Issues after getting new wheels
Discussion in 'Wheels & Tires' started by Surg03, Aug 30, 2013.
  1. Aug 30, 2013 at 8:57 PM
    Surg03
    Surg03 [OP] Active Member
    06prerunnersr5
    Purchased these wheels on Craig's list and paid a mechanic to balance and install them. My stocks were 16"/7rim with 245/75/16 tires, the ones I purchased were 16"/8 rim with 245/75/16 tires. After mechanic was done I started driving and the rear wheels wobble and front tires rub when I turn and my breaks are acting weird like a bounce or something. I would realy appreciate it if you guys can help, all I wanted was to make my 06 pre runner look better, now I have a mess! Please help!
  2. Aug 30, 2013 at 9:01 PM
    Surg03
    06prerunnersr5
    Also the front wheels had 1.25" spacer adapters since the calipers hit, don't know if that has something to do with the rear wheels wobbling.
  3. Aug 30, 2013 at 9:04 PM
    Flynbyu2
    Flynbyu2 Start every day with a smile and get it over with
    Ron
    Folsom, CA
    '10 Tacoma Sport
    There are ways you could make them work(spacers, etc...), but in the end it's not worth the risk.
    I'd eat the mounting/balancing charge, put your stock wheels back on and put the new wheels back on Craigslist.
  4. Aug 30, 2013 at 10:47 PM
    Surg03
    06prerunnersr5
    You think I got shafted on the wheels on Craig's list? If the wheels were balanced wouldn't the mechanic notice there is something wrong before he mounted them?
  5. Aug 31, 2013 at 1:12 AM
    Mailman
    Mailman Member
    Dennis
    Texas
    PreRunner SR5, Texas Edition
    IF you really like your new wheels, I think I would start off by going to someone who specializes in tires, (i.e. Discount Tires) and not just some mechanic. They could properly diagnose your problems and make educated recommendations. Good luck
  6. Aug 31, 2013 at 1:46 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    pics, what kind of rims, are they hub centric or???
    I would be looking for another mechanic...
  7. Aug 31, 2013 at 1:53 AM
    dph473
    dph473 Active Member
    America's Tire/Discount Tire or Les Schwab, etc. should be able to tell you right away what is wrong and get you rolling smooth again. Hard to say what the issue is with what you said. May be the wheels but like you said, if there was an issue, the tire guy should know and would have told you about it.
  8. Aug 31, 2013 at 2:42 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    IMO; Wobble could be due from being lug centric. Get hub centric rings, make sure the lug nuts are properly torqued. Rub could be due from the different backspacing, trim, spacers or find new wheels.
    When you say "bounce or something", are you taking about pulsating in the pedal of you actually feel wheel hop? Pulsating in the pedal could be warped rotors, bouncing could be bad shocks.
    We def need some more and better information here. Take a pic of the new WHEEL and tire us.
  9. Aug 31, 2013 at 7:35 AM
    Surg03
    06prerunnersr5
    I had no problem before with my stock wheels, that's what I don't understand. Don't know brand of wheels but I know the front wheels needed a 1.25 spacer to fit. The breaking problem is pulsating, hard to explain never had this problem before so its new to me. Going back today to have him fix it or put my stocks back on, and yes I made sure all the lugs were tight, I first thought that was the problem. I will get some pics
  10. Aug 31, 2013 at 7:51 AM
    Surg03
    06prerunnersr5
    I think I did it right, new here hopefully the pics went.
  11. Aug 31, 2013 at 8:11 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    In not sure but some of the lugnuts look different than others. Are they all tapered seat nuts. You may need extended thread lugnuts. Put a lite grease on the studs and snug the nuts down and the remove it and see how far there threading on. You need atleast the stud width worth of threads. By the looks of it you are gonna need acorn bulge 60deg nuts. Or just do like others have said and take it to a pro tire shop.
  12. Aug 31, 2013 at 12:37 PM
    Surg03
    06prerunnersr5
    Thank you guys for helping me, the mechanic figured it out, I guess my rear break drum had a weight for balance or something and the wheels were not siting flush. He installed two shallow spacers to fit. I'm not a mechanic so I did not understand the weight or notch on the rear rotor or drum
  13. Aug 31, 2013 at 12:39 PM
    Surg03
    06prerunnersr5
    Another pic
  14. Aug 31, 2013 at 12:43 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Two shallow spacers? Please tell me he didn't just slap a couple of washers in there and call it good.
  15. Aug 31, 2013 at 6:42 PM
    Surg03
    06prerunnersr5
    He did balance the wheels but he did slap on the spacers in the rear. Educate me, is he trying to pull a fast one on me?
  16. Aug 31, 2013 at 6:43 PM
    Surg03
    06prerunnersr5
    They were toyota tacoma spacers for the lug pattern if that means
    anything
  17. Sep 1, 2013 at 4:09 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    1.25" spacers on the front, now you have added some kind of spacer to the rears, unknown what kind...
    You are not doing your truck any favors...you need to roll up your sleeves and get to educating yourself...
    this is a very strange story on the rears..
  18. Sep 1, 2013 at 8:32 PM
    dunwur
    dunwur Active Member
    toronto Canada
    2011 tacoma sr5 4x4
    Did you change from alloy rims to steel rims or vise versa ? If so , according to the owners manual , You must also change the lug nuts .
  19. Sep 2, 2013 at 7:48 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I'm a little confused by everything and before something goes seriously wrong, it might be a good idea to go your local wheel/tire shop and buy some proper wheels.
    As something mentioned, please try to educate yourself in this department so you know exactly what's going on and be on the safe side.
  20. Sep 3, 2013 at 5:31 AM
    Surg03
    06prerunnersr5
    Basically I have 1.25 spacers adapters on the front and 1/8 spacers on the rear of my truck. Everything feels fine now but eventually I will just buy new rims that fit the truck without spacers and sell these wheels.
