JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. May 23, 2020 at 2:56 PM
    #2141
    sf.larry
    sf.larry Well-Known Member
    larry
    2011 XR
    Cali special —-> swap out all non carb parts prior to smog and back in after
  2. May 25, 2020 at 9:27 PM
    #2142
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    IMPORTANT:
    If you have these lower control arm gussets my y-pipe wont fit with the y-pipe hanger installed!
    I will try to highlight the area with MS Paint tomorrow.
    Please let me know if you have these gussets installed.
    Lucario Runner likes this.
  3. May 25, 2020 at 9:35 PM
    #2143
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    is that the marlin crawler ones ?
  4. May 25, 2020 at 9:36 PM
    #2144
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    12TRDTacoma likes this.
  5. May 25, 2020 at 10:03 PM
    #2145
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Damn I was going to get a set of those soon.
  6. May 25, 2020 at 10:15 PM
    #2146
    Roostfactor
    TX panhandle
    You MAY be able to modify them to facilitate y-pipe install/removal but I would clamp them in place then remove y-pipe to ensure clearance before welding them on.
    You also have a 4x4 which has a lower crossmember so yours MAY fit as is but I cannot confirm.
    I should have taken more pics but I was feeling like poop and @Lucario Runner needed to get on the road.
    Murphinator[QUOTED] likes this.
  7. May 25, 2020 at 11:27 PM
    #2147
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I see 4x4 and fitment was mentioned a couple times.... Is that something I need to note for the build of my y-pipe? Cause my truck is a 4x4...
    Nice to see the shop has power now! (TW dropped me off the notification of this thread 5-6 pages ago, no clue why)
    Roostfactor[OP] likes this.
  8. May 26, 2020 at 5:09 AM
    #2148
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @Lucario Runner , if the sky isn't falling out, could you get under there and snap some pictures of the differences? That'd be quite helpful.
  9. May 26, 2020 at 7:34 AM
    #2149
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Good to know before I burn mine in, but I don't see how they could possibly interfere all the way up by the LCA with the Y-pipe??? Standing by for pics.
  10. May 26, 2020 at 7:56 AM
    #2150
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think what they’re talking about is when you install the y-pipe you have to slide the back part of the Y up over the crossmember then tilt the front of the y-pipe up into place.
    The control arm pivot reinforcement thingy sticks out toward the rear of the truck a little and is probably interfering with tilting the front of the y-pipe up to get it to meet up with the header.
    That’s what I’m seeing in the picture posted above. As usual I may totally wrong and just running my mouth! Of course @Roostfactor and @Lucario Runner were there so they can elaborate on it.
  11. May 26, 2020 at 8:16 AM
    #2151
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  12. May 26, 2020 at 9:27 AM
    #2152
    Lucario Runner
    Robert
    06 Toyota 4Runner
    This is basically the difference of frames on the dcsb. The frame is modular yes but with the option of 2wd or 4wd, auto or manual. The prerunner auto mount sits a little bit higher than the 4x4. The exacerbation is also the requested outlet i.d of 3in. If I had went with 2.5 if wouldn't be that be a big deal. There is a recess on the floor of the body when the heat shield is removed that can help but with the front skids and how far they stick back a hanger wouldn't allow rotation for install. Now you could notch the skids but lose that integrity of the mount. The other solution which we did was move the mount to the cat back and carrier bearing support. Took a bit longer but works as well as the oem one on the frame.
    Roostfactor[OP] and loginfailed like this.
  13. May 26, 2020 at 9:29 AM
    #2153
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Pretty much spot on mate
  14. May 26, 2020 at 9:31 AM
    #2154
    Lucario Runner
    Robert
    06 Toyota 4Runner
    It isn't anymore but I'm debating whether to fall out of bed atm.
  15. May 26, 2020 at 9:56 AM
    #2155
    garciav
    Houston, TX
    TRD SC,HPTuners
    So on a DCSB 4x4 this is a non issue ?
  16. May 26, 2020 at 10:03 AM
    #2156
    Lucario Runner
    Robert
    06 Toyota 4Runner
    That is an unknown. We don't have a 4x4 auto/manual w/those gussets to verified the fitment. This is a PSA from roost and one of the adventures of modding hoping all the parts you install play nice and when they don't come up with a solution. The hanger relocation placement is that solution.
    Roostfactor[OP], SUMOTNK and Torspd like this.
  17. May 26, 2020 at 10:08 AM
    #2157
    zippsub9
    Halfmoon, NY
    14 DCLB
    I think I am next in line. I am a DCLB auto. I also have 3" outlet. I have the MC gussets, but they are not burned in yet. I can help verify.
  18. May 26, 2020 at 10:17 AM
    #2158
    Lucario Runner
    Robert
    06 Toyota 4Runner
  19. May 26, 2020 at 10:23 AM
    #2159
    Lucario Runner
    Robert
    06 Toyota 4Runner
    You can actually see you transmount now or whatever time. per roost the 4x4 transmount is lower compared to a prerunner (which I uploaded) so that can be one of the way to verify even before you get the y pipe.
    There is also the recess on the floor that will help the install. Driver side pictured.
  20. May 26, 2020 at 10:29 AM
    #2160
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    A stopped clock is right twice a day!
    Glad y’all were able to create a workaround to get it bolted on.
