JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. Nov 30, 2018 at 9:06 PM
    #281
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    JFR = the real Walter White. :spy:
  2. Nov 30, 2018 at 9:30 PM
    #282
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    It's a possibility.
  3. Nov 30, 2018 at 9:35 PM
    #283
    Roostfactor
    TX panhandle
    Give me a few weeks to see if they get back with me. I'll let everyone know what I come up with.
  4. Dec 1, 2018 at 9:03 AM
    #284
    ThomasMore66
    Dallas/Fort Worth & Durango
    Yes! I want a separate reservoir. Don’t want to use my washer fluid. Does it really damage the coating on the rotors?
    Murphinator likes this.
  5. Dec 1, 2018 at 9:09 AM
    #285
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Word on the street is that it only damaged the coating on some rotors where the coating from eaton was faulty.
    BassAckwards likes this.
  6. Dec 1, 2018 at 9:24 AM
    #286
    ThomasMore66
    I’ll hope for the best. I think Meth is a good idea.
  7. Dec 1, 2018 at 9:34 AM
    #287
    Roostfactor
    TX panhandle
    I think it was just the old epoxy coated rotors, not the newer black coating.
  8. Dec 1, 2018 at 9:48 AM
    #288
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    @Roostfactor This setup would slick under that tonneau cover of yours. (From cars and coffee this morning w/ @Torspd )
  9. Dec 1, 2018 at 9:49 AM
    #289
    ThomasMore66
    I like it!
    loginfailed[QUOTED] likes this.
  10. Dec 1, 2018 at 10:31 AM
    #290
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    100' Roost-er tails! :mudding:
  11. Dec 1, 2018 at 11:56 AM
    #291
    Roostfactor
    TX panhandle
    Yeah I don't think I would be running any nitrous. At least not without a built motor. Methanol would be mainly for cleaning, cooling, and octane increase. I wonder if the UCON would advance timing at all if zero knock was detected. Probably not.
    Interested to see what @o0opackersfano0o comes up with for intake air temp separated from the maf.
  12. Dec 1, 2018 at 11:57 AM
    #292
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I am too. I haven’t had any time to do anything with a 2 year old and a 4 month old to watch on the weekends lol. Hopefully soon I’ll be able to get some stuff done.
    BassAckwards and Roostfactor[OP] like this.
  13. Dec 1, 2018 at 12:09 PM
    #293
    ThomasMore66
    Just put them on a leash in the garage.
    oni06 likes this.
  14. Dec 1, 2018 at 12:28 PM
    #294
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
  15. Dec 1, 2018 at 3:05 PM
    #295
    Roostfactor
    TX panhandle
    I used to be able to that with one kid. I mounted hooks in the garage and would hang his swing from them. It would keep him busy for awhile but doesnt really work for a 2 yo or a 4 month old.
    rmepilot likes this.
  16. Dec 1, 2018 at 3:14 PM
    #296
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Ha yeah. I got a 2-1/2 year old and a 6 month old. I’d have the 2 year old out working on the truck with me, it was awesome. Until he keyed two of my cars with a gasket scraper. He was so proud of himself. I was at a loss for words.
  17. Dec 1, 2018 at 3:27 PM
    #297
    Roostfactor
    TX panhandle
    Oh I would have lost it! Of course not much you can do but chalk it up to a learning experience.
  18. Dec 1, 2018 at 3:35 PM
    #298
    Roostfactor
    TX panhandle
    Then they grow up and you try to get them to help you.
    Here is my 17yo just starting to learn to run beads.
    Dont worry, he is not part of the JFR fabrication process.....yet.
  19. Dec 1, 2018 at 4:59 PM
    #299
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He's going to be your secret weapon.
    Man! If he can accelerate as quickly in learning as you did, you guys will be turning out exhaust components and making money in no time!
  20. Dec 1, 2018 at 5:17 PM
    #300
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Haha ya. My trucks in the garage all winter and he walks around it and he knows now to be safe lol he’s helped me too but gets distracted easily.
