JAKE's 06 SOLID AXLE SWAPPED DCLB EAF & BS build
Discussion in '2nd Gen. Builds (2005-2015)' started by 3378jakesr5, Nov 26, 2015.
  1. Jan 4, 2016 at 11:30 AM
    #981
    12TRDTacoma
    Rob
    Concordia
    Boosted
    When talking about bump spacing, it's best to measure the entire bump from its mounting base down to the point where it first contacts. I believe the wntire bump measures 4" total. With washers the most you should be able to run while being able to mount a nut on it through the frame plate is 4.5" total top to bottom. I can go out there and measure if you want, but if you are getting fox shocks and want to run these, they will take the brunt of the bump well before you bottom out.
    If you ever do bottom out hard, just know the fox shocks have an integrated bump stop on their shaft as well, placed there as a failsafe.
  2. Jan 4, 2016 at 11:42 AM
    #982
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    I'm running the extended icons 15.9 collapsed 26.8 ext...Mainly just doing slow crawling and maybe some fast washboard, but nothing too extreme.. I just want to keep from bottoming out these new shocks.. Thanks for your input greatly appreciated
  3. Jan 4, 2016 at 11:46 AM
    #983
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh man, you are running 11" shocks? What size lift leaf springs over stock are you running for those? That's close to an inch over the 10" stroke shocks that I run.
  4. Jan 4, 2016 at 11:55 AM
    #984
    303tacoma
    Rebecca
    Dakars full pack
  5. Jan 4, 2016 at 11:57 AM
    #985
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dakars untouched? I know they offer them in two different flavors if I remember right.
  6. Jan 4, 2016 at 11:58 AM
    #986
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    I don't need longer bumps if I do the shock tower relocate correct @3378jakesr5?
  7. Jan 4, 2016 at 11:59 AM
    #987
    303tacoma
    Rebecca
    Yes gained about 2.5"
  8. Jan 4, 2016 at 12:00 PM
    #988
    303tacoma
    Rebecca
    Sorry for the thread jack Jake
  9. Jan 4, 2016 at 12:04 PM
    #989
    12TRDTacoma
    Rob
    Concordia
    Boosted
    PM me. We can further figure it out if you want to set up bumps. I didn't realize this wasn't your thread.
  10. Jan 4, 2016 at 12:05 PM
    #990
    3378jakesr5
    3378jakesr5 [OP] AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Correct.
  11. Jan 4, 2016 at 12:05 PM
    #991
    3378jakesr5
    jake
    littleton colorado
    haha you guys are fine.
  12. Jan 4, 2016 at 12:15 PM
    #992
    303tacoma
    Rebecca
    Jake said its fine we're all learning something.. What did you have in mind I was going to just stack more washer for a total bump height of 5".. From my measurements I need 3"collapsed bump
    3378jakesr5[OP] likes this.
  13. Jan 4, 2016 at 12:17 PM
    #993
    303tacoma
    Rebecca
    Or if you have something in mind that's needs to be fabricated Jake is the man...
  14. Jan 4, 2016 at 12:20 PM
    #994
    12TRDTacoma
    Rob
    Concordia
    Boosted
    3" collapsed measured from the frame? Did you use my math solution for that or did you use the suspension to cycle your suspension to determine that?
    The only way you would be able to space out those silverado bumps to 5" would be to use some sort of alternative mounting plate at the top. 4.5-4.75" is the max they can go before you dont have any stud left to go through the upper frame plate.
  15. Jan 4, 2016 at 12:25 PM
    #995
    303tacoma
    Rebecca
    Yes I used your math solution and I popped the studs out and was going with an Allen head bolts little longer so I could stack more washers..
  16. Jan 4, 2016 at 12:42 PM
    #996
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh nice! That is smart thinking there! 3" collapsed. If you need more washers just stack as needed and you'll be good to go for an overall bump height of 5".
  17. Jan 4, 2016 at 12:44 PM
    #997
    303tacoma
    Rebecca
    Ok so I am on the right track then :)
    12TRDTacoma[QUOTED] likes this.
  18. Jan 4, 2016 at 12:47 PM
    #998
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes sir you are. The biggest obstacle for me I never overcame (primarily because I never attempted to pop the stud's out) was obtaining 5" or however much I needed at the time to get the full collapsed length I needed. I remedied it by going full hydro bumps and the rest was history. :D
    Unless you plan on hardcore wheeling, the Silverado bumps will be overkill for our trucks and feel like pillows on harder suspension hits. You are set to go bud! :thumbsup:
  19. Jan 4, 2016 at 12:55 PM
    #999
    303tacoma
    Rebecca
    Thanks again for your help and by the way you mean yes ma'am lol
  20. Jan 4, 2016 at 1:03 PM
    #1000
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh shoot, I didn't see the name when I was talking to you. Funny girl. Hahaha!
    303tacoma[QUOTED] likes this.
