JBA LT's, O2 extens, and O2 sims, stil have check engine light
Discussion in 'Performance and Tuning' started by Brockin07, Dec 10, 2012.
  1. Dec 10, 2012 at 5:46 AM
    Brockin07
    Brockin07 [OP] Member
    Gadsden, AL
    Red PreRunner TRD Sport
    Air intake, exhaust, OMU 3' lift, sound system, Headlights, grillcraft grills
    I just installed the JBA LT headers, O2 simulators, and O2 extension harnesses and im getting p0037 and p0057 codes, They say Circuit Low Bank ????
    I bought everything from URD. I dont know whats wrong, i thought i bought everything to make this work right. I put the O2 sensors in the collector hole and plugged the upper primary hole. Please help.
  2. Dec 10, 2012 at 8:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Bank 2 sensor 2 is your driver side O2 sensor. The rear sensor, on the driver side which is plugged into the O2 simulator.
    Something is wrong with your connection possibly.
    Edit*** I originally only checked for the P0057. The P0037 is the pasenger side O2 as well. Something isn't connected p properly with your O2 simulator.
