JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. Jan 1, 2019 at 5:54 PM
    #541
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Ucon feels alot smoother as far as power delivery goes and in between shifts. With the trd tune and meth it was pretty harsh when pushing in the clutch to shift, youd have to do it really quick or it was very rough. That is 100% gone now with the ucon.
    Roostfactor[OP] and jojotoo like this.
  2. Jan 1, 2019 at 6:07 PM
    #542
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Good question
    BassAckwards likes this.
  3. Jan 1, 2019 at 6:08 PM
    #543
    Roostfactor
    TX panhandle
    Hmmm, all those problems seem like they were due to the previous UCON huh?
    BassAckwards[QUOTED] likes this.
  4. Jan 1, 2019 at 6:23 PM
    #544
    BassAckwards
    Indeed they do sir
  5. Jan 1, 2019 at 6:25 PM
    #545
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Worth $1000+ ??
  6. Jan 1, 2019 at 6:29 PM
    #546
    BassAckwards
    Now that its working properly i am very happy with it, so yes worth it id say
    Roostfactor[OP], oni06 and DocME like this.
  7. Jan 1, 2019 at 9:30 PM
    #547
    WorldWar546
    WorldWar546 Baja Member
    Anthon
    Utah
    TRD Charged '14 Black TX Baja
    TRD Supercharger And a lot of rice n chrome
    Tax season or even sooner I'm definitely in!! Just need to get a 3" exhaust to go with it :thumbsup: Awesome work as always Roost
  8. Jan 1, 2019 at 9:50 PM
    #548
    Roostfactor
    TX panhandle
    Thank you!
    WorldWar546[QUOTED] likes this.
  9. Jan 2, 2019 at 6:10 AM
    #549
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    :thumbsup:
  10. Jan 3, 2019 at 4:08 AM
    #550
    TitanRattler813
    TitanRattler813 Active Member
    Sean
    Davie, FL
    2012 Nautical Blue X-Runner (Formerly 07 RR X-Runner)
    Just beginning...
    Quick question: Is the V-band included in the standard system or is that only part of the built out self-install install versions?
  11. Jan 3, 2019 at 6:48 AM
    #551
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Hey Roost can you add me to the list? I lost my patience with the urd y pipe this morning.
  12. Jan 3, 2019 at 8:01 AM
    #552
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Due tell.....cuz I run one as well.....
  13. Jan 3, 2019 at 8:56 AM
    #553
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Hits on the trans Cross member. Torspd and myself have done numerous fixes and it still hits. Its an 09 double cab and so far that issue only happens to that cab configuration.
  14. Jan 3, 2019 at 10:31 AM
    #554
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Is it a 4x4?....mine is fine. I have a 14, 4x4 dbl cab and no problems at all.
    ThomasMore66 likes this.
  15. Jan 3, 2019 at 10:35 AM
    #555
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Negative. His is a PreRunner. Double Cab.
    jojotoo and Lucario Runner like this.
  16. Jan 3, 2019 at 10:58 AM
    #556
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    I had the same issue .. 15’ double cab pre-runner.
    Roostfactor[OP] likes this.
  17. Jan 3, 2019 at 11:10 AM
    #557
    Roostfactor
    TX panhandle
    Yessir, the male v-band is welded to the collector and the female v-band + clamp are shipped with the y-pipe for your own fitting to exhaust.
  18. Jan 3, 2019 at 11:13 AM
    #558
    Roostfactor
    TX panhandle
    Sure thing buddy!
    What options do you want on this one?
    You remember my PayPal?
    Roost
  19. Jan 3, 2019 at 11:20 AM
    #559
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Think nearly the same as the other one. Catback is 3in but two bungs for the o2 sensors. Will also take a flex pipe. Pm other details you needz.
  20. Jan 3, 2019 at 11:28 AM
    #560
    Roostfactor
    TX panhandle
    A little update. I have been out the last couple days with Vertigo. This is my third time having this so I am familiar with it and it has subsided in 3 days in the past.
    @Laoturk y-pipe is finished (not shipped)
    @rmepilot is almost finished.
    Since I am a perfectionist I still want to ensure final fitment of the y-pipes to my truck so as soon as the weather clears (snowing here) and I regain my balance I will check the y-pipes fitment and ship them out asap.
    Torspd, rmepilot and Murphinator like this.
