JAKE's 06 SOLID AXLE SWAPPED DCLB EAF & BS build
Discussion in '2nd Gen. Builds (2005-2015)' started by 3378jakesr5, Nov 26, 2015.
  1. Feb 5, 2016 at 6:59 AM
    #1621
    CO MTN Steve
    CO MTN Steve Well-Known Member
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    Lifted, Armored, needs more lights.
    So Ramon has set up a Dual Battery GB. All I want is the digital readout on Plug, do you know where I can get that?
    Later this summer Jake I want a new cage for a 31M battery for truck.
    Here is Pelfry's http://www.pelfreybilt.com/#!2005battery-cage/c50f
  2. Feb 5, 2016 at 7:02 AM
    #1622
    3378jakesr5
    3378jakesr5 [OP] AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Amazon has the digital read out http://www.amazon.com/gp/aw/d/B001R...ge+display&dpPl=1&dpID=41fZBDW2pqL&ref=plSrch
    And the cage is not that bad.
    CO MTN Steve[QUOTED] likes this.
  3. Feb 5, 2016 at 7:16 AM
    #1623
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Which 31m battery you gonna go with? I am curious now that Die Hard's is gone.
  4. Feb 5, 2016 at 7:17 AM
    #1624
    3378jakesr5
    jake
    littleton colorado
    Let me go down to the shop and see what the specs are on the 31 I can get. Give me a second.
  5. Feb 5, 2016 at 7:28 AM
    #1625
    CO MTN Steve
    RaMbLiN' CoLoRaDo
    2015 Taco DCSB Blue
    I need to figure that out, so pissed I missed that the diehard was going away.
  6. Feb 5, 2016 at 7:30 AM
    #1626
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    I could use to add a second battery. Was thinking a deep cycle under the bed someplace. I kinda wanted a fuel tank under there also, like a FJ60 tank.
  7. Feb 5, 2016 at 7:35 AM
    #1627
    3378jakesr5
    jake
    littleton colorado
    image.jpg The one with the arrow is what I'm putting in the trailer not what you want in your truck. image.jpg These are the "optima" quality battery and can be mounted any where. The first pic is there stock ones but might not be good for bouncing down the trail.
    Your wanting to look at the 31 and 31p also go off of the ref C.A. 32deg that's what the diehards go off of.
    Let me know if you need battery's unless you can get a good deal from Toyota.
  8. Feb 5, 2016 at 8:17 AM
    #1628
    Gramps
    Gramps
    07 TRD DC 4x4
    Interesting... the die hard is 1150 CCA @32f. LoOKs like nothing could touch that battery.
  9. Feb 5, 2016 at 8:20 AM
    #1629
    3378jakesr5
    jake
    littleton colorado
    I bet you that it has very thin lead plates though witch is great for holding the large amps but it makes its recharge life really bad.
  10. Feb 5, 2016 at 8:26 AM
    #1630
    Gramps
    Gramps
    07 TRD DC 4x4
    Interesting...
  11. Feb 5, 2016 at 9:21 AM
    #1631
    thefatkid
    Brian
    Colorado
    2004 thingy
    Reserve is all you should care about
  12. Feb 5, 2016 at 9:23 AM
    #1632
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    Wouldn't you want a secondary battery for running accessories like lights, winch, etc to be a deep cycle battery? There's no need for millions of cold cranking amps if it's not the battery that's going to be used to start the truck.
  13. Feb 5, 2016 at 9:27 AM
    #1633
    3378jakesr5
    jake
    littleton colorado
    That why I did a dual battery. I have more reserved amp hours and I can self jump my self.
  14. Feb 5, 2016 at 7:05 PM
    #1634
    Gramps
    Gramps
    07 TRD DC 4x4
    Jump yourself.... hehe
    303tacoma likes this.
  15. Feb 5, 2016 at 7:07 PM
    #1635
    3378jakesr5
    jake
    littleton colorado
  16. Feb 5, 2016 at 7:08 PM
    #1636
    Gramps
    Gramps
    07 TRD DC 4x4
    You got an apple and a coke with heims? Sweet!!!!
  17. Feb 5, 2016 at 7:08 PM
    #1637
    3378jakesr5
    jake
    littleton colorado
    Red Baron likes this.
  18. Feb 5, 2016 at 7:09 PM
    #1638
    3378jakesr5
    jake
    littleton colorado
    Yah! Didn't you know you get free hiems with every Coke and apple combo purchase.
  19. Feb 5, 2016 at 7:09 PM
    #1639
    3378jakesr5
    jake
    littleton colorado
    And I had no banana for scale.
  20. Feb 5, 2016 at 7:19 PM
    #1640
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    you're gonna wear out that dimple die machine aren't you?
