JDFabrication Full Float Ford 9 Inch Axle Install
Discussion in 'Long Travel Suspension' started by Airdog, Jul 15, 2022.
  1. Aug 14, 2022 at 6:02 PM
    volcomstone1223
    volcomstone1223 Well-Known Member
    Lake Havasu City
    05 Taco LSupreme
    Solo DMZ
    So I’m in a situation where I bought a Tundra brake booster and master cylinder but turns out the brake booster is to large for my setup so my only option is to keep a stock Tacoma brake booster. That being said I have an ‘05 but I’d have to order a new booster and master cylinder since I tossed them awhile back. Would the best option be just to go for the camry master and an 09+ Tacoma booster? I’m running Wilwood brakes on all 4 corners and I’m re plumbing all brake lines if that matters. No ABS.
    Airdog[OP] likes this.
  2. Aug 15, 2022 at 12:59 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Not a helpful post, but I could be interested in buying the Tundra setup off you if you're selling it
  3. Nov 28, 2022 at 8:47 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    So if I was already geared to say 4.88 in the front, would the 3rd in the 9" also be 4.88 or is it different due to the size difference of the axle shafts/3rd?
  4. Nov 28, 2022 at 8:51 AM
    Airdog
    Airdog [OP] did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    You can get the Ford in 4.86 and be just fine.
    Slashaar[QUOTED] likes this.
  5. Nov 28, 2022 at 8:52 AM
    Slashaar
    Josh
    Kansas City, MO
    So it is different. :thumbsup: Thanks, probably not in the cards, but I was curious.
  6. Nov 28, 2022 at 8:53 AM
    Airdog
    Tom
    SoCal
    I’ve read you can have almost 10% difference in gear ratio between the front and back diffs and be just fine. But obviously the closer they are in ratio the better.
  7. Nov 28, 2022 at 9:10 AM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    I can't wait to start this... My camburg housing should be ready soon. Need to start buying all the extra parts to go with it.
    tacotunner06 and Airdog[OP] like this.
  8. Nov 28, 2022 at 10:33 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    love my camburg axle.
  9. Feb 5, 2023 at 11:42 AM
    amadougrand
    amadougrand Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    Very nice write up and inspiration. 100% agree on the ABS
  10. May 6, 2023 at 8:23 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Very nicely done!
  11. Jun 27, 2023 at 4:37 AM
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Great write up. About to install the JDFab LT kit/subframe LCA tabs & debating whether to take on the JDFab Ford 9 too.
    What mods do you need for the E-brake? I did not see anything discussing this (sorry if I missed it buried in the thread)
  12. Jun 27, 2023 at 5:00 AM
    Airdog
    Tom
    SoCal
    Im currently running no ebrake. But wilwood makes parking brake calipers in either cable or electric flavors. It’s up to you to make it work. It’s just a matter of gabbing up the bracket to hold the caliper. It’s not overly difficult to do. I’m just lazy.
    Jrgymie[QUOTED] and Slashaar like this.
  13. Jun 27, 2023 at 10:30 AM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    For your viewing pleasure
    Windigo, Naveronski, Slashaar and 3 others like this.
  14. Jun 27, 2023 at 5:17 PM
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    very tempting. Not "if" but "when" since I already cracked my OEM axle housing and driving around with temp weld fix.
    Thank you Airdog regarding parking brake options.
  15. Jun 27, 2023 at 7:27 PM
    #35
    Tango Bravo
    Thomas
    SoCal
    I remember talking to you and @tacotunner06 over on the LTBS thread about a send cut send file. I know I'm definitely going to want to do an ebrake when I do my swap. Those electric ones are sexy.
  16. Jun 27, 2023 at 8:18 PM
    #36
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    yeah it’s very doable. But someone’s basically gotta be the Guinea pig for a 3” one with different style mounting. But I have the file on my laptop at home.
  17. Dec 5, 2024 at 3:37 PM
    #37
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    Thanks for the write up. I'm getting ready to swap in Super Duty axles and some of this applies to my situation, specifically the abs delete and making my driveshaft work.
