IT BS thread
Discussion in 'Technology' started by chadderkdawg, Jan 16, 2012.
  1. Feb 19, 2017 at 8:03 PM
    #2561
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    One thing to note is your wireless and eth0 will have different MAC address. If your pi has an address on eth0 when you disconnect it a second MAC will have a second IP from DHCP. Have you tried doing another search?
  2. Feb 20, 2017 at 8:50 AM
    #2562
    bongwhisperer
    bongwhisperer Well-Known Member
    horn that plays "la cuka racha,"
    A search with fing? I will try later tonight.
    My second thought is, since I have both wifi dongles set up and working, just assign two different access points to the pi, at school I can put one wifi dongle on A and put the second one on B. That way each gets assigned an individual ip from two different networks. Not sure if it will work, but I'm gonna try and see what happens.
  3. Feb 20, 2017 at 9:04 AM
    #2563
    digitaLbraVo
    You can do that. What would be the purpose though? You will want to make sure only 1 side has a default gateway otherwise you can have weird session based issues as WAN IP can change.
  4. Feb 20, 2017 at 10:02 AM
    #2564
    bongwhisperer
    To be honest, I don't really need two individual ip's. I just need to make sure I can connect through and establish an ssh session through the TL-WN725N, which I can, and I just want to be able to put the other into monitor mode. Since both dongles work, I think I should be able to do this.
  5. Feb 22, 2017 at 10:52 AM
    #2565
    digitaLbraVo
    Like I said man if you have a wifi connection to your home wireless and a cable plugged into the same wifi-access point/L2 switch/firewall router combo (or whatever it is), youhave 2 IPs on the same network. Two different MAC addresses.
    That explains why if you plug in with a cable you can ssh into THAT IP, you're getting eth0's IP. If you then setup wifi, unplug the cabled connection you'll drop. The wifi is at a different IP on the same network as every NIC has it's own MAC address (spoofing not withstanding....).
  6. Feb 22, 2017 at 10:59 AM
    #2566
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Unless you're on a PS3/PS4
  7. Feb 22, 2017 at 11:04 AM
    #2567
    digitaLbraVo
    Like I said... spoofing not withstanding.
  8. Feb 23, 2017 at 11:05 AM
    #2568
    bongwhisperer
    345.jpg Got them both working. I think it is set up how I want it. I haven't tried running aircrack-ng or monitor mode, but I can log into the IP associated with wlan1 which is set to the mini wifi dongle WN-725N and the wlan2 which is dongle WN-722N, the one I can get into monitor mode, has its own ip. I can still run the command: sudo iwlist wlan2 scan | grep ESSID from wlan1 and scan SSID's.
    So I am hoping I will be able to get it into monitor mode and still be connected to the mini dongle
  9. Feb 23, 2017 at 11:06 AM
    #2569
    digitaLbraVo
    Those SSID's are boring :(
    Did you honestly hide your private IP's? bruhhh
    oni06 likes this.
  10. Feb 23, 2017 at 11:22 AM
    #2570
    bongwhisperer
    I'm not Jedi yet and some of the shit that you guys can do scare me. So yes, I did black out my IP's.
    :anonymous:
    loco usmc likes this.
  11. Feb 23, 2017 at 11:25 AM
    #2571
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    ips inside your network are trivially easy to obtain.
  12. Feb 23, 2017 at 11:25 AM
    #2572
    digitaLbraVo
    If the IP you have is
    192.168.0.0/16
    172.16.0.0/12
    10.0.0.0/8
    169.254.0.0/16
    You do not have to hide it.
  13. Feb 23, 2017 at 11:28 AM
    #2573
    bongwhisperer
    Do you foresee any problems with having the wifi dongles set up this way?
  14. Feb 23, 2017 at 11:31 AM
    #2574
    digitaLbraVo
    Nope. If wlan1 is on network 192.168.0.0/16 and wlan2 is on 10.0.0.0/24, if your computer is on 192.168.0.0/16 you can communicate with the device and it will be able to reach both networks.
    Again though, like I said, if you have a gateway on both IPs and the route priorities are wrong you may have weird issues. ESPECAILLY if the 10.0.0.0/24 network happens to have some route built that would point to another network with a 192.168.0.0/24... say via a VPN or MPLS.
  15. Feb 23, 2017 at 11:32 AM
    #2575
    bongwhisperer
    my noobeness. :annoyed:
    digitaLbraVo[QUOTED] likes this.
  16. Feb 23, 2017 at 11:33 AM
    #2576
    digitaLbraVo
    Those are all private non-routable networks.
    My computer is 192.168.1.100
    My vHost is 192.168.1.10
    YOU CAN'T HACK ME :rofl:
    Firebird likes this.
  17. Feb 23, 2017 at 11:39 AM
    #2577
    bongwhisperer
  18. Feb 23, 2017 at 12:00 PM
    #2578
    digitaLbraVo
    Do yourself a favor. Crack open the first few sections of NET+ or CCNA/CCENT you'll thank me later as you cannot really begin to understand your tools if OSI or the different protocols don't make sense. You gotta know at least how it works in order to exploit it.
  19. Feb 23, 2017 at 12:07 PM
    #2579
    bongwhisperer
    Sweet. Any other book reccomendations would be greatly appreciated.
  20. Feb 23, 2017 at 2:59 PM
    #2580
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    So i got called in to fix someone's network issues yesterday. It's tiny office on AT&T DSL with 10 static routable IPs and a new Arris DSL modem. 1 Linux "server" (old dell desktop), 1 QNAP storage box and an Airport Extreme. Everything is plugged into and old dumb 100mbit switch.... The server and QNAP both have 2 ethernet cables going to the same dumb switch and they tell me that both of these boxes have internal and external IP addresses..... while connected to the same dumb switch. My had exploded. They are mixing internal and external traffic on a dumb switch with no VLAN support of any kind.
    Apparently, geniuses at Arris decided that it was a good idea to some internal woodoo and route external IPs to the internal network all willy nilly.... because you know, NAT is somehow not cool anymore.
    Here is a kicker... AirPort was set into the bridge mode and gave out routable internet addresses to internal DHCP clients.
    Anyway, I have tried to fix things but turns out they use the QNAP as L2TP VPN server, and this Arris modem is not able to properly NAT GRE, so no vpn connections timed out. Had to leave everything as is for now and told them that they need a proper Linux or pfSense firewall, so we could bridge that stupid Arris and have proper control of how things work.
