Issues with 17x9 rims with no lift?
Discussion in 'Wheels & Tires' started by Finphan, Oct 29, 2009.
  1. Oct 29, 2009 at 8:54 AM
    Finphan
    Finphan [OP] Active Member
    Logan, OH
    04 TRD Doublecab
    Can anyone provide any feedback on using 17x9 wheels on a 2007 TRD Tacoma with no lift? Will they rub and if so, how bad? Any solutions to this short of lifting the truck?
    Any help would be greatly appreciated.
  2. Oct 29, 2009 at 8:55 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    It depends on the size of the tire, not the wheel
  3. Oct 29, 2009 at 9:08 AM
    Finphan
    Logan, OH
    04 TRD Doublecab
    I get that, but the width of the rim also has an effect on how wide of a tire is needed to fit the rim. Just looking for any input from someone running 17x9 rims on a stock height. What size tire is a good choice? and any issues with them.
    Thanks for the input!
  4. Oct 29, 2009 at 12:41 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Might want to look into a 17x8. To my knowledge most who run 17x9 wheels run 285/70/17 tires with a lift. Now if you don't want to lift you should go with 17x8 wheel or just stay stock and run a 265/70/17 tire.
  5. Oct 29, 2009 at 1:13 PM
    QuoteWarz
    QuoteWarz New Member
    Cali
    05 Tacoma
    It will all depend on what size tire you end up running.
  6. Oct 30, 2009 at 4:22 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I am running 17x9 rims on an 07 stock with 265/70/17....
    Moto Metal 957B with Nitto Terra Grapplers
    I had minor rubbing on full turns or turning and going over a bump, like into the driveway or U turns..I did some minor trimming on the inner fender area and no more rubbing. I drove for about 10 months before trimming, so it is not a major issue and it doesn't cause a problem with normal day to day driving.
    Some tire manufactures only offer certain sizes for a 9" rim and some tire shops won't install a tire on the rim if the manufacturer doesn't say it fits a 9" rim. 265/70/17 is the biggest you can go without a lift, so check the specs of whatever tire you want to use also.
  7. Oct 30, 2009 at 9:19 AM
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
    Is this for 2nd gens only? or does this encompass all tacomas?
    thanks
  8. Oct 31, 2009 at 1:30 AM
    FoxySandChick
    Kristin
    Henderson, NV
    I was answering for the OP with an 07 and I have an 07...I have no experience with the 1st gens, so I'm not sure what the max size is for those.
  9. Oct 31, 2009 at 6:45 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I have the same issues with 1.75" lift. No biggie.
