JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. Jan 22, 2019 at 5:43 PM
    #781
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Excellent, thanks for the tips. Gonna give this a go and see what i can find
  2. Jan 22, 2019 at 5:47 PM
    #782
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Just go slow with brake clean and it will be easy to find ur leak. Sounds like vacuum leak. Can only be from the maf to the heads. Not a big area to check
    BassAckwards likes this.
  3. Jan 22, 2019 at 5:52 PM
    #783
    BassAckwards
    So if i spray the cleaner and there is not a vacuum leak there, then the idle will not be affected right?
  4. Jan 22, 2019 at 5:56 PM
    #784
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Correct. If there’s a vacuum leak it’s sucking in air. The brake clean will stop the leak and will change how it idles.
  5. Jan 22, 2019 at 5:58 PM
    #785
    BassAckwards
    Any idea if MAF cleaner would work for this? I dont have any TB or brake cleaner
  6. Jan 22, 2019 at 6:02 PM
    #786
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes. Anything flammable.
  7. Jan 22, 2019 at 6:03 PM
    #787
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Just don’t waste good booze on it. :drunk:
  8. Jan 22, 2019 at 6:23 PM
    #788
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    It’s all just brake clean relabled haha
  9. Jan 22, 2019 at 6:54 PM
    #789
    BassAckwards
    Well just gave it a go and had trouble finding it. Gonna just plan to tear it all down and go through everything in a couple days
  10. Jan 22, 2019 at 7:27 PM
    #790
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Scott only wants stock ECUs to piggy back the Ucon nowadays and that is pretty unfortunate. Back when everybody had the TRD reflash, you could easily take out the ucon and find out whether or not the ucon was the culprit first off the bat. I think the 7th and the 455s are plenty for fuel. I’d only get the bigger injectors for e85. Didn’t all the problems start after having the 61s installed? @rjbiii
    BassAckwards and Roostfactor[OP] like this.
  11. Jan 22, 2019 at 7:53 PM
    #791
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Man this sucks dude....I’ve haven’t been paying too much attention due to work. When did this start??
    BassAckwards[QUOTED] likes this.
  12. Jan 22, 2019 at 7:56 PM
    #792
    ThomasMore66
    Dallas/Fort Worth & Durango
    So you could flip back a few pages...
  13. Jan 22, 2019 at 8:34 PM
    #793
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Too bad we don’t live closer I’d definitely help you troubleshoot. Don’t let it discourage you, shit like this is what separates the men from the boys.
  14. Jan 22, 2019 at 8:48 PM
    #794
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Nevr give up
  15. Jan 23, 2019 at 6:02 AM
    #795
    BassAckwards
    Yessir all started after bigger injectors went in. That's why im leaning towards a vacuum leak or bad o-ring/gasket. Everything had to come apart and then i was in a rush to get it all back together to be ready for my appt with Scott for the retune. Probably something simple, just gotta take it apart to find it
    Just this past weekend after i had everything apart. Im sure ill find it though, seems like the rough idle is definitely related to the problem
    Appreciate it man, yeah the size of the state of tx kinda puts a damper on that. Wish there was someone in my area that was boosted. Truer words never spoken sir, couldn't agree more
    @Roostfactor sorry this has turned into rjbiii's troubleshooting thread :anonymous:
    Roostfactor[OP] likes this.
  16. Jan 23, 2019 at 6:20 AM
    #796
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    No worries. @loginfailed had a great idea of a possible problem...if you guys tightened the sc supports (drivers side) before the lower intake manifold to sc bolts then there could be a leak between the lower intake manifold and sc.
  17. Jan 23, 2019 at 6:32 AM
    #797
    BassAckwards
    Yeah i am starting to think that could have happened in the haste to finish up. I think i may have tightened up the side ones first. We were having an issue getting the front bolt on the side bracket to line up (and we never took the bottom bolt loose on that), so something isn't sitting 100% perfectly..
  18. Jan 23, 2019 at 6:47 AM
    #798
    Roostfactor
    TX panhandle
    I think that was the bracket that I noticed didnt have a bolt in it when we installed your headers so I put one in.
  19. Jan 23, 2019 at 7:06 AM
    #799
    BassAckwards
    Yeah it was definitely one of those, cant remember if that was the front or back one though. I am fairly confident i will have things sorted here in a couple days
  20. Jan 24, 2019 at 8:43 AM
    #800
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    The following are installed showing the clearance at various points.
    luck 13.jpg installed.jpg Clearance.jpg clearance 2.jpg clearance 3.jpg clearance 4.jpg clearance 5.jpg
    There is great clearance at every vital point. The only concern on a 5th Gen T4R is with a flex, cat and resonator, there is not a lot of length back to the muffler so we cut down every piece to save as much length as we could. Roost did an awesome job and put a piece of pipe beneath every connection from the flex to the resonator for structure. I have the Thermo-Tec to place over the tranny and where the wires to come out for the inverter but don't show it here.
    I just love the way is sounds and the throttle response is excellent as well and the overall increase in drivability, especially being NA.
