JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. Jun 23, 2020 at 2:12 PM
    #2261
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I haz hangers w/brace.
  2. Jun 23, 2020 at 2:28 PM
    #2262
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I didn’t want the lift and went with BAMF shackles hangers. With brace incoming.
  3. Jun 23, 2020 at 5:54 PM
    #2263
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You have the trickest exhaust brace ever created!
    Torspd likes this.
  4. Jun 23, 2020 at 6:24 PM
    #2264
    Lucario Runner
    Robert
    06 Toyota 4Runner
    this is true too
  5. Jun 23, 2020 at 7:27 PM
    #2265
    su.b.rat
    su.b.rat broken truck
    on my radar and discussing with Pablo 2nd week in July. getting the whole front end rebuilt. 3rd time. :rolleyes:
  6. Jun 23, 2020 at 9:49 PM
    #2266
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Yeah, the Magnaflow that comes with the URD cat back. It’s sounds ok with the URD Y as long as you’re just cruising. WOT was embarrassing.
    Expecting a drastic improvement with the new combo. I have a few more configs I'm planning on as well.
  7. Jun 24, 2020 at 4:59 AM
    #2267
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mad scientist can turn his skills towards a home made property saver. ;)
  8. Jun 25, 2020 at 6:25 PM
    #2268
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Okay I had another minor change of mind. I would like a 3rd bung in the merge. I realized this would be very useful for hooking up AFR to the dyno computer.
    BassAckwards likes this.
  9. Jun 27, 2020 at 11:22 AM
    #2269
    Roostfactor
    TX panhandle
    Got it buddy.
    Athlaos[QUOTED] likes this.
  10. Jun 27, 2020 at 11:45 AM
    #2270
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Seeing dis pop up in the land of the rising sun.
  11. Jun 27, 2020 at 11:54 AM
    #2271
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Similar in design to the spec-u y-pipe.
    Roostfactor[OP] likes this.
  12. Jun 27, 2020 at 12:06 PM
    #2272
    Lucario Runner
    Robert
    06 Toyota 4Runner
    it does with 'test pipe' options it seems
  13. Jun 27, 2020 at 1:26 PM
    #2273
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Read the speedhunters story on him. That s600 sounds insane. :drool:
  14. Jun 27, 2020 at 8:23 PM
    #2274
    Roostfactor
    TX panhandle
    Interesting.
    Looks like 2.25" tubing
    Missing section between header/manifold and y-pipe
    Likely 2wd unless length of system not of primary concern.
    Where did you find this @Lucario Runner?
    Athlaos likes this.
  15. Jun 28, 2020 at 8:17 AM
    #2275
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I just follow the poundsign 1grfe and stuff pops up. Mostly in Arabic but every now and then something interesting pops up. So the vehicle pictured is an lc70 so its a 4wd 2 door suv.
  16. Jun 28, 2020 at 4:42 PM
    #2276
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    On that guy’s Instagram he mentions Technical Garage. He may be referring to Technical Garage Sasaki, which could mean Brilliant. No 1GR stuff on the website, though.
    https://www.ekimani.com/
    8687DB02-0B0F-4457-BD22-69401056C2DA.jpg 4F5C9121-5A6E-4640-846A-19281C76E9B8.jpg 8D0760DC-05C1-47B4-BC44-06972F91C352.jpg 26D85B0E-DC22-4C1F-A295-4E87C5879162.jpg
  17. Jun 28, 2020 at 7:59 PM
    #2277
    Roostfactor
    TX panhandle
    That's some seriously trick shi!!!
    I aspire to gain a fraction of knowledge from such gifted artists!
    SUMOTNK and loginfailed[QUOTED] like this.
  18. Jun 29, 2020 at 3:00 AM
    #2278
    Chris(NJ)
    08 Indigo 4x4 DC OR
  19. Jun 30, 2020 at 12:28 PM
    #2279
    Roostfactor
    TX panhandle
  20. Jun 30, 2020 at 3:00 PM
    #2280
    Hawk373
    2012 TRD Sport DCLB
    Soooo, the Y, cat, resonator and Black Widow exhaust are all mounted up; HP Tuners is a go; just went for a test drive.
    Now I can only assume what a pissed off Yak in heat sounds like, but that’s the best way I can describe this muffler - it’s definitely not good. I only have a 90 degree turn down dump, so that’s not helping things.
    Tinkering continues...
