JAKE's 06 SOLID AXLE SWAPPED DCLB EAF & BS build
Discussion in '2nd Gen. Builds (2005-2015)' started by 3378jakesr5, Nov 26, 2015.
  1. Mar 16, 2016 at 10:35 AM
    #2861
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    That depends on how much you cut Your fenders
  2. Mar 16, 2016 at 10:36 AM
    #2862
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    How much lift do I need for 285s?
  3. Mar 16, 2016 at 10:36 AM
    #2863
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Again, do you want to cut or no?
  4. Mar 16, 2016 at 10:38 AM
    #2864
    Tacoma SS
    Denver
    None :sawzall:
  5. Mar 16, 2016 at 10:38 AM
    #2865
    3378jakesr5
    3378jakesr5 [OP] AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    i am assuming that you did not have to trim studs because you have the dimpled pieces on the back side of the wheel. and @Tacoma SS you better pull a wheel and see if you have those off set dimples in the after market wheels or you are doing some wheel stud trimming
    Tacoma SS likes this.
  6. Mar 16, 2016 at 10:39 AM
    #2866
    Tacoma SS
    Denver
    I'm already paranoid about having wheel spacers on. If I can at least move to a smaller spacer I will feel much better
  7. Mar 16, 2016 at 10:41 AM
    #2867
    alee891
    Austin
    Black Hills
    Tacomaless
    I don't want to cut tho.
  8. Mar 16, 2016 at 10:42 AM
    #2868
    geekhouse23
    No trimming. Just some light tapping with a rubber mallet to get the spacer to seat dead center on the threads so everything was installed properly. I'm super anal about installing important stuff and I don't want to be another casualty of those running spacers..super nervous about them being on the rig..
  9. Mar 16, 2016 at 10:42 AM
    #2869
    geekhouse23
    265/75
  10. Mar 16, 2016 at 10:43 AM
    #2870
    3378jakesr5
    jake
    littleton colorado
    putt putt can not handle very much so you might have to stick with a 35... sorry bud
  11. Mar 16, 2016 at 10:45 AM
    #2871
    Tacoma SS
    Denver
    You hammered the studs deeper into the hub? That doesn't seem safe. Unless I'm misunderstanding what you did
  12. Mar 16, 2016 at 10:48 AM
    #2872
    alee891
    Austin
    Black Hills
    Tacomaless
    :anonymous:
  13. Mar 16, 2016 at 10:48 AM
    #2873
    geekhouse23
    Lightly tapped on the spacer to get it to seat dead center on the hub assembly so when I torqued the acorn nuts down, the spacer was seated PERFECTLY.
  14. Mar 16, 2016 at 10:50 AM
    #2874
    Tacoma SS
    Denver
    But your wheel studs are longer than .75, so didn't they stick out a little bit? That's what I was wondering about, if your wheels had little indents for the studs to go into or how you avoided that
  15. Mar 16, 2016 at 10:51 AM
    #2875
    3378jakesr5
    jake
    littleton colorado
  16. Mar 16, 2016 at 10:52 AM
    #2876
    Tacoma SS
    Denver
    :threadjacked:
  17. Mar 16, 2016 at 10:53 AM
    #2877
    3378jakesr5
    jake
    littleton colorado
    im no longer in need of wheel spacers in the front which is the worst place for them and so......:infantry:
  18. Mar 16, 2016 at 10:54 AM
    #2878
    Tacoma SS
    Denver
    Are the spacers that you have on the front 1.25?
  19. Mar 16, 2016 at 10:54 AM
    #2879
    3378jakesr5
    jake
    littleton colorado
  20. Mar 16, 2016 at 10:57 AM
    #2880
    Tacoma SS
    Denver
    The only reason that I would want wheel spacers on the front is so my tires are parallel. But if I am able to move down to a .75 space or in the rear, I might not bother with the front. I will flex out my rear axle pretty soon here and see if I can go smaller. If I have to stay with 1.25 I will take your spacers
