is would be ideal...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOMAN22, Apr 17, 2008.
  1. Apr 17, 2008 at 7:27 PM
    TACOMAN22
    TACOMAN22 [OP] Well-Known Member
    agoura hills
    Debadged TRD offroad, bhlm, black surround grill,
    K&N drop in air filter,flowmaster 40 series, blue interior neon, bhlm, color matched grill, alpine head unit w/ infinity reference series speakers, insane driver.....
    but i dont know if it would work. i have an access cab prerunner v6 with no suspension mods...if i got the 5100's and set them to 2.5 and added a 1/2" top plate spacer to achieve 3" would it work?
  2. Apr 17, 2008 at 8:43 PM
    TACOMAN22
    agoura hills
  3. Apr 17, 2008 at 11:15 PM
    TACOMAN22
    agoura hills
    anyone?????????????????
  4. Apr 18, 2008 at 3:19 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    You might get some answers once the sun comes up again :D
  5. Apr 18, 2008 at 4:14 AM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Nope, won't work, 5100's can be used with any kind of spacer or leveling kit. Not sure why, but it's been asked and answered in the suspension section before.
  6. Apr 18, 2008 at 5:18 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    If you want a full 3", just buy the Toytec 3" with OME coils. Its only $49 more than all four 5100s.
  7. Apr 18, 2008 at 6:34 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    its highly recomended that you not use any spacers with the 5100's unless they are set at stock height
  8. Apr 18, 2008 at 7:55 AM
    TACOMAN22
    agoura hills
    Ya but if its on top of the strut wouldn't it not affect the bilsteins? I don't know a LOT about suspension but to me since its not in the strut it really has nothing to do with the 5100's?
  9. Apr 18, 2008 at 8:24 AM
    nd
    Nate
    Greenville, SC
    i dont know why but you're not suppose to use any type of lift with the 5100's. you can do it ifyou want but you could have some problems. why not just get a 3 inch lift?
  10. Apr 19, 2008 at 12:35 PM
    TACOMAN22
    agoura hills
    well i ust heard the ride is better with the 5100's than with in-strut spacers
  11. Apr 19, 2008 at 1:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i thought the 5100's were basically for lifted trucks???
  12. Apr 19, 2008 at 7:45 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    I've understood that the 5100's are for non lifted or not more than 2". As in TSB in rear and up to the 2.5" in the front to level it out?
  13. Apr 20, 2008 at 12:15 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    they should definitely work in that case then. but the billy 5100 series are for lifted trucks....thats why there is an adjustment for the fronts...........or so i thought.
  14. Apr 20, 2008 at 6:13 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You shouldn't put spacers ontop the coil assembly because you're lowering the entire suspension which can cause your steering knuckle to come in contact with the coil assembly since the upper a-arm is sitting much lower.
    The whole point with putting spacers INSIDE the coil pak (not the 5100's) is to keep the upper A-arm in the stock location.
  15. Apr 20, 2008 at 6:14 AM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    Adjustments are generally to compensate for drooping and to maintain ride height before getting getting the shock rebuilt. 5100s are usually used to level out a TSB in the rear. If you're trying to get a 3" lift think about what you need it for and either snag a $300 spacer lift for show or go all out and piece together your off-road suspension parts. You're barking up the wrong tree right now. Adjust fire.
  16. Apr 20, 2008 at 8:00 AM
    4x4x4trd
    North Texas
    Kinda mixed on Bilsteins web sight. States they are for lifted trucks and then shows lift as 0-1" in rear and 0-2.5" in the front.
    The front is only because of the adjustable collar changing the preload of the spring, gaining lift.
    http://www.bilstein.com/offroad_5100pre.php
    On another page they show product in development for Tacoma's with lift of 4" in the rear and the same part # as above for up to 6" in the front?
    In the notes this lift is gained using spacer kits?
    http://www.bilstein.com/suvs_5100.php
  17. Jun 11, 2008 at 6:59 PM
    warchi81
    warchi81 Active Member
    So my truck is at the shop for the suspension TSB. I wished I had looked into a leveling kit before it went in, but I was too busy. So should I tell the dealer to adjust them accordingly or can I adjust them myself after the install is done? I guess I would want them to be at 2" to level right? Or would I just go the max? Any help would be great. Thanks.
  18. Jun 11, 2008 at 7:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You forgot to menthion how happy the top plate spacer makes the ball joints. :)
  19. Jun 11, 2008 at 7:23 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Tell the dealer to adjust what accordingly? The dealer is not installing 5100's, just the upgraded Bilsteins (on most) and a 4 leaf pack in lieu of the 3 leaf pack.
  20. Jun 12, 2008 at 1:41 PM
    warchi81
    Oh I got ya. Sorry I was under the impression they were the 5100's. So the toyotech leveling kit is what I should look at then ?
