IT BS thread
Discussion in 'Technology' started by chadderkdawg, Jan 16, 2012.
  1. Nov 24, 2013 at 7:47 PM
    #1561
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    I say try a full reset... up to you... if you know how to access your routers ip address and set it all up... which you do
    haha or this
  2. Nov 24, 2013 at 7:52 PM
    #1562
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    I usually dont have that problem but could be
    Maybe tomorrow when I work on my truck
  3. Nov 24, 2013 at 7:58 PM
    #1563
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    First of all, Comcast very often doesn't deliver what it says it will. It can't-sort of the nature of how cable works.
    The things you can try to improve wireless connectivity are: check the channels used by the wifi. Sometimes, there are other wireless routers using the same channels for their wifi and this can cause performance issues. Second, the path between your router and the devices connecting to it should be free of things that might cause degradation of signal-metallic wall studs are a good example, and lastly, distance. Be sure the devices you want to connect are within the range of the router-this won't be a problem in most houses but could be in a commercial space. Lastly, check the antenna orientation and make sure it's correct and away from electric cords or other metallic objects.
    There's a slight chance the current security settings are what's causing the problem. You can try a lower security setting. Also, look at any software you're running for firewalls/spam/etc and make sure it's working correctly.
    HTH.
  4. Nov 24, 2013 at 8:01 PM
    #1564
    Monster Coma
    Corey
    The 25-30mbps short was from previous performance numbers not what comcast says they offer.
    and I understand these issues but the router has been fine in the past and I havent moved it.. It worked great yesterday and today it sucks.
  5. Nov 24, 2013 at 8:08 PM
    #1565
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Good luck.
  6. Nov 24, 2013 at 8:10 PM
    #1566
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    SOMEthing is different. Logically, it must be.
    Otherwise it would be working.
  7. Nov 24, 2013 at 8:11 PM
    #1567
    Monster Coma
    Corey
    Thats why I think its something on comcasts end. As far as I know nothing has been changed on my end
  8. Nov 24, 2013 at 8:15 PM
    #1568
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Things get old and die. Forced upgrade.
    Monster Coma, if you can, buy a MoCA bridge. They are fantastic.
  9. Nov 24, 2013 at 8:17 PM
    #1569
    KCDuran
    Kyle
    South Jersey
    5 Lug'n 4 banger
    can you connect to JUST the modem? start there... then move up... if you cant connect with just the modem then comcast (or bad modem)
  10. Nov 24, 2013 at 8:24 PM
    #1570
    Monster Coma
    Corey
    I can connect with just the modem.. but idk how often. I never use my parents computer but my mom said she was having trouble with it earlier.. The lady at comcast expected me to believe it was my router just because I could connect to the internet 1 time with the modem.. I can connect with the router too its just random when it disconnects.
    and I wont be getting a MoCA bridge.. I dont live with my parents enough to shell out $60 for it.
    I'm just curious how yesterday I stayed connected the whole day with no issues and now today its fucking up. I doubt my router took a shit over night but anything is possible I guess.
    and now its not connecting at all.. I have 5/5 bars on my comp and 4/4 bars on my xbox but I cant open a webpage or connect to xbox live..
  11. Nov 24, 2013 at 8:31 PM
    #1571
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Can you access the modem and pull line stats from it? This will help you see what your looking for. If they are not within good ranges, Comcast needs to fix it.
  12. Nov 24, 2013 at 8:32 PM
    #1572
    Monster Coma
    Corey
    How do I do this?
  13. Nov 24, 2013 at 8:34 PM
    #1573
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    You may or may not be able to, depending on if your modem is bridged or not. What model modem do you have?
  14. Nov 24, 2013 at 8:39 PM
    #1574
    Monster Coma
    Corey
    Arris TM822
    Figured it out..
    Downstream: 1.9 average
    Upstream: 44.70 average
    37.36 db
  15. Nov 24, 2013 at 8:40 PM
    #1575
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Are those the power readings? If so then there is definitely a problem on the downstream reading.
  16. Nov 24, 2013 at 8:42 PM
    #1576
    Monster Coma
    Corey
    see my edit
  17. Nov 24, 2013 at 8:45 PM
    #1577
    Monster Coma
    Corey
    just ran another speed check..
    So I guess it is my router..
  18. Nov 24, 2013 at 8:45 PM
    #1578
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Are you able to connect right now? Those readings can and will change, especially if you've just rebooted it. Try and look at the readings when it's acting up. The best thing to do is rule things out. Try connecting direct to the modem with a computer, if your still having problems, try a different computer. If still having problems it may be an issue with the modem itself.
  19. Nov 24, 2013 at 8:48 PM
    #1579
    Monster Coma
    Corey
    Yes and I'll have to check and the modem could be old.. Think we've had it a while now
  20. Nov 30, 2013 at 4:30 PM
    #1580
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Maybe I should ditch my ISP and just tether from my phone from now on.
