It seems the TRD Sport is better......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MudFlap, Dec 30, 2012.
  1. Jan 1, 2013 at 6:23 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Hino came with every 2005 - 2008 TRD Sport and DCLB truck. (my truck has Hino also I got spare Hino from Larry's TRD Sport)
    People got Eaton limited slipp when they requested Limited Slip as option from TRD parts catalog.
    IMHO
    Truetrac and Detroit are two different system.
    Truetrac is limited slip, capable of shifting power between left and right axle.
    Also it's bias based, that means slipping wheel has to have some traction for non slipping wheel to have power. Negative of that design is that, if one wheel is in the air, with Truetrac, truck is going nowhere. This is what all those videos showing how locker is better then limited slip are based on.
    However, if you into more speed driving, or your truck is daily driver you most likely will be happier with Truetrac. For heavy offroading Truetrac itself is not the best option.
    That is where Detroit locker comes. It's heavy duty and it will power both axles at the same time no matter what. Great for rock crawling offroading. However, if you daily drive truck it will feel like somebody is crashing to the rear of the truck very time you take a turn. And parking is odd experience.
    That's where ATRAC/TRAC comes in play. In old days when you got one wheel in air with Truetrac, you would slightly tap brakes and that would help Truetrac to shift power, on newer trucks ATRAC/TRAC system will do this for you and only apply brakes to wheel in the air. ( perfect!)
    Added benefit should be that Truetrac will smoth out wave like power patter on traction control which is what makes traction control useless in super slick conditions. (sorry David K. But it's true)
    So if I had 2009+ Tacoma with Traction control I will look into installing Truetrac before any lockers. Especially if truck is dual purpose (daily driver + ocasional offroad).
    For offroad only vehicle I would go with Detroit.
    On side note: Ford raptor comes with Torsen , and Another company (wavetrac) made version of gear limited slip but improved:
    http://www.fordraptorforum.com/f5/new-limited-slip-differential-coming-raptor-front-end-11892/
    I hope that helps.
  2. Jan 1, 2013 at 6:57 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    That actually clarifies a lot of posted mis-information. So then, to keep this moving forward. Can you break down which year / model trucks have which rear ends. Explaining, the which have 8.4 and which have 8.0, do all 4x4 have 8.0, all 4x2 have 8.4. This may save someone from buying an LSD for converting and getting the wrong one.
    FWIW, I was trying to decide if I make an upgrade which LSD to go with. Your explanation of the ALSD and trutrac confirmed my thoughts.
    PK
  3. Jan 1, 2013 at 8:57 AM
    BlueT
    NorthEast
    Best website that explains Toyota differentials is
    http://home.4x4wire.com/erik/diffs/
    IMHO: newer SR5 or TRD Sport with Truetrac is much better all around deal then Offroad.
    Price difference covers the Truetrac install and removes worry about exploding rear end.
    So you will keep up with TRD Offroad that has e-locker, and will be there in case TRD OR needs tow with broken rear diff ;)
  4. Jan 2, 2013 at 5:26 AM
    PMK
    Florida
    10 DCLB TRD Sport
    That is a good link. Honestly, I had visited it prior to some of these posts. Overall, pretty good, but still there is some confusing information. examples, like the 8.4 gears measure 8.0, there are early style diffs with small bearings and later diffs with large bearings, and compounding things, the 2013 Detroit catalog ends it's listing for the gen 1 trucks, yet people have installed locker and truetracs into gen 2 diffs.
    The other link is on Pirate 4x4. There is some good info there also, just not a lot in regards to newer Tacomas. The guy on Pirate also is always using a claw hammer to accomplish his work. Smart for info, but I question his primitive Pete methods. He may be great, just concerned about the photos.
    I need to take a run by the dealer and look "inside" the diff on the parts catalog. I'm guessing my diff is an open type with brace 8.4". (2010 TRD Sport 4x2 DCLB).
    Downside of swapping in a truetrac myself is this style does not use adjuster for side preload / backlash, meaning it may need shims or not. Just a pain with no shims on hand.
    PK
  5. Jan 2, 2013 at 8:04 AM
    trot
    trot Dang.
    Aberdeen Proving Ground
    18 SW TRD OR DCSB P&T
    You are correct. I had a lunchbox locker in the rear diff on my 01 Jeep XJ. I had 4.56:1 gears with non-siped 32" BFG MTs. On wet roads, it liked to slip and slide a little. On snow and ice, it wanted to go down the road sideways. On dry pavement, well, you knew it was there. LOL.
    It was a true joy offroad.
    After that experience trying to build up the XJ platform, I just sold it to someone who appreciated it and got a Taco.
    My brother has the Rubicon with the air lockers. That thing is nice, assuming you need to be locked up and don't mind the smaller vehicle.
  6. Jan 3, 2013 at 6:17 AM
    BlueT
    NorthEast
    For getting feel on limited slip install take a look over here.
    http://www.gearinstalls.com/
    ZUK has been doing this for long, long, looooooong time :)
    You can see tools he uses, what goes in and out of these differentials, checks and balances.
    Now if I were you I would buy spare diff on junkyard and send both truetrac and spare diff to ZUK. have him installed and ship it back.
    All you will have to do is swap diffs, and keep your original for spare.
    Installing Limited slip is not rocket science but requires tools and a lot of patience. If you dont feel fully comfortable you are better off outsourcing it. :D
