JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. Jan 18, 2019 at 10:20 AM
    #681
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    You should totally do it!!!...... I was just asking to ask. If I was coming down to meet you boys I’d have every intention to buy this and get everything ported I could given the timeline.
    BassAckwards[QUOTED] likes this.
  2. Jan 18, 2019 at 10:23 AM
    #682
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    It's not finished yet. If time permits it could be. $350 and I need your old one.
    It does make sense if we have time.
  3. Jan 18, 2019 at 10:33 AM
    #683
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    For the 350 would you be willing to help me with mild porting of my TB and S/C intake piping?
    Would the s/c manifold need to be ported as well to be effective?
  4. Jan 18, 2019 at 2:43 PM
    #684
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Liked the first part, disliked the second part.
    Definitely the right time to swap manifolds. I can tell you from the last time @Roostfactor came to Houston and we did mine, it was time consuming! (porting the TB and the blower)
  5. Jan 18, 2019 at 2:51 PM
    #685
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Tomorrow. Low 30 (9am) , High around 42 (4pm). 9am feels like 18. Looks cold AF I'm stopping to get some gloves!!! :D
    Torspd and BassAckwards like this.
  6. Jan 18, 2019 at 2:53 PM
    #686
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Nope. Nope. Nope.
  7. Jan 18, 2019 at 2:55 PM
    #687
    BassAckwards
    Will probably go ahead and do that, even though i know i shouldnt :cookiemonster:
    Gonna bring my dremel in case this turns into a porting party! I probably dont have the attachments needed, but if i end up needing to i can run to lowes or something and get what i need. What do you use for porting/polishing?
  8. Jan 18, 2019 at 8:23 PM
    #688
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Not sure, we used John’s bits and I think he got them from Amazon. Don’t know if the HD/Lowes has them or not.
  9. Jan 19, 2019 at 4:22 AM
    #689
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  10. Jan 19, 2019 at 5:14 AM
    #690
    Roostfactor
    TX panhandle
    Yes my bits are Amazon specials.
    Dont know if we will have time to do it today but we will see. Especially after finishing up @elnip's exhaust.
    loginfailed likes this.
  11. Jan 19, 2019 at 5:21 AM
    #691
    Roostfactor
    TX panhandle
    Sure! Its mod day! The $350 is for the ported manifold. The rest of the labor is free on mod day!:D
  12. Jan 19, 2019 at 5:24 AM
    #692
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have to leave around 5. I’ve got some stuff to do early Sunday so I need to get back tonight. So probably all I’ll do to mine today is put the door seals on. Planning on focusing on @rjbiii ’s rig, since he’s got a healthy list of to-dos.
  13. Jan 19, 2019 at 5:28 AM
    #693
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I brought most of my Snap-On cordless stuff so we can zip that blower off lickety-split!
  14. Jan 19, 2019 at 5:57 AM
    #694
    ThomasMore66
    Dallas/Fort Worth & Durango
    @loginfailed, looks like cold air in the Falls this am. You should go for a big run.
  15. Jan 19, 2019 at 6:34 AM
    #695
    Roostfactor
    TX panhandle
    Come on out Tomas. Its finally not too hot out.
  16. Jan 19, 2019 at 8:04 AM
    #696
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You were right. No cooler needed. You on your way? :D
    18469006-FF42-436C-AF3B-90018C76AFBE.jpg 6FF17DC4-E08A-46DF-ADB9-CDE557DCDFBC.jpg
  17. Jan 19, 2019 at 10:13 AM
    #697
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Still coughing up junk. :pout:
  18. Jan 19, 2019 at 2:35 PM
    #698
    ThomasMore66
    Went somewhere colder.
  19. Jan 19, 2019 at 3:52 PM
    #699
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Looks fake :rofl:
    BassAckwards likes this.
  20. Jan 19, 2019 at 3:56 PM
    #700
    ThomasMore66
