i've about had it with these d*** pullies
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kessler89, Oct 17, 2011.
  1. Oct 17, 2011 at 11:03 AM
    kessler89
    kessler89 [OP] Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    i've replaced all 3 of my idler pullies and still get the "chirp" when it's cold or damp, it goes away after it's been running for a few min. but it drives me nuts, looks like i'm gonna have to get a belt tensioner and swap the pulley off of it and see if that cures it, if that doesn't fix it i'm probably gonna run my truck off a cliff:mad:, oh i also put a new belt on
    /rant
  2. Oct 17, 2011 at 11:07 AM
    pootermobile
    pootermobile Well-Known Member
    Florida
    06 DBL cab 4WD V6 6-speed Debadged
    De-Flapped, All-Weather Floor Mats, Blue LED dome light, De-badged, BMW shift knob, 8K HIDs in headlights and fogs, Fog light relay MOD, 3" Coil-spring spacers, 1.5" rear blocks, 17" ProComp 7033s, 285/70R17 Nitto Terra Grapplers, Ebay 7" touch screen head unit, TEKstyle snap button tonneau cover
    had this same problem on my mustang. Used WD-40 to spray on each individual pulley to figure out which was the bad one. Or are you saying that that they're all failing on after the other? because that sucks!:)
  3. Oct 17, 2011 at 11:08 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Just one of those things... ignore it. Mine has been doing it since it was new. 81k now
    Changing a pulley wont stop a belt chirp anyways. Try roughing up the belt's back surface
  4. Oct 17, 2011 at 11:11 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    haha doesn't make me feel as bad i'm right at 80k, my other pullies bearings were shot, i'm gonna try the tension pulley and then if that doesn't fix it i'm just gonna say the he!! with it and ignoor it, some have said to try soap but i was looking for a permanent fix lol, i'll update once i get the tensioner pulley on
  5. Oct 17, 2011 at 11:14 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Did you try replacing the belt first before swapping out all of the pulleys?
  6. Oct 17, 2011 at 11:17 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    yeah last year i did a new belt and top pulley, problem solved, then it started again a month or so ago so i did the 2 lower pullies, problems still there so i'm left with the tensioner pulley, we'll see what happens!
  7. Oct 17, 2011 at 11:18 AM
    mjp2
    NJ
    Damn that blows. Hope the tensioner fixes it for good, or at least for another 100k miles!
  8. Oct 17, 2011 at 11:22 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I hear ya. Those pulley are crap to begin with. To save money you can just punch the seal of the bearing and put some grease there instead of keep buying pulleys. Tensioner is probably your culprit. Worst come worst it could be alternator .
  9. Oct 17, 2011 at 11:46 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    ^yeah i did that on one of them for awhile, i'm not gonna replace the whole tensioner (looks like a PITA) just gonna try to swap the pulley off of it and go from there
  10. Oct 17, 2011 at 12:01 PM
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Just wondering what the belt # is? I bought a new belt but sold the Tacoma. If you have the 4.0 and need a new belt I'll let it go for $20 TOTAL (INCLUDES SHIPPING). I bought it new at the Toyota stealership May 31 st. Still have the receipt. It is part # 90916-A2001, or Part #: 7PK2120
    I had the 06 4x4 Dbl cab TRD 4.0L with A/C. I'm in Pa, so shipping to Ohio should be less than a day or two to get there. Let me know, Rich (814) 536-3389
  11. Oct 17, 2011 at 3:42 PM
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    Remember the tensioner pulley bolt is a left hand thread. All the other pulleys are right hand threads.
  12. Oct 17, 2011 at 4:00 PM
    Syncros
    Syncros Well-Known Member
    Clean the pulley surfaces. Just the oils from your hands when you changed it will cause it to chirp. I used alcohol and a new tooth brush.
    Dumbest thing on newer vehicles is serpentine belts IMO. V-belts never failed me, they were cheap, no need for a bunch of idlers because the tension was set by hand with a bolt setup. That said it lasted 180,000km before it started having issues, replaced the upper idler and its quiet again.
  13. Oct 17, 2011 at 11:29 PM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    amen to that, my 170,000mi subaru hasn't had one single problem with the belt system or any system for that matter, but my truck that's 6 years newer and has half the mileage sounds like a 1986 caprice when i start it (ok it's not that bad but still), i'll try to give it a good cleaning, as for the guy sellin the belt i dont need one but thanks for the offer, mines not even a year old, i'd hope they last a little longer than that:eek:
  14. Oct 26, 2011 at 11:23 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    update, replaced my tensioner pulley, didn't fix the problem, pulled the belt and cleaned all of the pullies with brake clean and put a new belt on.... chirp is gone for now, we'll see how long it lasts:rolleyes:
  15. Oct 26, 2011 at 12:58 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    consider trying a goodyear gatorback belt next time you replace one...good stuff
  16. Oct 26, 2011 at 11:32 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    If it does this again my guess is a tensioner that is weak. This over time will cause the belt to glaze from slippage. The only remedy is a new tensioner.
  17. Oct 26, 2011 at 11:43 PM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    maybe its not that. it might be your alternator replace it or spray it just to make sure.....on my truck that was the squeaky problem
  18. Oct 27, 2011 at 12:43 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    i got the belt from autozone, they're the ones that originally carried the gatorback belts, said they dont have em anymore that's what i was looking for
  19. Oct 27, 2011 at 4:41 AM
    monkeytaco
    monkeytaco Well-Known Member
    Charles
    Austin, TX
    2012 Mag Grey DCSB V6 4x4 AT Sport
    Definitely try different belts. I went through three on my Suburban before I found one that did not squeal.
  20. Oct 27, 2011 at 5:07 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Spray water on the belt, if the chirp goes away, it is either the belt or one of the pulleys is out of alignment. If the chirp stays, do the WD-40 trick an earlier poster suggested.
