JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. Jan 6, 2019 at 1:29 PM
    #581
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    But those are acted. That is plain old real life goodness
  2. Jan 6, 2019 at 1:41 PM
    #582
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  3. Jan 6, 2019 at 5:13 PM
    #583
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Let me know if you have any TIG questions.
    Also the flux I use for the inside of the welds is called Solar Flux type B. I just mix it with rubbing alcohol and make sure I get all of it off of the joint.
    rmepilot and Stryker420[QUOTED] like this.
  4. Jan 7, 2019 at 11:54 AM
    #584
    Roostfactor
    TX panhandle
    @elnip, any word on if you are going to be able to make the 19th?
    @JacksonTacoma @JuanitoBunito are you guys coming down?
    Who else is coming? I need to get some sort of headcount to determine how much food to get. So far here is what I have:
    @loginfailed definite
    @rjbiii definite
    @elnip definite
    @Biscuits waiting on response
    @5thGearPinned probable
    @ThomasMore66 possible
    @Torspd waiting on response
    @Lucario Runner negative (you can always change your mind if things change)
    @JustDSM possible
    Sorry if I have missed anyone. This is open to everyone but please let me know asap if you would like to come socialize, mod, drink, eat, etc. not necessarily in that order!
  5. Jan 7, 2019 at 12:34 PM
    #585
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Roost,
    Can you throw me down as "interested"? I might be picking up a set of Spec-U headers to finish off the full exhaust in addition to some cam gears.
    Roostfactor[OP] likes this.
  6. Jan 7, 2019 at 12:35 PM
    #586
    Roostfactor
    TX panhandle
    Will do!
    JustDSM[QUOTED] likes this.
  7. Jan 7, 2019 at 1:10 PM
    #587
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    As of now I'm in!
  8. Jan 7, 2019 at 1:16 PM
    #588
    Roostfactor
    TX panhandle
    Yes!!! I'm getting ready to start your y-pipe.
    Test fitting @rmepilot and @Laoturk's y-pipes today. Hope to ship tomorrow.
  9. Jan 7, 2019 at 1:19 PM
    #589
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I unfortunately am out.....but I was just talking to the woman about this over the weekend at dinner and told her at some point this will be on my bucket list......
    Stryker420 and Roostfactor[OP] like this.
  10. Jan 7, 2019 at 1:32 PM
    #590
    ThomasMore66
    Dallas/Fort Worth & Durango
    Forgiveness, not permission. Just sayin'...
  11. Jan 7, 2019 at 1:42 PM
    #591
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Oh she don’t care if I go.. she cool like that. It’s more of rearranging my schedule for work that’d be a pain at the moment...
  12. Jan 7, 2019 at 1:53 PM
    #592
    Laoturk
    Laoturk Well-Known Member
    Huntington Bch
    2013 tacoma LB
    No rush bossman. hope you feel better.
  13. Jan 7, 2019 at 4:00 PM
    #593
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    ^^ This!!
  14. Jan 7, 2019 at 10:18 PM
    #594
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Been away from the thread for a little bit. Are there any fires I need to put out? :rofl:
    Still in!​
    BassAckwards likes this.
  15. Jan 8, 2019 at 6:03 AM
    #595
    Roostfactor
    TX panhandle
    Well thank goodness your back! I was barely able to keep things afloat without you.
  16. Jan 8, 2019 at 7:50 AM
    #596
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Does anyone in here have a mechanical boost gauge that they know is accurate? Would like to do some testing on January 19th and see which one of my boost gauges is actually reading accurately..
    loginfailed likes this.
  17. Jan 8, 2019 at 9:21 AM
    #597
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Only one I have is installed. We could drive next to each other with a long hose. :D
  18. Jan 8, 2019 at 9:53 AM
    #598
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh:
  19. Jan 8, 2019 at 9:56 AM
    #599
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Bruh dats been done w/dah boost caboose on roadkillz
  20. Jan 8, 2019 at 10:01 AM
    #600
    BassAckwards
    Lol good plan:rofl:
