IT BS thread
Discussion in 'Technology' started by chadderkdawg, Jan 16, 2012.
  1. Mar 20, 2017 at 6:11 PM
    #2641
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    do you work in a place that uses primarily microsoft or apple? do you ever have programs that simply dont play well together or have you been able to find a decent work around for these situations? im just worried switching fully to a linux based system will make things too difficult to move between windows applications and files to linux at home. (work is 100% windows) only reason im looking at a switch is that my home computer is XP and my work computer doesnt share files that play well with my home computer.
  2. Mar 20, 2017 at 6:32 PM
    #2642
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    At work, we have some sort of frankenstien Windows CE/Python thing going on.
    I would suggest using Linux on a spare pc if you have one. Install, experiment, reinstall, etc until your comfortable enough to trust your data with it. Linux has many ways of doing things, some like Windows, some ways very different. These days it's rare I need windows for anything at home.
    jpneely[QUOTED] likes this.
  3. Mar 20, 2017 at 6:44 PM
    #2643
    jpneely
    Charleston, SC
    Fair enough. Thanks man.
  4. Mar 22, 2017 at 7:33 PM
    #2644
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Use the Ubuntu live ISO and create a bootable flashdrive with UNetBootin.
    **Edit I misread the question
  5. Mar 23, 2017 at 1:04 PM
    #2645
    bongwhisperer
    bongwhisperer Well-Known Member
    horn that plays "la cuka racha,"
    Hello IT people,
    For anyone who has taken the CCNA exam, would this book be enough to study for it? THis is a the book we used in my advanced networking class, but I'm not sure if this alone would be sufficient.
    Thank you,
    Leonard
  6. Mar 23, 2017 at 2:01 PM
    #2646
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    i used 2 different books back when i did the CCNA in 2010. i let mine lapse since I never work on network gear anymore. if you've never taken a cisco test, they are hard because the information is hard. microsoft tests are hard because they have tricky questions and the MS way is not necessarily the way the real world works.
    bongwhisperer[QUOTED] likes this.
  7. Mar 23, 2017 at 2:12 PM
    #2647
    Pabloeeto
    Paul
    San Diego
    The CCNA is broken down into 2 tests. Get the Cisco press books for each exam or get the one for the composite exam. Honestly if its your first go at the CCNA take the 2 exam route.I used the books written by Wendell Odom but any Cisco press is good.
    bongwhisperer likes this.
  8. Mar 23, 2017 at 2:15 PM
    #2648
    krap22
    krap22 Well-Known Member
    Anyone dealling with outsourcing companies such as TCS, IBM, HP, etc?
  9. Mar 23, 2017 at 4:49 PM
    #2649
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    At one time, I probably could have passed a CCNA with minimal studying. Now, though, I've forgotten too much. Couldn't write an ACL or configure a routing protocol from memory anymore. My understanding is a good chunk of the exam is a virtual lab so you can prove you can actually apply the knowledge and know the commands.
    I believe by going the two exam route you will walk out with a CCENT as long as you pass the first one.
  10. Mar 30, 2017 at 4:24 PM
    #2650
    replica9000
    2019 T4R ORP
  11. Mar 31, 2017 at 3:18 PM
    #2651
    jsi
    jsi Well-Known Member
    native earthling
    What would you do?
    Just going to throw this out there to see what happens. I have kind of a different decision that has 2 choices and neither one is terribly satisfying.
    Scenario: I will soon be replacing 180 industrial computers running a video monitoring process. They run in the nastiest environment you can think of for a computer, hot / cold / vibration / dirt / crappy power. I tell my users that when computers are little they are taught that if they are good they go to a data center, and if they are bad, the become process monitors. This is computer hell.
    So, here’s the problem. 99.99% of the time everything runs just fine and nobody cares about the monitoring video, but for that .01% the users care a lot. These Windows 10 based (yeah I know) industrial computers will come equipped with two 1TB SSD drives that can be configured one of two ways:
    Option 1 - Hardware RAID 1 (mirrored)
    Pros
    • Mirrored – one drive fails and everything keeps working
    Cons
    • No way to know if the first drive has failed. These computers have no driver to communicate to Windows the status of the RAID. We will find out about a failure only after the second drive fails and the corresponding loss of data. That data loss may or may not be a big deal.
    Option 2 A primary drive running a backup to the secondary drive
    Pros
    • Nagios will alert us if either drive fails.
    • A backup of the data if the primary fails.
    • An easier restore if the primary fails
    Cons
    • 50/50 chance of the primary failing. The MTBF of the monitor will be lower because there is no mirror.
    The Cons are just about equal. Nagios will notify us in either monitoring failure situation. Option 1 with mirroring will provide a longer MTBF and that’s one of my priorities. Option 2 has quicker recovery times because of the backup.
    Which one would you choose option 1 or 2?
  12. Mar 31, 2017 at 3:20 PM
    #2652
    replica9000
    2019 T4R ORP
    What about software raid?
  13. Mar 31, 2017 at 3:48 PM
    #2653
    jsi
    native earthling
    I've considered it, but it does slow down the write speed which is an issue. There are four 4k cameras running at 15 FPS. And if one faction of users get their way there will be eight 4K cameras. Read time isn't an issue because when things go sideways the users download the video and analyze the problem frame by frame.
    (As I think further, the current system uses spinning drives, 360p cameras and older CPU's and it can't keep up. But, I've not have accounted in my head for the speed of SSD's and the i7 processors - Hmm)
  14. Mar 31, 2017 at 8:14 PM
    #2654
    drwx
    M'boro, TN
    Why not store the data on servers instead of desktops?
    Pabloeeto likes this.
  15. Mar 31, 2017 at 9:24 PM
    #2655
    jsi
    native earthling
    For the most part these computers are not connected to any network and have to run autonomously. They do connect at the end of the day when the equipment returns to the shop. So we will know if there is a problem when they check in. Often when things go sideways we have to send someone into the field to retrieve the hard drive so the users can figure out what went bad. We did discuss downloading all of the data every night, but there are bandwidth problems between the shop and the datacenter and 99.99% of the data we don't care about anyway. (suffice to say that the .01% stuff can be very expensive and even the crappy system we currently have has paid for itself many times over by allowing the users to fix problems so they don't reoccur.)
  16. Apr 1, 2017 at 5:21 AM
    #2656
    drwx
    M'boro, TN
    Ok then, option 2. I personally use crash plan and backup to they storage for $6/ month, but you can backup locally for free. You can even backup to another computer for free as long as you aren't using cloud storage.
  17. Apr 13, 2017 at 11:18 AM
    #2657
    replica9000
    2019 T4R ORP
  18. Apr 14, 2017 at 4:19 PM
    #2658
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    How the hell did I not know about this?
    How many of you guys use OpenStack?
  19. Apr 14, 2017 at 4:48 PM
    #2659
    drwx
    M'boro, TN
    Knowing what the problem is is the first step to ignoring it.
    Sleipnir likes this.
  20. Apr 16, 2017 at 12:01 AM
    #2660
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Had to work 48 hour last week and 60 hours this week. Made something tonight I call the Dream Crusher
