JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. Jan 8, 2019 at 10:13 AM
    #601
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I'm sure there is a cheap tester somewhere that you would manually pump a small amount of air into a chamber with gauge hooked to the boost gauge pressure sensor. Compare readings.
    Stryker420 and BassAckwards like this.
  2. Jan 8, 2019 at 10:27 AM
    #602
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Lol, link?
    BassAckwards likes this.
  3. Jan 8, 2019 at 10:45 AM
    #603
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  4. Jan 8, 2019 at 11:23 AM
    #604
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Unfortunately, I won't be able to try for the longest traveled award this year...but maybe someday if this is a regular thing. Would be an epic road trip for sure. Cheers fellas:cheers:
  5. Jan 8, 2019 at 1:00 PM
    #605
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    hmm.. may have to look into this. Wonder if I could rig up some way to test it with my vacuum pump/pump if I had a gauge to put in between the manifold and the pump..
  6. Jan 8, 2019 at 1:14 PM
    #606
    Roostfactor
    TX panhandle
    If your pump is a low capacity so you don't build up crazy pressure too quickly then absolutely it would work. All you are doing is putting a controlled small amount of pressure into the system, then hold pressure and compare the boost gauges to the "control" gauge.
    BassAckwards[QUOTED] likes this.
  7. Jan 8, 2019 at 1:15 PM
    #607
    BassAckwards
    Gotcha, yeah mines just a little hand pump used for bleeding brakes or a clutch, but it can also pump air, so I think it'd work good.
  8. Jan 8, 2019 at 1:20 PM
    #608
    Roostfactor
    TX panhandle
    @Laoturk please pm me your address asap so I can get your stuff shipped out today.
    @rmepilot your stuff is wrapped and ready. I will wait as long as I can for laoturk's response but if he doesn't reply in time I will still send yours off today.
    Roost
    rmepilot, 808inDa503 and Torspd like this.
  9. Jan 8, 2019 at 2:38 PM
    #609
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Damn wish I lived in Texas. Far ride down. From Maine
    Roostfactor[OP] and BassAckwards like this.
  10. Jan 8, 2019 at 6:15 PM
    #610
    Roostfactor
    TX panhandle
    That would be one helluva trip.
  11. Jan 9, 2019 at 6:07 AM
    #611
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    I'm in no hurry, feel free to wait and only make one trip to the PO.
  12. Jan 9, 2019 at 6:14 AM
    #612
    Roostfactor
    TX panhandle
    Thanks man. They are both going out today.
    BassAckwards, Hawk373, Torspd and 6 others like this.
  13. Jan 9, 2019 at 7:08 AM
    #613
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Soooo, lucky #13 is next.....
    Roostfactor[OP] and rmepilot like this.
  14. Jan 9, 2019 at 10:37 AM
    #614
    Roostfactor
    TX panhandle
    You got it! Literally.
    At Post Office now mailing off #11 and #12.
  15. Jan 9, 2019 at 10:57 AM
    #615
    PTinUT
    PTinUT New Member
    Phil
    SLC Utah
    2007 Tacoma ACC CAB 4X4 V6 TRD Offroad
    TRD (old style) CAI, URD MAF calibrator
    Did those boxes give anyone else Tetris flashbacks?
  16. Jan 9, 2019 at 10:58 AM
    #616
    rmepilot
    Rob
    Huntsville, AL
    :goingcrazy:
  17. Jan 9, 2019 at 12:05 PM
    #617
    Roostfactor
    TX panhandle
    Well, you will have one box to start your real life Tetris in due time sir!
    @rmepilot @Laoturk check your PM's. You have tracking #s.
    Also a quick shout out to everyone that has ordered and is patiently waiting. I REALLY appreciate your patience. I am making progress.
    Roost
  18. Jan 9, 2019 at 12:18 PM
    #618
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Patiently waiting for Christmas 2.0
  19. Jan 9, 2019 at 12:18 PM
    #619
    rmepilot
    Rob
    Huntsville, AL
    :thumbsup:
  20. Jan 9, 2019 at 12:31 PM
    #620
    rmepilot
    Rob
    Huntsville, AL
    You did make sure the babies weren't swapped at the nursery, correct? :eek:
    Murphinator and Roostfactor[OP] like this.
