I've decided on a lift setup... Does anyone see a problem?
Discussion in '1st Gen. Tacomas (1995-2004)' started by HSmith_11, Oct 13, 2016.
  1. Oct 13, 2016 at 10:17 AM
    HSmith_11
    HSmith_11 [OP] Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    I am planning to order the parts for my lift/tire setup within the next 2 weeks. I want to make sure that no one has had any problems with this setup before.
    I am ordering the lift parts from wheelersoffroad :
    Black steel center caps - Wheeler's 1.5" multi-leaf AAL - Bilstein 5100 adjustable front shocks - Bilstein 5100 rear shocks - Wheels/Tires from 4wheelparts :
    BFGoodrich KO2 33x12.5x15 - http://www.4wheelparts.com/Tires/33...aspx?t_c=13&t_s=536&t_pt=101509&t_pn=BFG37881
    Pro Comp Series 52 Rock Crawler Black Steel Wheels 15x8 6 on 5.5 w/ 3.75 BS - http://www.4wheelparts.com/Wheels/5...x?t_c=11&t_s=535&t_pt=101508&t_pn=PCW52-5883M
    P.S. I have a 2001 Tacoma Ext Cab 2.7L SR5
    Thanks
    Hunter
  2. Oct 13, 2016 at 10:21 AM
    cfayne
    cfayne Well-Known Member
    Santa Clarita
    2012 Tacoma V6 six speed FUN
    Pro Comp wheels General Grabber AT tires
    What springs are you going to run up front?
  3. Oct 13, 2016 at 10:23 AM
    HSmith_11
    Hunter
    Madison, Va
    Im gonna run the stock springs with the 5100s set at 2.5. I know it will ride stiff.. But I won't mind since im on a budget and i actually prefer a stiffer ride.
  4. Oct 13, 2016 at 10:42 AM
    cfayne
    Santa Clarita
    That could be rough! Many people here got with Old Man Emu springs, depending on your cab. I have an access cab and am running 884's. For a few extra bucks, you might want to consider it while you have everything apart anyway.
    Check out Headstong Offroad.
  5. Oct 13, 2016 at 10:44 AM
    HSmith_11
    Hunter
    Madison, Va
    Ive heard that. But i think ill be fine cause my brother ran a similar setup with stock coils. Plus, I'm not planning on doing crazy offroading, just state roads and a few backroads and farm roads. Maybe a few trails.
  6. Oct 13, 2016 at 10:58 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I'm sure down the road you'll end up changing the coils out for new ones. Depending on how many miles the stock springs already have. It's just a matter of time. But good luck!
  7. Oct 13, 2016 at 10:59 AM
    HSmith_11
    Hunter
    Madison, Va
    That's what i was thinking too but i just wanna get the base down while i have the money since I've been busy with school.
  8. Oct 13, 2016 at 10:59 AM
    HSmith_11
    Hunter
    Madison, Va
    Also, I'll post before and after photos when i get closer to the installation
  9. Oct 13, 2016 at 11:10 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
  10. Oct 13, 2016 at 5:36 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    I put brand new toyota dealer TRD coils on a set of 5100's set at 1.25...
    I actually ended up with about 2-2 1/4 inches of lift over what it sat at before (very worn) and the ride is not bad but it is a little stiff.
    I personally prefer it to the stock ride overall. it handles better on a twisty road and is -oddly- slightly smoother on gravel.
    the drawback; it does seem to get fairly choppy on the freeway at 65mph on up compared to stock.
  11. Oct 13, 2016 at 5:43 PM
    CStoy
    also it may be worth considering these as opposed to the standard 5100's with the rear lift... they are a hair longer than the 5100's and iirc valved the same.
    from what I have heard they are the more suitable pick for a truck running a small rear lift like the add a leaf you are looking at
  12. Oct 14, 2016 at 4:58 PM
    HSmith_11
    Hunter
    Madison, Va
    Ive looked at those before but most people say to just stick with the 5100s cause they are more basic and the 5125s can get confusing (i guess with the different lengths but idk)
  13. Oct 14, 2016 at 6:32 PM
    CStoy
    thats why I linked the set that wheelers has already figured out works well instead of bilstiens chart. lol! bottom line; they will both work the same...but even on stock height the shocks are borderline on length.
  14. Oct 14, 2016 at 6:49 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I've had the 5100's on the rear of my truck w/ a 1.5" AAL for a little over 3 years. I've changed my front set up going on my 3rd time now but kept the rear of the truck the same w/ the 5100's I got, which were from ToyTec.com w/ the 1.5" AAL in a rear. It was a seperate rear set up that ToyTec offered at the time. I had a 3" spacer lift 1st, w/ Camburg uppers, ditched that for the Bilstein/ Eibach 3" coil combo and now the Icon ext. travel coil overs. A lot of people said to get that extra travel that the 5125's offered and to get longer rear brake lines also. I never did and my rear shocks are holding up great. Just something to think about. Every application is different.
  15. Oct 14, 2016 at 6:54 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Anybody take their sway bar off? I still have mine on. It's the elephant in the room. Everybody I ask says they came on the truck for a reason. I wonder if it would benefit me w/ Icon ext travels and Camburg uppers? Or if that would be too much?
  16. Oct 14, 2016 at 8:08 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I took off my sway bar back in '04
    once I upgraded the front to 2.5" adj. CO's
    and have never looked back or thought of reinstalling.
    Body sway is minimal at most
    when a supportive suspension is installed.
    Only reason I'd leave it on...
    is if I were still utilizing the factory soft suspension
    and it were a designated street queen that is rarily run off road.
    While having a sway bar may let you run flatter at high speed (useless for an off road 4X)
    they are restrictive to the suspension's articulation when flexing off road.
    And forward traction is only good if the tires are on the ground.
    Basically the same reason why torsion bar suspensions are no longer popular off road.
    Torsion bars and sway bars hamper off road articulation and traction.
  17. Oct 14, 2016 at 8:22 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    96 extended cab sr5
    cxracing turbo, fic6, methanol injection, 5100s/eibachs, skyjacker leafs, rear 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, throttle body spacer, retrofit headlights, trans cooler, bed lined exterior, excessive stereo etc...
    Torsion bar comparison isnt really right but yea. No sway bar is the way to go with aftermarket suspension.
