JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. Nov 29, 2018 at 9:54 AM
    #261
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    IMHO....Retirement will be the busiest job that Roost has ever held....
  2. Nov 29, 2018 at 10:11 AM
    #262
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I was going to get the gesi cat, but someone talked me out of it. Ahem ahem roostfac ahem. :D
    Agree. I’ve had many people say that they’re busier in retirement than when they worked a regular job.
  3. Nov 29, 2018 at 10:14 AM
    #263
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    You'll probably get better value out of this cat than I am by getting the 3" and having it after the merge. I found mine cheaper at a secondary dealer...around $300.
    With the Vibrant GESi cats on my Doug Thorley shorties, URD ypipe, and 2.5" TRD catback, my HP/TQ and MAF numbers have been underwhelming compared to others with similar setups outside of the cats and catback.
    With this current exhaust setup, my best MAF g/s is 321.5 which seems low.
    I plan to compare the MAF numbers at each stage as I upgrade the exhaust. I hope to get 3" banks exhaust installed tonight and re-check the MAF g/s. Then do the same each time for the JFR y-pipe and URD long tubes.
  4. Nov 29, 2018 at 12:53 PM
    #264
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Thanks Justin!
  5. Nov 29, 2018 at 1:05 PM
    #265
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Care to share who has it for $300? I want my flex right after merge for obvious reasons.
  6. Nov 29, 2018 at 1:17 PM
    #266
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    It was www.tunersports.com. Looks like they've raised the price of my 7525 to $336. $341 for 7530
    Stryker420 likes this.
  7. Nov 29, 2018 at 1:42 PM
    #267
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    I appreciate the info. Ill keep everybody posted as I make progress.
    BassAckwards and Roostfactor[OP] like this.
  8. Nov 29, 2018 at 1:57 PM
    #268
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
  9. Nov 29, 2018 at 3:54 PM
    #269
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    What year is that from !?
  10. Nov 29, 2018 at 3:56 PM
    #270
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    $1.93 this morning for me
  11. Nov 29, 2018 at 3:57 PM
    #271
    Hawk373
    2012 TRD Sport DCLB
    Jealous
    BassAckwards likes this.
  12. Nov 29, 2018 at 4:18 PM
    #272
    TRD493
    Dave
    Texas (DFW)
    I was more than a little surprised....
  13. Nov 29, 2018 at 4:23 PM
    #273
    ThomasMore66
    Dallas/Fort Worth & Durango
    Is it bad that I don’t really know the price of gasoline? Knowing doesn’t change the decision. Just don’t push the wrong button.
    BassAckwards, rmepilot and Biscuits like this.
  14. Nov 29, 2018 at 5:08 PM
    #274
    Roostfactor
    TX panhandle
    I wouldnt say it is bad, but does give a possible clue into ones financial status.
  15. Nov 29, 2018 at 5:16 PM
    #275
    Roostfactor
    TX panhandle
    So after getting my new shoes today (excuse dirty truck)
    since I found out yesterday they are local and just acquired Snow Performance. Long story short they may desire my experience.
  16. Nov 30, 2018 at 4:27 AM
    #276
    rmepilot
    Rob
    Huntsville, AL
    :bowdown:
    BassAckwards and Stryker420 like this.
  17. Nov 30, 2018 at 7:30 PM
    #277
    ThomasMore66
    Yes! Somebody is gettin’ sprayed!
  18. Nov 30, 2018 at 8:02 PM
    #278
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Did you just find a retirement gig?
  19. Nov 30, 2018 at 8:08 PM
    #279
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Somebody getting paid?
    Roostfactor[OP] likes this.
  20. Nov 30, 2018 at 8:47 PM
    #280
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    John is gonna setup the biggest meth kit group buy ever??? What?!!!
