JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. May 30, 2020 at 12:42 PM
    #2181
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  2. May 30, 2020 at 12:45 PM
    #2182
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
  3. May 30, 2020 at 12:49 PM
    #2183
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
  4. May 30, 2020 at 1:21 PM
    #2184
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    JuanitoBonito likes this.
  5. May 30, 2020 at 1:50 PM
    #2185
    Roostfactor
    TX panhandle
    loginfailed[QUOTED] likes this.
  6. Jun 4, 2020 at 10:09 PM
    #2186
    Roostfactor
    TX panhandle
  7. Jun 5, 2020 at 2:08 AM
    #2187
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Looks like you solar flux about 3/8” on the inside and the ends as well, is that correct?
    zippsub9 likes this.
  8. Jun 5, 2020 at 4:45 AM
    #2188
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yup.
    Hawk373 likes this.
  9. Jun 5, 2020 at 5:46 AM
    #2189
    Hawk373
    2012 TRD Sport DCLB
    I’ll be trying it for the first time Saturday.
  10. Jun 5, 2020 at 7:15 AM
    #2190
    RBx
    RBx Active Member
    Charm City
    '88 4Runner & '07 X-Runner
    SAS 4Wheel Underground, X-Runner Daily Driver
    So jelly....
  11. Jun 5, 2020 at 10:39 AM
    #2191
    Roostfactor
    TX panhandle
    NOT THE ENDS!!!
    Just inside with an acid brush, then I carefully wipe off any on the ends and/or outside.
    I mix with rubbing alcohol and brush inside. I dont pay too much attention to width, just enough to keep the inside of the weld pure.
    I keep my Solarflux in a little Tupperware and just add alcohol as needed to keep my desired consistency.
    Hawk373[QUOTED] and BassAckwards like this.
  12. Jun 5, 2020 at 10:48 AM
    #2192
    Roostfactor
    TX panhandle
    I'll put more pics up later.
    Hawk373 and BassAckwards like this.
  13. Jun 5, 2020 at 11:51 AM
    #2193
    Hawk373
    2012 TRD Sport DCLB
    Regular store bought alcohol? I was about to go out to the race fuel station for methanol.
  14. Jun 5, 2020 at 12:01 PM
    #2194
    Roostfactor
    TX panhandle
    Yep! I think its 91% rubbing alcohol from Wallyworld.
    Acetone is the standard.
  15. Jun 5, 2020 at 12:07 PM
    #2195
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This really makes me wonder how much more power I would get out of the 2.8 if I had your Y pipe setup.
  16. Jun 5, 2020 at 12:17 PM
    #2196
    Hawk373
    2012 TRD Sport DCLB
    Cool, I have both! Win.
  17. Jun 6, 2020 at 12:08 PM
    #2197
    Roostfactor
    TX panhandle
    One way to find out.
  18. Jun 6, 2020 at 12:29 PM
    #2198
    Roostfactor
    TX panhandle
    Shipment from Aceraceparts just came in as well as my latest order from my machinist for O2 bungs.
    Here is about $1K worth of parts.
    Look how well he wraps the bungs!
    So glad y'all are willing to pay for the good stuff!
    I wouldnt be doing this otherwise.
  19. Jun 6, 2020 at 12:46 PM
    #2199
    Roostfactor
    TX panhandle
    Here are some pics hoping to explain why it takes me so much time to fabricate each one.
    This is the tube that goes under the trans. Below my thumb is my reference line (jig).
    Notice the tubing has a slight upward angle?
    This required changing the angle of the 45° mandrel bend slightly by sanding in order for the tubing to lay flat against the jig while being able to fusion butt weld.
    Welded and true to the jig.
    Getting each joint perfectly prepped and oriented is the difficult part.
    Lengths and angles need to be manipulated slightly with each joint to get them where I want them.
    This is why no two y-pipes are exactly the same.
    Here I'm starting to route the tubing where it goes up and over the crossmember.
    I do my best to fusion weld every joint which means there cannot be any gap between the joints.
    Roost
    oni06, SUMOTNK, BassAckwards and 12 others like this.
  20. Jun 6, 2020 at 1:21 PM
    #2200
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just remember back when you had no jig....:eek:
