IT BS thread
Discussion in 'Technology' started by chadderkdawg, Jan 16, 2012.
  1. May 28, 2013 at 9:32 AM
    #1281
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Depends on how the manufacturer makes it. Some do like you say, others won't boot past making the fans spin a few seconds.
    jpneely, did you try removing or re-seating the RAM sticks? If you can, run with less memory or swap for some known good sticks.
  2. May 28, 2013 at 12:58 PM
    #1282
    farmerjon
    farmerjon Hailing from the land of bucking broncos...
    farmerjon
    Rugged Rockies
    '98 4Runner SR5, 4WD, V6, 3.4L.
    ARB, sleeping platform, Husky liners.
    RAM messes with things easily.
  3. May 28, 2013 at 1:20 PM
    #1283
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    They are a certain kind of watch battery. If you pop out the old one, the name and model will be etched into the side. Take the old one with you to Radio Scrap and hand it to the guy, he'll walk over to the wall o batteries and match it. They're usually $3 to $5.
    Damaged RAM can also do what you're talking about. Cooked RAM isn't terribly uncommon, either.
  4. May 28, 2013 at 2:55 PM
    #1284
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    BINGO bitches. RAM was the culprit. pulled one out and she started right up. +1 to you good sir! shes slower but at least she works again. guess its time to get a new one of those.
    and since im going to replace it its a 512MB would i even be ably to tell a difference if i get the next one at 1GB or up? and i have two sticks in there both 512MB can i have one at 512MB and one at a higher memory?
  5. May 28, 2013 at 3:07 PM
    #1285
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    what OS are you running?
    no it doesn't make a difference if one is 512 and one is 1.
    i'd recommend having 2 or more Gb of RAM if you have a dual core or more processor.
  6. May 28, 2013 at 3:12 PM
    #1286
    jpneely
    Charleston, SC
    im running XP and it has Centrino Duo
  7. May 28, 2013 at 3:24 PM
    #1287
    Xaks
    Xaks
    Oklahoma City area
    2GB of decent DDR2 800mhz RAM is the 'sweet spot' for 32bit XP Pro...and, thankfully, hella cheap right now.
    What's your vid card memory and make/model?
  8. May 28, 2013 at 3:24 PM
    #1288
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    32bit XP won't handle more than 4gb of ram, so don't try to go more than that if your system is 32 bit.
  9. May 28, 2013 at 3:26 PM
    #1289
    Xaks
    Xaks
    Oklahoma City area
    And don't forget, video card RAM is part of that equation.
    If you have 512M on your video card, then only 3.5 GB is available for the system, even if you HAVE 4 GB installed.
  10. May 28, 2013 at 3:31 PM
    #1290
    jpneely
    Charleston, SC
    yea its the 32 bit system. so basically what yall are saying is that dont exceed 3GB on my setup
  11. May 28, 2013 at 3:34 PM
    #1291
    Chickenmunga
    Keizer, Oregon
    Depends if it's paired sticks. JP also needs to make sure what the system's upper limit is. Some manufacturers impose really low limits.
    Depends on if it is shared video RAM or dedicated. Granted, it's most likely shared.
  12. May 28, 2013 at 3:38 PM
    #1292
    Xaks
    Xaks
    Oklahoma City area
    Actually, no it does not depend. Hardware RAM, like on a dedicated video card, is counted against the 4GB max up front, before the OS gets a crack at it as 'system memory'.
    I have tested this a hundred times (no, literally...I build custom gaming rigs for people as a side job), and it is as such, and has been since day 1. Shared RAM is from the same RAM pool as system memory, yes, so if you dedicate 512 MB of 'system RAM' to the 'video card' you'll have half a gig less on the OS tab.
    However, I've done this personally: Put 4 GB of RAM on a motherboard, add in a 1GB nVidia 650GTX, install XP32.
    The OS shows 3GB of available RAM, no matter what you do it cannot see more.
  13. May 28, 2013 at 3:42 PM
    #1293
    jpneely
    Charleston, SC
    so basically again keep mine below 4 total and im set. i was fairly happy with this comp before it went out. im not trying to max out my system or anything. i may just go back with the 512MB. just would rather upgrade since im buying some anyways
  14. May 28, 2013 at 3:48 PM
    #1294
    Xaks
    Xaks
    Oklahoma City area
    It's only an issue now since relatively cheap video cards are coming with 512MB, 1GB, and even 2GB (relatively, again!) of on-board RAM. Up until the last couple years, that simply wasn't the case...even a 512MB was a 300$+ behemoth that only dedicated powergamers would buy, and have the hardware to run/power it/cool it.
    Nowadays, with the 4GB limit in 32 bit OSes, and cheap-as-hell RAM, people are running out of room.
    In your case, 2GB of decent 800mhz DDR2 and a middle of the road or even cheap vid card will make that rig fly, provided XP itself isn't fuxxor'd.
  15. May 28, 2013 at 3:50 PM
    #1295
    Evil Monkey
    Robert
    Escondido, CA
    But like they said also, check on what capacity your laptop will support. XP's limit is 4gb but your computer's limit may be less.
    Sometimes, it will be higher than what the manufacturer shows because at the time of manufacture, memory sticks weren't available that would go higher. I have a Dell that stated it's upper limit was 2GB. I put 4GB in and it worked fine (3.5 as stated above).
  16. May 28, 2013 at 3:54 PM
    #1296
    Xaks
    Xaks
    Oklahoma City area
    Evil Monkey speaks troof.
    *nods
  17. May 28, 2013 at 3:56 PM
    #1297
    Evil Monkey
    Robert
    Escondido, CA
    And don't argue with an armed sysadmin.:D
  18. May 28, 2013 at 4:00 PM
    #1298
    jpneely
    Charleston, SC
    ok mine maxes out at 3.5. you guys are awesome. saved me a lot of money and time. neither of which i have much extra of now.
  19. May 28, 2013 at 4:12 PM
    #1299
    jpneely
    Charleston, SC
    should i just go ahead and replace both sticks since theyre the same age and have been through the same abuses?
  20. May 28, 2013 at 4:42 PM
    #1300
    Xaks
    Xaks
    Oklahoma City area
    I would.
    How much is matched 1GB sticks of 800mhx right now? $20-30 I think. Silly cheap.
