Its hot out, and I have a AC problem......help??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeckel7234, Aug 5, 2011.
  1. Aug 5, 2011 at 7:34 PM
    jeckel7234
    jeckel7234 [OP] Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
    05 Taco DC 4.0
    So my AC stopped working today, I was driving stopped and turned off the truck for a about a minute started it back up and there was warm air blowing out the vents, I noticed the light on the AC button was blinking so i turned it off, and then on again, the was a loud enough hum type noise for about 5 seconds, and still no cold ac, ive done some researching on here and other toyota forums, alot of people were saying it was the clutch relay, but nobody had reported the hum noise i heard, except for YIOTTA on here but he never got an answer, because of that noise am I right in assuming the compressor is bad/ is there a way to test the compressor
    Thanks again for any help
  2. Aug 5, 2011 at 7:46 PM
    JKD
    JKD Well-Known Member
    You probably need to start by having your refrigerant charge tested. If the refrigerant is low, the truck most likely has programming that won't engage the A/C clutch. Maybe that's what it's telling you with the blinky light.
  3. Aug 5, 2011 at 7:49 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    This^
    Your A/C compressor will not engage if there is not enough refrigerant in the system for it operate properly. You need to take to a shop and have them diagnose your problem. The first step in diagnosing an A/C problem is evacuating the system and recharging it to see if everything works properly, then inspecting for leaks. I've heard of compressors failing on the 2nd gens but not that often.
  4. Aug 6, 2011 at 8:34 AM
    jeckel7234
    Drew
    VA
    05 Tacoma
    I used the regular gauge handle u can use to fill up your ac system with the gauge on it, and it read high at 100psi, would my CEL come on if it were the compressor, or the high pressure level, I also just got my ultragauge in today and tried to read codes with it, no codes appeared
  5. Aug 6, 2011 at 9:18 AM
    NelsonTacoma
    Tucson, AZ
    No it would not set any codes. Was the 100psi static? or was it while running? You can't really tell how much is in the system without actually removing it and recharging it. I've evacuated some A/C systems that had a static pressure of 100psi and a running pressure of 200psi and it only took out .25lbs from the system when it actually held 2.0lbs. Normal running A/C pressures should be about 210psi high side and 30psi low side.
    Since your A/C light is blinking it sounds like you definetly have a problem that needs to be addressed.
  6. Aug 6, 2011 at 11:33 AM
    JKD
