Jacking up the Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 45longcolt, Jun 28, 2008.
  1. Jun 28, 2008 at 3:07 AM
    45longcolt
    45longcolt [OP] Well-Known Member
    DFW Area
    2020 Off Road
    Is it OK to use a roll around cradle type jack under the back diff to raise the rear all at once? I know mechanics used to do this with the older tanks we used to drive but can modern vehicles with thinner steel everywhere handle this weight?
    I went to get my tires rotated at a local NTB and the mechanics used a jack to raise the rear as I guess the big floor jack you run the vehicles up on only raises the front/middle section.
    I'll be taking it back to them on Sunday to re-do the balance for the third time! Truck only has 11K miles on it and this was the second rotation of the Rugged Trail tires.
  2. Jun 28, 2008 at 6:17 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    That is how I lifted mine, if it is correct of not I don't know. What is the problem with the balancing?
  3. Jun 28, 2008 at 9:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I use a typical hydraulic floor jack (craftman) and I put it directly under the rear diff.....jack up both sides at the same time. I'll put jackstands underneath the U-bolt plates on each side. You should avoid jacking up on or supporting the axle tube itself.... (when i'm rotating tires)
    Have the guy at NTB rotate the tire 180 degrees on the machine and spin it again to verify and fine tune the balance.....
  4. Jun 28, 2008 at 5:17 PM
    45longcolt
    DFW Area
    2020 Off Road
    I've read that these Tacoma wheels/tires are hard to balance sometimes due to the TPMS dohickey. The second balance was much better than the first but it still has a rather noticeable shimmy from about 52+ MPH. When I took it in, no shimmy whatsoever.
    Janster, I will suggest that to them as a means of speeding up their trail and error process that seems to be going on here. Thanks for the tip!:)
