JBA Long Tube Headers Review & Install Instructions
Discussion in 'Performance and Tuning' started by 05RedTaco, Nov 21, 2012.
  1. Jan 21, 2013 at 12:23 PM
    rrh_2
    rrh_2 Well-Known Member
    Richard
    Devine texas
    05 tacoma 4x4 sr5 dc
    6" pro comp stage one lift ome 885's, 5100's,bhlm, billet grille, lights behind grille, k&n cai , tinted Led tails, tinted 3rd brake light, Lotek a pillar, color matched grille mirrors and door handles, trd seat covers, blacked out windows, color matched engine cover, in-dash flip out screen 2 10'' kicker subs
    This is starting to be a pain in the ass.. Have to cut one of the bolts that bolts the old header to the y pipe off
  2. Jan 22, 2013 at 2:13 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Exhaust hardware is almost always a pain. An oxy-acetylene torch helps or something a couple cans of aerokroil/PB blaster/freeze off. Let us know how it sounds after!
  3. Jan 22, 2013 at 2:21 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  4. Jan 22, 2013 at 2:29 AM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Have the JBA headers. Good stuff.
  5. Jan 22, 2013 at 7:43 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    TWO bolts which connects the stock exhaust manifolds to the Y pipe broke off when I installed my set... It will be royal pain if I ever go back to stock :(
  6. Jan 22, 2013 at 9:32 AM
    rrh_2
    Richard
    Devine texas
    Yea it was a lil harder than I thought.. I ended up just splitting that nut with a chisel
  7. Jan 22, 2013 at 4:37 PM
    rrh_2
    Richard
    Devine texas
    What's the trick on getting the drivers side in
  8. Jan 22, 2013 at 4:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Some people have removed the steering linkage. Others get lucky. The easiest way for me was by removing the two studs in the head, which are closest to the firewall. One on top and one on bottom.
    It gives you more wiggle room. Then once you have the header on, re-install the studs as well as other hardware.
  9. Jan 23, 2013 at 8:50 AM
    rrh_2
    Richard
    Devine texas
    Ill try that.. It'll be another day anyway.. Had to replace an o2 sensor
  10. Jan 24, 2013 at 5:49 AM
    05RedTaco
    Tony
    Scottsdale
    I didnt remove steering linkage or studs. Trick is to remove the bracket which bolts to the header flange on the bottom....
  11. Jan 24, 2013 at 5:53 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Completely forgot about that bracket, since I don't have it/either anymore. Good point.
  12. Jan 24, 2013 at 8:02 AM
    rrh_2
    Richard
    Devine texas
    I got em in and just picked up a new o2 sensor.. Holy shit those things are expensive so I should be finished soon.. I guess the factory cross threaded the old sensor when they built my truck.. The threads on it were beyond repair
  13. Jan 24, 2013 at 8:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If ever in the future you need another one, Amazon.com has them at a much better price.
    Stryker420 likes this.
  14. Jan 24, 2013 at 3:51 PM
    rrh_2
    Richard
    Devine texas
    I like them but it made that ticking sound that we always have way way worse
  15. Jan 25, 2013 at 5:25 AM
    #35
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
  16. Jan 25, 2013 at 6:50 AM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That will be a totally quieter tick than if an exhaust leak is found.
    And if people think the factory injectors are loud, try installing some aftermarket injectors. They get much louder. O_O
  17. Jan 25, 2013 at 7:00 AM
    #37
    rrh_2
    Richard
    Devine texas
    That's the only thing that disappoints me about them.. I'm fixing to go over everything
  18. Jan 25, 2013 at 8:39 AM
    #38
    rrh_2
    Richard
    Devine texas
    Done finally no leaks no tick!!! It smells like ass tho
  19. Jan 25, 2013 at 9:38 AM
    #39
    05RedTaco
    Tony
    Scottsdale
    LOL sure does. I have no cats and on cold startup it blows shit load of white smoke :D Makes up for all those hybrid cars driving around...
    Stryker420 and rmepilot like this.
  20. Jan 25, 2013 at 9:45 AM
    #40
    rrh_2
    Richard
    Devine texas
    Haha it did for a lil while but now it doesn't stink anymore it all burned off I guess
