Jeep headlight retrofits 0_o
Discussion in 'Lighting' started by 5 Lug Fury, Oct 30, 2017.
  1. Oct 30, 2017 at 9:15 AM
    5 Lug Fury
    5 Lug Fury [OP] Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    So I finished my retrofits, I decided to go with a different approach. I used 7" led headlights designed for vehicles that use a 7" headlight. The lenses are 5d which are know for a decent cutoff as well as it uses philips leds. I also made sure that the light had mounting holes visible in the sellers pictures.
    Here's the link for type I used (notice how the hi brights are on the bottom of the light just like how oem headlights are.)
    https://m.ebay.com/itm/5D-Pair-7-qu...JK-CJ-TJ-LJ-/202034058773?txnId=1582674610010
    Pictures
    Now here's a photo dump
    20171025_145951.jpg 20171025_150007.jpg 20171025_165358.jpg 20171025_165341.jpg
    Fitting
    (Make sure to shorten the bolts coming out of the sides or it may interfere with adjustments later...I didn't do that :facepalm:)
    So the headlight fits in the reflector housing and I've seen where some people just used glue to mount them. I wanted something a little more mechanical so I put a bolt on each side of the headlight and lined it up. I then pressed on the headlight and move it from left to right scoring the reflector marking holes to drill. This allowed me to use long bolts to mount the light to the reflector.
    This method allowed me to get a pretty accurate mount and I used es3000 glue to fine tune it. What I also like about this way is if the glue fails, the headlight will remain in place and only drift a few degrees.
    As for the wiring the light plugged right in no modifications unless you want your dalight running light. (Simple tap)
    Here what the drls look like in the wild
  2. Oct 30, 2017 at 9:16 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Reserved for Output shots (what I'm sure most people want)
    I need to adjust one headlight a little more and take new pictures on a more even surface.
    inwood customs, TacoTRD78 and Nimble9 like this.
  3. Oct 30, 2017 at 9:53 AM
    zh137dz
    zh137dz Well-Known Member
    Nashville, TN
    2012 Tacoma Prerunner TRD Sport
    too many lights
    Great idea and execution! Can't wait to see the output shots.
  4. Oct 30, 2017 at 10:58 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Awesome idea. Those 2nd gens housings are meant for round lights.. flows good.
    mcharfauros, Jcyr and ChadsPride like this.
  5. Oct 30, 2017 at 11:07 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  6. Oct 30, 2017 at 11:07 AM
    fatfurious2
    David
    Ashburn, VA
    @inesshell can you put your ARB intensity lights inside?
  7. Oct 30, 2017 at 11:52 AM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    lol not sure if 9.5 will fit, that would get me a ticket fast
    fatfurious2[QUOTED] likes this.
  8. Nov 20, 2017 at 5:35 PM
    Taco-Fishing239
    Taco-Fishing239 Well-Known Member
    Fort Myers
    2010 TRD sport dclb 4x4
    5100's all around, Wheeler's add a leaf, cmc, bora wheel spacers 285/70r17
    Nice install, just as I was going to start piecing out projector retro I see this
  9. Nov 21, 2017 at 10:30 AM
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    Subbed for output shots
  10. Nov 21, 2017 at 10:35 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  11. Nov 21, 2017 at 10:51 AM
    ErocksTaco
    ErocksTaco Well-Known Member
    Eric
    Denver
    06 4x4 DCSB Sport Radiant Red
    OME 886 and rear Dakars Light Racing Upper Control Arms All pro U-bolt flip with Timbren Bump Stops CVJ Reman axles with off road boots Adventure Offroad Fab Sliders ARB Front Bumper Interior LEDs Weathertechs 2009+ taillights 2009+ headlights
    Brilliant! Can't believe I've never seen this... Seems a lot easier and cheaper than a projector retro. I imagine this could be done with any 7" LED headlight and I know the truck light headlight has good output as I had one in my motorcycle and I've heard the JW speaker headlight is even better than that.
    Looking forward to some output shots. Thanks for posting!
    ChadsPride likes this.
  12. Nov 21, 2017 at 11:18 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    I was just thinking about this the other day. would love to see the output of those lights. I have the Trucklite ones on my fj40 and love the output.
  13. Nov 21, 2017 at 11:20 AM
    Ripcord
    Ripcord KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    sub'd, looks really good!
  14. Nov 21, 2017 at 12:09 PM
    ChadsPride
    No problem brother!
  15. Nov 21, 2017 at 1:11 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Just use a cheapo Craigslist set like I did.
  16. Nov 25, 2017 at 5:50 AM
    T@com@Steve
    T@com@Steve Well-Known Member
    Sarasota, Florida
    15 4x4 DCLB
    Patched headliner, loud rack, too much shit in the bed
    Great idea!
    5 Lug Fury[OP] and ChadsPride like this.
  17. Nov 28, 2017 at 5:22 PM
    Ted Steel
    Ted Steel Well-Known Member
    Ted
    NC
    2018 Cav Blue Pro 6MT, 2014 Baja (sold)
  18. Nov 30, 2017 at 11:23 AM
    zh137dz
    Nashville, TN
    too many lights
    Any update on output pictures?
  19. Dec 3, 2017 at 3:40 AM
    Kloverz158
    Kloverz158 Well-Known Member
    Georgia
    Radiant Red
    Cheap ebay LED’s huh? I highly doubt that there will be a cutoff. Just like the majority of Jeeps owner with LED PnP you will blind everyone. Looks cool though.
    SportsmanJake and EatSleepTacos like this.
  20. Dec 3, 2017 at 3:48 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Exactly what I was thinking... Sub'd for the output shots :popcorn:
    ChamYota likes this.
