Issues generated by lifts.......
Discussion in 'Suspension' started by BBBsti LTD, Aug 26, 2010.
  1. Aug 26, 2010 at 7:28 PM
    BBBsti LTD
    BBBsti LTD [OP] Well-Known Member
    Irvine, CA
    2010 TRD Off Road 4WD
    I am quite new to TW, but I have been involved in automotive forums and I don’t like to ask questions commonly asked. I could not find definite answers to my lift related questions.
    I have a 2010 Tacoma DC 4X4 OffRoad. I drive it mostly in the freeway and I have only done a fire road of maybe 10 miles distance twice. For now I don’t want to get too much in offroading since this truck is my only vehicle and it is still brand new, but eventually in few years, I would like to do some more off-road, but never crazy stuff.
    I would like to get a lift with a set of wheels and tires. I like the 3" lift look with some nice wide tires.
    I researched and know what type of lift I would like to get (Toytec Ultimate).
    My concern is with issues related to the lift. I remember reading of a member here having issues with his front differential after a lift and if I remember correctly, some others members had the same issue.
    Is it any commonly known issued from lifting the truck the right way (with a decent kit).
    I understand that the CV joint angle can be fixed with the differential drop and also know about some people getting a vibration at speed, but could any other issues happens?
  2. Aug 26, 2010 at 11:04 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    You pretty much nailed the 2 main concerns, CV and vibe issues are possible. A properly installed 3" is a fairly safe bet and the vibe/CV issues are cheap to fix.
    The other concern is the change in ride quality. The truck won't ride the same as before... for better or worse. I've never ridden on the ultimate lift but it's real popular and seems to be good.
  3. Aug 27, 2010 at 2:47 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Yea and the other problem is there is some issue with the front diff.;I think its a bad bearing, but it will wear out sooner or later with or without lift. look into OME full 3" and just buy axle shims and carrier bearing drop seperate. Save some money unless you just want adjustability. Another idea, if you willing to spend 2K look at RCD. This drop setup will improve your ride and your CV axles will love you
  4. Aug 27, 2010 at 3:00 PM
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    I have a 2010 DC LB 4X4 TRD Sport with a 3" EZ Lift. I have taken it offroading and it performs good. No vibes that I feel. only difference i felt was the different tires, but nothing major. I did do the diff drop but no carrier drop and again have felt no other vibes. Seems to be working just right. I have about 2k miles on the lift and have probably doen about 60 miles of offroading.
