-way blinkers on so people flying along at 80 mph behind me have some warning I'm just going along at 60 mph.
    And I get about 10-12 mpg. It's not much of a hauler, IMO. I had an Equalizer WDH with 4-way sway control and tore that thing up going offroad on some mild dirt roads. The rear factory springs are too weak even WITH the WDH. Bought some Timbren rear bumpstops and a straight rear hitch, that solved most problems, and it still does fine on the interstate, doesn't sway out of control when 18-wheelers go blasting by me (but it's a short trailer).
    I feel any vehicle passing me much more with the straight hitch, but it's not uncontrollable at all. That's my .03.
  13. Jan 20, 2014 at 9:18 PM
    dgtacoma
    dgtacoma Member
    dg
    norcal- bay area
    08 longbed pre
    debadged billet grill
    I have been pulling a small coleman tent trailer... looking to up grade to a Fleetwood evolution E2, my TV is a double cab long bed pre. wt tow package.. WT airbags... will get a Weight Distribution Hitch . trailer weights 2550 unloaded. 400 hitch weight. ( I know -high) don't really need the deck. ( I have a long bed) just really like the lay out of them.. even had a crazy idea to get my certified welder buddy to help me shorten the front deck.....OK so what to you guys think ???
  14. Feb 8, 2014 at 5:59 PM
    52motorhead
    52motorhead Well-Known Member
    You will be fine, my trailer is pushing 6000 lbs with all are gear and the truck does just fine.
