I've had it with this truck! I wish the frame would just rot already.
Discussion in '1st Gen. Tacomas (1995-2004)' started by mbtech208, Jan 4, 2010.
  1. Jan 4, 2010 at 2:29 PM
    mbtech208
    mbtech208 [OP] Well-Known Member
    Peoria, Illinois
    1997 Base 4WD regular cab
    '97 2.7. First, it blew a head gasket. Fine. I pulled the head, sent it out for a valve job, put everything back together. Checked the valve adjustment, all valves good except one exhaust valve is a little tight. Ordered a replacement shim from Toyota. That is supposed to come in tomorrow. On the drive home from work today, I get a Check Engine light. Checked the codes, found P0420 Catalyst Efficiency Low. Great, now I wonder if the coolant from the blown head gasket took out the catalytic converter or the O2 sensors. Got under the truck to pull the O2 sensors and look at them, and what used to be the O2 sensor nuts are now just mounds of rust. Worse yet, the nuts holding in the sensors are attached to studs, which are a part of the (expensive-looking) exhaust pipes! So now if I remove the sensors just to look at them, I'm almost guaranteed to snap off the studs and need a whole new exhaust pipe before AND after the cat, as well as possibly needing a new cat too! AND I need a new power steering pump, because the shaft is wobbly and noisy. I wish the frame would just rust already. How I miss my 2000 SR5 V6, which only needed a light bulb in 2 years.
  2. Jan 4, 2010 at 3:57 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Sounds like an obvious solution to me...
    Get rid of it and buy something else. :)
  3. Jan 4, 2010 at 4:05 PM
    mbtech208
    Peoria, Illinois
    Yeah, but it's a lot easier to sell something without those problems, so unless I want to take a hit, I have no choice.:(
  4. Jan 4, 2010 at 4:16 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Sorry to hear about all the problems. You really take a chance buying any used vehicle, and one with 224,000 miles on it your almost guaranteed to have issues. Hopefully you got it at a good enough price to where you can get it fixed and be able to enjoy it for a few years...
  5. Jan 4, 2010 at 5:43 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yea buying used with that many miles and not expecting anything is just wishful thinking.
  6. Jan 4, 2010 at 5:49 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    salt the frame
  7. Jan 4, 2010 at 6:37 PM
    putawaywet
    putawaywet Yaris Offroader
    New Hampshire
    '17 DC TRD Off Road MT
    PB the nuts every day for a week. Then use a torch on them (a little burnzomatic should be fine) and the nuts will come right off. Buy replacements at the hardware store. A little bit of work, but cheaper than a new exhaust pipe.
  8. Jan 4, 2010 at 6:44 PM
    blackxpress
    blackxpress Well-Known Member
    Jeff
    Carlisle, OH
    98 SR5 2WD Xcab
    Let me see if I've got this right. Your truck is 13 yrs old and has 224k miles on it and you're bitching because it has a couple of little problems. Get yourself a new exhaust system and some new O2 sensors and be glad it didn't sling a rod.
  9. Jan 4, 2010 at 7:18 PM
    mbtech208
    Peoria, Illinois
    I like that idea.
  10. Jan 4, 2010 at 7:19 PM
    mbtech208
    Peoria, Illinois
    Are you going to give me the money to do that? I just spent all my money getting everything else fixed.
  11. Jan 4, 2010 at 7:28 PM
    Janster
    Jandy
    Lancaster, PA
    Want some cheese?
    [size=-4]......with that whine?[/size]
    :p:p:p
    Chop chop! You've got work to do!! Work to earn money to fix that old truck of yours. She's old .... 13 year old truck is like being 80 years old (in human years).
  12. Jan 4, 2010 at 7:35 PM
    mbtech208
    Peoria, Illinois
    Like a few friends sitting at a bar, I thought I could share a little of my misery without getting it thrown back in my face. I'm a college student and I bought an old, high-mileage Toyota truck because it was about all I could afford. I thought I wouldn't have to spend as much to keep it running as a domestic vehicle, due to my past experiences with Toyota and Honda. Now it's me "whining" and "bitching" and "wishful thinking" and "just buy this and this and this," well, I simply don't have the resources you guys seem to.
  13. Jan 4, 2010 at 7:37 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Buy a new one and then instead of spending a couple hours removing rusted nuts you can spend hours arguing with some lame ass service manager about doing a half dozen or so TSB's :cool:
  14. Jan 4, 2010 at 9:50 PM
    Janster
    Jandy
    Lancaster, PA
    Been there done that. I went to college. I lived in the dorms. I had a 1980 Plymouth Horizon back then. I worked on it with a $10 wrench set from Kmart in the dorm parking lot. I had to hit the starter with a hammer to get it to start because I didn't have the time nor the money to fix it. It ran on 3 cylinders most of the time and I ran it into the ground. I made due with what I had...and I worked at McDonalds making $7 an hour. I was supporting myself for books & extras.
    Oh wait...am I that old? Computers & the internet didn't exist back then so I couldn't whine & cry to anyone but myself.
    Just yankin your chain man...... you're not the only person who's fallen on hard times. Some of us have lived through it and now we're older and making every effort never to see those times happen again.
    Responses like this kinda piss you off don't they? Well - it's good for ya!! Makes you wanna get out there and get something done!!
  15. Jan 4, 2010 at 10:10 PM
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    Well Snapper at least now you know what not to do. You could always just drive it the way it is....with the damn code until you get enough coin to do it right or trade it for another yota with the same value. Either way, good luck with the truck. :D
  16. Jan 4, 2010 at 10:25 PM
    joby
    joby Member
    joby
    idaho
    00 limited trd 4x4
    black wheels bfg km2s small lift
    i had the same prob cuz i knocked the guts out of my cat. i cut the o2 sensor off and straight piped mine:) you only need the upstream sensor to manage the fuel oh ya and i fixed my check engine light with a small inexpensive piece of electrical tape;) good luck bro
  17. Jan 4, 2010 at 11:00 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    hey mb hang in there I know whats it like and sometime we just need someone to let us vent... and no matter what any of the guys or gals on here say at we've all gone through what you’re going through and we'll probably go through it again so hang in there and if you must sell then go for it but I think if you take a moment and think about it you'll see your better off finding the $$$$ to fix what you have than to embark on an unknown
  18. Jan 4, 2010 at 11:17 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    if it gets you to a and b then your good... worry about college not what you drive
  19. Jan 5, 2010 at 9:37 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    [​IMG] try this
  20. Jan 5, 2010 at 9:55 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    jbob,
    According to Toyotas commercials ..after that "event'..only thing left will be Taco's and roaches;):rolleyes::rolleyes:
    MB, coming here for sympathy is just like going to the "bar"....all will listen BUT most will "give it to you" just like Janster did;)..
    Yes it sucks BUT if it can be driven with that stupid orange lite on..drive it:cool: I am....too dam cold to replace that front sensor unless I'm going to ad all my other "Mods" into the scheduled visit....;)
    S
