IT BS thread
Discussion in 'Technology' started by chadderkdawg, Jan 16, 2012.
  1. Feb 16, 2012 at 8:10 AM
    #321
    chadderkdawg
    chadderkdawg [OP] Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Most now are 32, but moving to 64 as I upgrade to win7
  2. Feb 16, 2012 at 8:12 AM
    #322
    krap22
    krap22 Well-Known Member
    a 64 bit OS can be a PITA to get setup with 32 bit clients. You will need to add the 32 bit drivers to the 64 bit machine. To do this, you have to connect to the printer from a 32 bit machine and add the driver from the 32 bit machine.
    edit, maybe they finally got smart and changed it. used to be a PITA.
    http://technet.microsoft.com/en-us/library/cc732946.aspx
  3. Feb 16, 2012 at 8:14 AM
    #323
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Its gotta be easier than adding the 64 bit drivers in xp....
  4. Feb 16, 2012 at 8:16 AM
    #324
    krap22
    ok i found the "gotcha" i've dealt with for printers and x64/x32
    this is from the link in my previous post.
  5. Feb 16, 2012 at 8:16 AM
    #325
    krap22
    same BS, just reversed.
  6. Feb 16, 2012 at 8:18 AM
    #326
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Cool, thanks for this
  7. Feb 16, 2012 at 8:20 AM
    #327
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Whats a printserver ?
  8. Feb 16, 2012 at 8:20 AM
    #328
    krap22
    np, it took me forever to find the solution the first time i had this issue.
  9. Feb 16, 2012 at 8:21 AM
    #329
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    :notsure:
  10. Feb 16, 2012 at 8:22 AM
    #330
    krap22
    it is a machine that you use to manage print queues. The one server (pc in this case) is connected directly to the printers (either by usb or network). All of the machines in the office then point to the print server for their printers.
  11. Feb 16, 2012 at 8:25 AM
    #331
    BlueT
    NorthEast
    Ah I remember now we getrid off those when we ditched 5.25 floppies and ditched old service desk
    Direct printing FTMW :D
  12. Feb 16, 2012 at 8:26 AM
    #332
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Loading drivers on thousands of PC's individually, not ftw
  13. Feb 16, 2012 at 8:28 AM
    #333
    krap22
    depends on the printers you have, If you have a lot of printing going on, the printer doesn't always have the buffer to manage it, that's where a print server come into play. It also allows you to manage printer drivers. With the print server, i can just point a machine at the print server and it gets the driver automatically. Very useful for things like login scripts.
  14. Feb 16, 2012 at 8:29 AM
    #334
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not sure if this is the place for it but figured I'd throw it out to you guys. If you guys were to buy a new laptop, what would you get? Here's my criteria:
    -Under $500
    -For personal use (browsing, e-mail, basic office fuctions, doesn't have to be lightening fast, even the bottom of the line laptops these days are double the speed of my current one)
    -15" + screen size
    I know that really limits the choices, the 2 I've found are an Acer and an HP. Thoughts/Comments/Opinions?
  15. Feb 16, 2012 at 8:33 AM
    #335
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Under 500 bucks... yikes, if you are gonna go cheap, get something reputable with a good warranty, processors and memory are going to suck in the price range, so just get something that the manufacturer will fix if it breaks.
  16. Feb 16, 2012 at 8:33 AM
    #336
    krap22
    we got a dell for my wife from best buy for around that price too. I try to stick with a major manufacturer that will support their product. I don't know much about Acer support, but HP support isn't that bad.
  17. Feb 16, 2012 at 8:33 AM
    #337
    BlueT
    NorthEast
  18. Feb 16, 2012 at 8:34 AM
    #338
    krap22
    do you hear an echo?
  19. Feb 16, 2012 at 8:41 AM
    #339
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Check out www.slickdeals.net (Wednesday).
    They show an HP laptop for $330 after coupon code and $50 rebate (free shipping) from Staples.
    Specs:
    • AMD Dual-Core A4-3305M (1.9GHz)
    • 15.6" LED-backlit (1366x768)
    • 4GB DDR3 Memory
    • 640GB Hard Drive
    • AMD Radeon HD 6480G
      • HDMI
      • VGA
    • SuperMulti DVD Burner
    • Webcam
    • WiFi N
    • Bluetooth
    • 6-Cell Battery
    • Windows 7 Home Premium 64-Bit
  20. Feb 16, 2012 at 8:42 AM
    #340
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    we're back!
