I've got an issue....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by muliefever, Mar 2, 2016.
  1. Mar 2, 2016 at 9:45 PM
    muliefever
    muliefever [OP] Muliefever
    Tillamook, Oregon
    14' DCSB TRD
    5100's, 887', CB, 265's, FM Deltaflow
    my 2014 has a front leveling kit (2-3") not for sure. It was on it when I bought the truck. My issue it when cornering, especially on rain covered roads, the abs comes on all by itself and I literally loose control of my truck. It's friggin scary! Any ideas??
    Thanks
  2. Mar 2, 2016 at 9:54 PM
    Tacoma005
    Tacoma005 Well-Known Member
    Bellingham, WA
    2005 DCSB TRD Off-Road 4X4
    KMC Crank Rims, 30" Baja Designs light bar, HomerTaco front grill
    Most people here frown upon the spacer lift kit. If it were me, I'd take that leveling kit off ASAP. Dont know much about the ABS part of the problem, but maybe someone here can chime in on that.
  3. Mar 2, 2016 at 9:57 PM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    The wierd thing is my 2008 had 5100's and I neve had any issues?
  4. Mar 2, 2016 at 9:58 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Are you braking in corners? That is generally frowned upon, especially when conditions are more slick.
  5. Mar 2, 2016 at 10:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It isn't the ABS. It is the VSC ( vehicle stability control ). The dealership should be able to zero calibrate the system to compensate for the lift. Or you could hold the VSC Button for like 5 seconds and disable it when you start the truck each time.
  6. Mar 2, 2016 at 10:06 PM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    No. Not driver error. Simply driving and taking a corner. Nothing more. The abs kicks in, the brake does the jerking abs thing and I loose control for a second. It doesn't happen all the time. And I have never had a crazy dangerous scenario happen.
  7. Mar 2, 2016 at 10:06 PM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    Thanks Jimmy
  8. Mar 3, 2016 at 3:53 AM
    Rattlejay65
    Rattlejay65 Well-Known Member
    J.R.
    2015 Tacoma TRD Off Road
    I'd first do a quick check on the wire harnesses on all 4 corners. The wires may be stretching and losing contact (due to the lift, maybe it was not installed correctly) or wires rubbing and have a short somewhere. If all of that looks good, take it to the dealer like JimmyH said. If the wires are stretching while turning, they might lose contact making the computer think that wheel is locked and the stability control will definitely kick in, causing what you are experiencing.
  9. Mar 3, 2016 at 3:58 AM
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    Get some 5100's and join the club :bananadance::dancingbacon::broccoli::jellydance::kona::locked::taco::yay:
    muliefever[OP] likes this.
  10. Mar 3, 2016 at 8:08 AM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    no issues with your truck running 5100's?
  11. Mar 3, 2016 at 2:54 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
