JBA UCAs or Light Racing UCAs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 88nitro305, Sep 22, 2017.
  1. Sep 22, 2017 at 7:41 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Lol. What about the additional adjustments. Spc still wins.
  2. Sep 22, 2017 at 7:42 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    My local TW members pointed me in the right direction for a reputable alignment shop when I got my aftermarket UCAs. :)
    Blackout14 likes this.
  3. Sep 22, 2017 at 7:46 AM
    JayRolla
    Colorado Springs
    Also need to remove the lower ball joint nut. So that's 5 total nuts/bolts. Ha
  4. Sep 22, 2017 at 7:46 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Heck yeah. It's good to have those things lined up so you can get whatever you want installed after purchase. Plus we have a local Tacoma guy who is doing an LS Twin Turbo swap to his Tacoma .... so he can pretty much do anything mechanically that anyone needs. :D
  5. Sep 22, 2017 at 7:50 AM
    JayRolla
    Colorado Springs
    It's all entry level. They even work with extended travel setups.
    It's entry level until you go SAS.
  6. Sep 22, 2017 at 7:51 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Awesome, let me know when you guys come down. Maybe we can all meetup.
  7. Sep 22, 2017 at 7:52 AM
    JayRolla
    Colorado Springs
    I meant extended travel. My bad. Exited to late.
  8. Sep 22, 2017 at 8:02 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I didn't like the fact that the SPCs were adjustable. It may be a nice feature, but that seems to be an extra possible point of failure. Or at least your alignment getting knocked out of whack much easier since it slides to adjust and is then locked down with a nut.
  9. Sep 22, 2017 at 8:05 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    5" lift running stock UCAs​
    Come at me bro​
  10. Sep 22, 2017 at 8:08 AM
    JayRolla
    Colorado Springs
    Isnt it the ball joints ability to droop further than the stock UCA that allows it to work with extended travel? The built in additional caster just pushes the arm back a bit 2* to help get better alignment specs.
    But what I have found this also clocks the suspension back a bit, causing the tire get closer to the firewall causing more rubbing on the cab mount and firewall.
    I have found with the SPC's adjusted forward (taking away caster), then completely maxing out the LCA's cam bolts and finally using the SPC's camber adjustment to finalize the alignment. This gives you 2* caster at alignmment but also gives you almost 2" additional clearance between the tire and firewall. Making it a lot easier to fit 35's with a lot less cutting or hammering of firewall.
  11. Sep 22, 2017 at 8:09 AM
    JayRolla
    Colorado Springs
    Been running them many years with no issues. If you tq the UBJ bolt to around 200ftlb they do not slide a bit. And I have jumped my rig.
  12. Sep 22, 2017 at 8:12 AM
    ChadsPride
    COME AT ME!!!! :p
  13. Sep 22, 2017 at 8:13 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Actually less money, as JBA's are cheaper
  14. Sep 22, 2017 at 8:14 AM
    JayRolla
    Colorado Springs
    ITs a bent bar, welded, poly bushings with a ball joint. They are priced how they should be. Everything else is over priced for what it really is. Ive seen $700 uniball crap ball joints loosen up in less than year, squeak like crazy and just push the tire into the firewall with its "additional caster".
  15. Sep 22, 2017 at 8:48 AM
    #35
    JayRolla
    Colorado Springs
    I was just saying they work with extended as "entry level". Never was arguing that some wont work with extended travel. Just because they are cheaper does not mean they are entry level is what I was getting at.
    And thats why I love the SPC's. I have actually clocked mine completely forward and then maxed the LCA's. Putting them near stock UCA location. This has given me enough caster for good daily driving and major clearance at the firewall. My rig will clear 35's on the street with no modification to firewall where with them set at the +2* caster location I had major issues just running 33's. I tested almost every ball joint location on them and had about 4 alignments in a 1 month period before I got them tuned perfect. No rubbing on or offroad at all when wheeling now.
    My brother runs Icons on his 4th gen 4runner and is having major issues wheeling on 33's because they slam into the firewall. He had more clearance on stock UCA's. They also have completely loosened up in 1 year time. Pretty sad. He is upgrading to the delta joints but $250 for a pair of ball joints is pretty crazy.
  16. Sep 22, 2017 at 9:23 AM
    #36
    88nitro305
    88nitro305 [OP] Well-Known Member
    Tom
    Vermont
    2012 white DCSB TRD OR
    Sweet thanks for all the responses guys! I have been busy all morning and haven't had time to check in and read more about the 2 that I'm looking at.. I'm kinda leaning towards the JBAs
  17. Sep 22, 2017 at 10:03 AM
    #37
    JayRolla
    Colorado Springs
    Yeah either way you will be pretty set. For the prices both are very good arms. I got my SPC's when they where super low on price. Like $340 shipped years back.
  18. Sep 22, 2017 at 10:54 AM
    #38
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Just gotta say Total Chaos UCAs FTMFW!!! :headbang:
    Oh BTW Amsoil is the best earl Scott ;) @scottalot
  19. Sep 22, 2017 at 11:08 AM
    #39
    Lord Helmet
    Nick
    '24 X3 M40i
    LOL :cheers:
  20. Sep 22, 2017 at 2:43 PM
    #40
    88nitro305
    Tom
    Vermont
    Well, I went with the JBA's!
    JayRolla, Lord Helmet and Blackout14 like this.
