JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. Dec 20, 2018 at 11:40 AM
    #461
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Thanks for the feedback guys. I just got a 2nd gen recently some I'm looking at some different mods for it. Most of my previous trucks have had performance mods. I'm learning what all the 1gr can do and what's out there for it. Any input is welcome!
    Murphinator likes this.
  2. Dec 20, 2018 at 11:48 AM
    #462
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I'm on the list to get one for my N/A '07. I can't wait to get rid of the rasp from my URD y pipe.
    Great work Roost, it looks like the jig will help you tremendously.
  3. Dec 20, 2018 at 12:02 PM
    #463
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Yessir!
  4. Dec 20, 2018 at 12:33 PM
    #464
    ThomasMore66
    Dallas/Fort Worth & Durango
    Rooster-boy, think this would fit under my RCI skid plate?
  5. Dec 20, 2018 at 12:36 PM
    #465
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Which version of the RCI skidplate do you have? I have one and mine fits with the center support gussets removed. I had to space mine down slightly, but that is because my driverside cat is not welded on right. No fault to the roost pipe. I just used two washers.
    Stryker420 and Roostfactor[OP] like this.
  6. Dec 20, 2018 at 12:40 PM
    #466
    Roostfactor
    TX panhandle
    I would have to see the clearance between the trans pan and skid plate. If there is a skid plate brace in the way we could modify it.
    Stryker420 likes this.
  7. Dec 20, 2018 at 12:56 PM
    #467
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    @Roostfactor just to clarify, your awesome y-pipe is a 3” pipe correct. At some point here I’m gonna be putting my name on the list.....
  8. Dec 20, 2018 at 12:59 PM
    #468
    Roostfactor
    TX panhandle
    Primary tubes are 2.25" and the merge is 2.5" or 3.0" depending on your choice.
    Roost
    JuanitoBonito[QUOTED] and Torspd like this.
  9. Dec 20, 2018 at 1:14 PM
    #469
    808inDa503
    808inDa503 From HNL living in PDX.
    Sam
    Portland, OR
    '09 Silver DCSB 4x4
    Icon stage 6 kit w/ billet UCAs, Dakar leaf pack, Icon air bump stop, Bullet Proof Fab grill, Magna-flow exhaust, ARE bed cover, Redline Tuning quick lift, 17" gunmetal SCS Ray 10, BFG KO2 285/70/17, Wet Okole and Ellis Precision shift knob
    Man I can’t wait till it’s my turn. I just got my URD headers, MAF calibrator, and urd cat back in. It’s just sitting in my garage waiting for a bad ass y pipe to connect everything.
  10. Dec 20, 2018 at 1:22 PM
    #470
    boostedka
    James
    NM
    These definitely look really awesome. The stock y-pipe looks super restrictive around the crossover crush bend. From what I’ve been reading, the stock y-pipe and headers are the most restrictive parts of the exhaust. Any guesses on hp/tq numbers for these custom y-pipes?
    loginfailed and Roostfactor[OP] like this.
  11. Dec 20, 2018 at 1:40 PM
    #471
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Far Superior than just looking. ;)
  12. Dec 20, 2018 at 2:05 PM
    #472
    boostedka
    James
    NM
    So these work with the urd headers correct? From what I’ve read they seem to be the ones that offer the most gains throughout the rpm range.
    Roostfactor[OP] likes this.
  13. Dec 20, 2018 at 2:12 PM
    #473
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yes that’s correct
  14. Dec 20, 2018 at 2:51 PM
    #474
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    This is on the list..
    Next up for this year is full exhaust and rear bumper...
    I have to decide on 2 1/2" or 3" exhaust.
    I want more torque and don't have a supercharger yet... So 2 1/2???
  15. Dec 20, 2018 at 2:57 PM
    #475
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    The fact you said yet makes me think that you should just get the 3” so when you are supercharged you dont have to drop another $500
  16. Dec 20, 2018 at 2:59 PM
    #476
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    If you are going to be supercharged in the future.....go 3”
  17. Dec 20, 2018 at 3:39 PM
    #477
    Roostfactor
    TX panhandle
    The URD header flanges terminate at the same location as the stock exhaust manifolds. The y-pipe will work with any header/exhaust manifold that exits at the stock location.
    Roost
    boostedka[QUOTED], shr133 and Torspd like this.
  18. Dec 20, 2018 at 3:45 PM
    #478
    Roostfactor
    TX panhandle
    Most aftermarket systems are 3" whether boosted or not. 3" is the best compromise between top end flow and low end loss. 2.5" is better for low end performance at the sacrifice of top end. 3" has minimal if any low end torque loss and better mid and top end. This is even without boost.
    Over 3" for our application (boosted or not) could result in too much exhaust velocity lost below the upper rpm ranges which results in low rpm power loss. So 3" is the best compromise.
  19. Dec 20, 2018 at 3:49 PM
    #479
    Roostfactor
    TX panhandle
    You coming out for mod day Jan 19th? We can fit one up to your specifications including v-bands!
    loginfailed likes this.
  20. Dec 20, 2018 at 3:54 PM
    #480
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I don’t think anyone has dyno tested before and after, but I definitely felt a difference. AND.. that was coming from a URD unequal length.
