JBL sub/amp replacment
Discussion in 'Audio & Video' started by Bfoster133, May 8, 2011.
  1. May 8, 2011 at 2:27 PM
    Bfoster133
    Bfoster133 [OP] If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    Does anyone know how to use the stock wires that run to the sub to attach to a new sub?
    there are two sets of wires running to each terminal on the jbl sub
    set one
    (red,yellow
    set two
    (black,green)
    i just need to know which wires do what, the red i assume is positive and black negative but what about the yellow and green?
  2. May 8, 2011 at 2:31 PM
    Iceman2448
    Iceman2448 Well-Known Member
    Ga
    5100 OME 3" front lift 1.5 rear All Injen cold air Intake N-Fab light bar Hella 500FF lights Alpine Heand unit Type R 10 sub r500.1 amp Alpine 6x8 comps up front Alpine 6x9 in rear
    Red and yellow. Should be power and acc power.
    Black and green should be inputs!!!
  3. May 8, 2011 at 2:32 PM
    Iceman2448
    Ga
    U can try a test light and use it on the red and yellow.
  4. May 8, 2011 at 3:39 PM
    Bfoster133
    Blake
    is it possible jbl added a dual coil sub? because that would make more sense
  5. May 8, 2011 at 4:14 PM
    Iceman2448
    Ga
    Not sure on tht!
  6. May 8, 2011 at 5:29 PM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    The wiring diagram for the older models (from ttora) implies a dual voice coil setup; however, the colors are different so not much help.
  7. May 8, 2011 at 7:43 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    With a multimeter you could find if one pair is power.
