Issues with brand new 2017 Tacoma 2.7L 4x4 AC 5SPD * VIDEO
Discussion in '3rd Gen. Tacomas (2016-2023)' started by faithless, Mar 22, 2017.
  1. Mar 22, 2017 at 5:50 PM
    faithless
    faithless [OP] Well-Known Member
    2017 2.7L 4x4 MT AC
    Taking it for service at 100 miles. Any input would be great if your Tacoma does these things. I am going in for service on Friday morning. We will see what they say.
    ChadsPride likes this.
  2. Mar 22, 2017 at 5:53 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Please go back to YouTube and make your video
    public!
    Thanks ;)
  3. Mar 22, 2017 at 5:55 PM
    10gaugemag
    10gaugemag Well-Known Member
    Missouri
    I see no issues!!
  4. Mar 22, 2017 at 5:55 PM
    faithless
    2017 2.7L 4x4 MT AC
    Oops. Done.
  5. Mar 22, 2017 at 5:55 PM
    faithless
    2017 2.7L 4x4 MT AC
    So you are saying all of those things are normal?
  6. Mar 22, 2017 at 6:00 PM
    10gaugemag
    Missouri
    No, I saw nothing in original vid just static!!
    Was able to watch a second ago.
  7. Mar 22, 2017 at 6:06 PM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    Most stuff seems normal to me...I have same engine.
    Cant hurt to check your trans and trasfer fluid levels.
  8. Mar 22, 2017 at 6:08 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Hard to really tell from the video. If you are worried about it, I'd take it in and have your issues documented. The truck isn't even slightly broken in yet, the idling issues I wouldn't really worry about till it has more miles on it. There might be something wrong with the trans, but can't really tell. My trans was very tight for the first couple thousand miles, hell 1st, 2nd is still pretty tight.
    Keep us updated.
  9. Mar 22, 2017 at 6:14 PM
    MOC221_
    Frank
    I have the V6 M/T, so not exactly apples/apples..
    Serious question OP, is this your first MT that's not front wheel drive? Not trying to be a dick, but most "top loader" transmissions will shake the shifter around quite a bit, because it is directly attached to it (as opposed to a cable shifter, for example). Mine moves a lot, especially on rough roads
    Frank
  10. Mar 22, 2017 at 6:18 PM
    MOC221_
    Frank
  11. Mar 22, 2017 at 6:26 PM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    I have the same 2.7L and M/T and experience that drastic shift lever wobble also - - unless, I very deliberately make sure I am off the accelerator before disengaging the clutch (pushing foot pedal in). Only an issue with 1st & 2nd gears (3rd - 5th are smooth as glass). If I have just a slight amount of fuel feed going when I clutch, the shifter tries to throw my hand off. If I pay attention and operate it with precision coordination it stays very, very smooth.
    For reference, I just bought the Tacoma in Jan17 and for the 18 years prior to that I drove a '93 Civic VX w/ a manual. Never had an issue like this when shifting that car. In fact, I had thought the throw-out bearing had gone bad at 246,000 so I bought a new clutch kit. Well, the original clutch coming out, w/ 246k+ miles on it, mic'd in at factory new specs. (0.40") That tells me that I wasn't abusing that clutch with improper shift technique. But apparently that same technique doesna work on Tacomas. It may be related to the post about FWD and top loaded transmissions, but my '42 Studebaker p-up doesn't do the shake-up (not the same either, but it is a top-load xnmsn).
    I do not have the clutch noise that you focused on in your video though.
  12. Mar 22, 2017 at 7:37 PM
    faithless
    2017 2.7L 4x4 MT AC
    No this is not my first 4WD truck. I had two Rangers before this. I never remember the stick moving so bad. I also test drove a few 1gen tacomas and I don't recall there being so much movement and I would have definitely noticed something like that.
    I think it's either a problem with an engine mount or something is loose like bell housing to tranny. The noise when I let off the clutch sounds like a flywheel or pressure plate ticking the bell housing. All I know is I just took this truck off the lot and in one day I am annoyed. I rather have it documented than not so we will see what they say on Friday. I am totally expecting a "nothing wrong with it".
  13. Mar 22, 2017 at 7:43 PM
    BeaverNation
    BeaverNation Well-Known Member
    There's nothing wrong with it, I've had 3 manual tacomas and they all do that.
  14. Mar 22, 2017 at 7:46 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I cannot tell from the Video but if its making noise when you take your foot off the Clutch in Neutral it may have a bad Throwout Bearing.
    Krucen 01 and 10gaugemag like this.
  15. Mar 22, 2017 at 7:49 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Yeah my shifter moves around that much and more on rough roads at speed. Mine idles at 500-600 rpm when warm and will dip and shake when the ac compresor kicks on. I have the V6 though. The "clank" when clutching in seems like what happens if you let off the gas too early when shifting. See if it still does it if you keep on the gas while clutching in. Just a guess. I couldnt hear the clutch rattle in neutral at the end of video so i dunno. Mine doesnt rattle but like all manuals in my experience you can hear a difference between neutral and a disengaged clutch if you listen for it.
    MOC221_ likes this.
  16. Mar 22, 2017 at 10:19 PM
    Taco Wheeler
    Taco Wheeler Well-Known Member
    17 Tacoma 4x4 Manual
    Toyo Mt
    First off you are NOT used to the truck, your shifting shows it, im not saying you cant drive a stick, I'm saying you've only put 90 miles or so on it, you are not used to the truck, the shift points, at what rpm to shift, when to clutch in, how much throttle can be be applied in between shifting etc...
    Go put 500 miles on it, get used to it, and come back and talk to us!
    George1441 and kcox31Tx like this.
  17. Mar 22, 2017 at 10:26 PM
    faithless
    2017 2.7L 4x4 MT AC
    You are probably right. I will report back.
  18. Mar 23, 2017 at 12:14 AM
    Dc2tacoma
    Dc2tacoma Well-Known Member
    6MT here and it have more play than Greg Oden
    Braves95 likes this.
  19. Mar 23, 2017 at 12:27 AM
    evilfij
    evilfij Well-Known Member
    2016 ACLB SR 4x4 MT Utility Package Black
    TRDOR wheels, sheepskin seat, cruise and intermittent wipers, curt hitch
    Seems normal to me. The trans and engine mounts allow a lot of movement in the trans lever compared to what I am used to (rovers) with direct mount shifters and obviously compared to cable/rod activated transmissions.
    MOC221_ likes this.
  20. Mar 23, 2017 at 2:24 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    That "rattle" is your throw out bearing. Sounds normal
    baron55 likes this.
