Jack recommendation for Tacoma with a 3 inch lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Patton250, May 1, 2021.
  1. May 1, 2021 at 6:24 AM
    Patton250
    Patton250 [OP] Bible and Gun Clinger
    Brett
    Tampa Florida
    2021 Tacoma SR5
    So obviously the stock jack in my Tacoma will not work since I have lifted it 3 inches. What do you guys recommend for a portable jack that doesn’t take up much room in the truck but will lift the truck so you can change tires? Thanks.
  2. May 1, 2021 at 6:29 AM
    Bishop84
    Bishop84 Well-Known Member
    Stock jack works fine you lift from the axles. They only change height with tires and every 1" of tire is 1/2" of axle lift.
    whatstcp, 71tattooguy and Skydvrr like this.
  3. May 1, 2021 at 6:35 AM
    Patton250
    Brett
    Tampa Florida
    2021 Tacoma SR5
    It was my understanding you’re supposed to lift the truck from the frame not the axle. I guess I was wrong. Thank you.
  4. May 1, 2021 at 6:59 AM
    Bishop84
    It takes a lot longer. It really depends, Ive never jacked from the frame as even stock its very high and less stable. You have to jack the frame up and unload the suspension, where as with axles it raises the wheels instantly.
    There's also a center jacking point which really speeds things up, its located on a cross member near the oil drain plug.
  5. May 1, 2021 at 7:04 AM
    Gasguy
    Gasguy Member
    2016 TRD DCSB 4X4 MT
    Couple blocks of wood under the Jack works for me…..
  6. May 1, 2021 at 7:10 AM
    Fpc187
    Fpc187 Well-Known Member
    Jack from the axles...buy a small portable hydraulic jack. They are typically less than 40 bucks
    Patton250[OP] likes this.
  7. May 1, 2021 at 7:14 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4, 2011 Camry LE
    Overbuilt daily driver
    This. Not sexy, but functional and inexpensive.
  8. May 1, 2021 at 7:22 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    Grindstone likes this.
  9. May 1, 2021 at 3:00 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Axles are fine. Most lift from the LCA, the diff or just under the rear ubolts.
    Patton250[QUOTED][OP] likes this.
  10. May 1, 2021 at 4:58 PM
    Eldiablo
    Eldiablo New Member
    I have a unijack and love it, you can look at it on Amazon
  11. May 4, 2021 at 10:27 PM
    dennguy08
    dennguy08 Well-Known Member
    2018 Cement Tacoma TRD OR
    Safe Jack, bottle jack
    hrivera007 likes this.
  12. May 4, 2021 at 11:58 PM
    Ncska21
    Ncska21 Well-Known Member
    Nils
    New England
    17 Pro
    cut up some 2x4s
  13. May 5, 2021 at 12:24 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    May not be an option for you but I use my highlift extreme and jack from the bumpers and sliders if I'm not at home with the big floor jack.
