Jerk
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rijo, Jun 1, 2012.
  1. Jun 1, 2012 at 8:35 PM
    Rijo
    Rijo [OP] New Member
    George
    Connecticut
    02 Tacoma TRD
    Ok so I bought a 2002 Tacoma double cab a month ago. Took it to Toyota and had them inspect it and give me a list of things the truck needed done. Told them the truck had this "slipping" or "slight jerk" when coming/taking off from a stop. They said it was typical with Tacoma and some Four runners. Told me to inflate the tires to 40lbs or get new tires to help eliminate some of what I experience.
    Now I'm no mechanic but it feels like it's more than just the tires. The truck had a new frame put on in January of this year. Any other suggestions or has any one else experienced this?
    Please offer up any ideas. Thanks!
  2. Jun 1, 2012 at 8:37 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    greese the driveshaft. They have a slip joint that "thumps" when it gets low on greese.
    jammer and Brie like this.
  3. Jun 1, 2012 at 8:46 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    both those guys are right
  4. Jun 1, 2012 at 9:46 PM
    Rijo
    George
    Connecticut
    02 Tacoma TRD
    Thanks guys! I'll give it a shot.
  5. Jun 1, 2012 at 11:15 PM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    I'd investigate this:spy:, my Supercharged 3.4 doesn't experience axle wrap unless I completely dump it full throttle from a dead stop:burnrubber: or punching it going into a turn in 2nd, so:notsure:.
  6. Jun 22, 2012 at 9:04 AM
    Hoyle
    Hoyle Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    I've searched this forum and read everything to no avail. I have the same "Jerk" and have tried all solutions offered here, from replacement of Springs to More grease, less grease,
    Why can't this JERK from the driveshaft be solved? Will a new slipjoint driveshaft remove the JERK feeling on stoping and starting?
    This is the only think that bums me out with my Tacoma! .. The only thing I'm unable to resolve.. it must be resolvable! ..
    Suggestions for me and the author of this thread!
    thanks
    Brie likes this.
  7. Jun 22, 2012 at 9:55 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    if your truck is lifted you might look at the carrier bearing too. It can get sloppy or play a part in the clunk if it is worn or needs a spacer to decrease the angle.
    Seagull233 likes this.
  8. Jun 22, 2012 at 12:48 PM
    Hoyle
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    Thanks Box, I installed this " carrier bearing bracket " from streetacos.com here in the forums.. This descreased the angle about 2" ... no difference from what I can tell..
    Any other suggestions?
  9. Jun 22, 2012 at 2:13 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Wild and Whipper are right, try purging and pump new grease into the driveshaft fittings. worked on my 03
    Brie likes this.
  10. Jun 22, 2012 at 3:52 PM
    Tashier
    Tashier Well-Known Member
    Sean
    Beaverton, OR
    99 Tacoma V6 Limited
    Air Bar Suspension
    How can you differentiate this between a bad U-Joint? I've been experiencing a little thump at take-off now for a year or so. Can't find any bad U-joints and greased the drivetrain all up.
    Brie likes this.
  11. Jun 22, 2012 at 4:15 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    one way to tell is when you change from R to D you can hear a ting or bell sound, that is a ujoint. Also if you have a noticeable chirp chirp when moving that could be a ujoint. Or if you let off the gas and then get back on it and hear a tink or ting that is probably a ujoint. If you do take the driveshaft out and rotate the ujoint range any rough spots or flat spots in the range of motion mean it's time to replace.
    Brie likes this.
  12. Jun 22, 2012 at 4:21 PM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    OK, well, the only thing I notice is when launching from full stop there is a clunk or jerk in the drive shaft. No other time do I hear something.
  13. Jun 22, 2012 at 10:50 PM
    Hoyle
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    How do I purge the driveshaft? thanks
    Brie likes this.
  14. Jun 23, 2012 at 3:48 AM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    I was told by the Toyota dealer to do this when I have that clunking noise,
    grease up the yoke fittings until you see the old grease pushing out. I do that about twice a year when doing an oil change, don't have that problem anymore.
    Brie likes this.
  15. Jun 23, 2012 at 9:42 AM
    Tashier
    Sean
    Beaverton, OR
    Air Bar Suspension
    OK, I will need to try that then. What grease is recommended for the job? I have greased mine occasionally with marine grease. (the light green stuff)
  16. Jun 23, 2012 at 9:45 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    Get a URD traction bar. Zero axle wrap, just 80 foot black marks when you get on it lol
  17. Jun 23, 2012 at 11:57 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    If it is sort of like a shuddering for the first little bit from a start or when you are stopping i can almost guarantee it's axle wrap, which is caused by weak springs.
    Brie likes this.
  18. Jun 23, 2012 at 4:53 PM
    Detective_Dan
    Colorado Springs
    The springs dont necessarily have to be weak for axle wrap to occur. My truck had terrible axle wrap and it only has 6k miles on it. Traction bar stopped 100% of it
    Brie likes this.
  19. Jun 25, 2012 at 11:53 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    this is a common and annoying problem. my dad's '07 tundra does the same thing since new. my tacoma used to do it too and i just learned to live with it(by ignoring it). however, somewhere along the lines of modding it, it went away.
  20. Jun 26, 2012 at 10:54 AM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
