IT BS thread
Discussion in 'Technology' started by chadderkdawg, Jan 16, 2012.
  1. Feb 21, 2013 at 6:41 PM
    #1161
    egan
    egan Well-Known Member
    Brian
    Steilacoom, WA
    95 Single Cab 4wd
    That's what I thought, but then i read this:
    General
    Cable Type: Video / audio adapter
    That is what confused me :confused:
  2. Feb 21, 2013 at 6:47 PM
    #1162
    krap22
    krap22 Well-Known Member
    http://en.m.wikipedia.org/wiki/DisplayPort
    I stand corrected, it looks like it does carry audio. If you try it, I would be interested in how it works.
  3. Feb 21, 2013 at 6:49 PM
    #1163
    egan
    Brian
    Steilacoom, WA
    95 Single Cab 4wd
    Alright I guess I'll try it. Doesn't cost too much so it won't kill me if it doesn't work :p
  4. Mar 12, 2013 at 7:20 PM
    #1164
    egan
    Brian
    Steilacoom, WA
    95 Single Cab 4wd
    By the way, it works for both audio and video.
    It is set up as dual monitors with my laptop and my TV. And i just set the audio default to the TV so that all sounds come from the TV instead of the computer.
    Works pretty well. :thumbsup:
  5. Mar 13, 2013 at 6:58 AM
    #1165
    krap22
    awesome. good to know the display port does audio as well.
  6. Mar 18, 2013 at 2:18 PM
    #1166
    chadderkdawg
    chadderkdawg [OP] Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Maybe you guys might have an idea on what to do here. I have a print server that I access through windows explorer by ip address, I then enter the username and password, find my printer and install. I also run a login script to map drives, I want to map a drive that points to the folder that the shared printers exist in, however I can't figure out how to do that. When mapping a drive it requires a folder, but when I browse the network the printers aren't in a folder.... so for now I just have it set to ipaddress\c$ so that it save the user account info, it would be great to map it to the shared devices. Any ideas?
  7. Mar 18, 2013 at 2:46 PM
    #1167
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    Palos Verdes
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    My question is .. why?
    Credentials should be automatically passed to the print server when connecting to install the printer or print a job. The desired printers should stay installed and connected unless the shared printer permissions change.
    FWIW, A mapped drive connects to a data/disk resource which a printer is not.
  8. Mar 18, 2013 at 2:54 PM
    #1168
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I think he's installing the drivers locally. At least that's what I got from his request.
  9. Mar 18, 2013 at 2:55 PM
    #1169
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Correct
  10. Mar 18, 2013 at 2:58 PM
    #1170
    NoSoup4You
    David
    Palos Verdes
    :confused: maybe I am misunderstanding... the point of a print server is to host queues and drivers. The first time you connect to a shared printer the drivers are pushed down to your local machine. This only needs to be done once per printer, hence why I am confused as to why a perpetual mapped drive is desired.
    EDIT: understood that it would be convenient if you have tons of printers being installed by users regularly.
    In that case you could create a shared folder on the print server with .LNK files for all the printer shares
  11. Mar 18, 2013 at 3:01 PM
    #1171
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Can you describe your environment? Do you run AD? Why not use one machine as the print server? Simplifies things.
  12. Mar 18, 2013 at 3:03 PM
    #1172
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    This is true for server setups. But some shops want the drivers installed locally-which makes maintenance a real PITA.
  13. Mar 18, 2013 at 3:07 PM
    #1173
    NoSoup4You
    David
    Palos Verdes
    print server was mentioned in the first post...
    and drivers are ALWAYS installed locally even when connecting to a shared network printer. the difference is that they have to be managed locally if the print queue resides on the local machine instead of a print server.
    this ^^^
  14. Mar 18, 2013 at 6:15 PM
    #1174
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    I guess I am getting confused here but why not just connect to the printers that are on the print server ?
  15. Mar 18, 2013 at 6:39 PM
    #1175
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    This is what I was thinking by how the question was asked.
  16. Mar 19, 2013 at 6:16 AM
    #1176
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    No AD, but we connect to our local hospitals domain, since network printers are a user based setting, for each user that signs in I have to install their printer. Since I have a script anyway to map drives, it would save a few clicks for me if I could just browse to the printer, rather than search for it.
  17. Mar 19, 2013 at 7:12 AM
    #1177
    krap22
    is the script that maps drives a vbscript? you can map printers with vbscript as well.
  18. Mar 19, 2013 at 7:36 AM
    #1178
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Nope, simple cmd script... Sounds like I need to learn vbscript.
  19. Mar 19, 2013 at 8:35 AM
    #1179
    NoSoup4You
    David
    Palos Verdes
    There should be an easy way to do it via CMD also... not totally sure though.
  20. Mar 19, 2013 at 8:53 AM
    #1180
    krap22
    I can get you some examples. We use vbscript at our office to map drives and printers based on AD groups. It really isn't too hard, especially when you have a template to go off of.
